TheGuitarGuy Riviera Penthouse Resident
Joined: July 17, 2005 Posts: 582 Location: Los Angeles, CA.
Posted: Thu Aug 04, 2005 10:24 am Post subject: Riviera Top Bunk |
I was just wondering if anybody had a picture of how the top bunk of a riviera should look. Mine came with a thin wood extension then makes it long enough to sleep on, but the cusion isn't long enough to cover the extension as well...I was just curious as to how it was origionally supposed to be _________________ My 78 "Virginia"
Raw Musicians Forum |
spiffy Samba Member
Joined: July 19, 2004 Posts: 531 Location: Tacoma, WA
Posted: Thu Aug 04, 2005 10:41 am Post subject: |
the extension should be cushioned w/ matching fabric. Does your extension store up along the roof behind the back seat/bed? I will try to take a pic of mine later today. _________________ 78 Riviera
67 Riviera
www.rivieraregistry.com |
Posted: Thu Aug 04, 2005 11:03 am Post subject: |
My extensions just sits up in the top bunk under the cusion. Also on the thin wood extension, there is too square cutouts on the end of it. just wondering if those are for something, or is mine is just special (hacked up by PO) lol _________________ My 78 "Virginia"
MHACK Samba Member
Posted: Thu Aug 04, 2005 11:32 am Post subject: TOP BUNK RIVIERA |
THE EXTENSION PIECE SHOULD ALSO BE PADDED TO MATCH HIGHT OF THE TOP BUNK. BEST STORED IN OTHER PLACE BECAUSE IT TAKES UP NEEDED SPACE WHEN NOT IN USE.  |
JSO Samba Member
Posted: Thu Aug 04, 2005 1:34 pm Post subject: riviera bunk |
i'll post a picture or two tomorrow. _________________ 1964 Standard Beetle
1974 Standard Beetle
2005 New Beetle Vert
2006 New Beetle Coupe |
spiffy Samba Member
Posted: Thu Aug 04, 2005 6:24 pm Post subject: |
here ya go
proper place for storage. We take it out for storage on longer trips when it is just my wife and I. _________________ 78 Riviera
67 Riviera
Posted: Thu Aug 04, 2005 7:24 pm Post subject: |
Thanks man...wow mine doesn't look like that...the wood on my top bunk isn't "padded" but there is a plaid cusion that goes up there that is the size of the unextended bunk, and the extension has no padding...I don't think the extension is origional, because it's very thin wood. _________________ My 78 "Virginia"
Hecubus Samba Member
Joined: March 28, 2005 Posts: 206 Location: Calgary Alberta
Posted: Fri Aug 05, 2005 3:52 pm Post subject: |
My 71 looks a little different then that. The extension just folds up twice like and accordion and stays up top. the top cushion is also in two parts and overlaps to stay up top. I will try to post a pick when I have a chance.
Kent |
spiffy Samba Member
Posted: Fri Aug 05, 2005 9:44 pm Post subject: |
I think you could make one up pretty easily, after all the feet region for sleeping doesn't have to support too much weight.......it would be nice to have a level sleeping surface though  _________________ 78 Riviera
67 Riviera
Posted: Fri Aug 05, 2005 10:43 pm Post subject: |
How thick is the wood of the extension? for you guys who have the origional one, because I'm going to make a better one, I just don't like the extension being so flexible...my feet almost cause it to flex.  _________________ My 78 "Virginia"
spiffy Samba Member
Posted: Sat Aug 06, 2005 3:47 pm Post subject: |
I measured mine and it looks to be 3/4" plywood......good luck with the project  _________________ 78 Riviera
67 Riviera
bobby g Samba Member
Posted: Sat Apr 08, 2006 3:35 pm Post subject: |
| you should have a two part mattress. your missing the other part. if you look on your matress you should see some buttons, they will conect |
nwcutie Samba Member
Joined: March 12, 2006 Posts: 9 Location: University Place, WA
Posted: Sat Apr 08, 2006 10:46 pm Post subject: |
| My pop-up has a funky wood extension too and the mattress is thin and doesn't cover it all. I was planning on getting some foam and making a new mattress and covering it to match the new curtains I'm sewing. |
TrickyThom Samba Anarchist
Posted: Sun Apr 09, 2006 9:59 am Post subject: |
http://trickythom.com/Gallery/album01?page=3
I put 2 picks of my upper extention w/ measurements there for you. I have a 77, so they are probably the same style. _________________ 1977 Riviera |
