How much room behind glovebox
Mberglo
Mberglo is offline
PostPosted: Thu Jan 28, 2021 1:40 pm    Post subject: How much room behind glovebox Reply with quote
I currently have my dash out and am curious about the distance between glovebox and the nose sheetmetal. I need to find a place to mount a small bluetooth amplifier, and if I have 1.5inches available, mounting behind (in front) of the glovebox would be ideal.
SGKent Premium Member
SGKent is offline
PostPosted: Thu Jan 28, 2021 2:33 pm    Post subject: Re: How much room behind glovebox Reply with quote
I can't tell you exactly what it is, but I mounted my amp on the airbox tube. You have to be careful because some areas are double wall and some are single. If you choose a single area you will put the screw right thru the nose.
here are some photos from the gallery what it looks like with the nose skin off.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
Mberglo
Mberglo is offline
PostPosted: Thu Jan 28, 2021 3:18 pm    Post subject: Re: How much room behind glovebox Reply with quote
Yes, that would suck.
pioneer1
pioneer1 is offline
PostPosted: Thu Jan 28, 2021 4:22 pm    Post subject: Re: How much room behind glovebox Reply with quote
How about above the radio where the original speaker was?
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
Mberglo
Mberglo is offline
PostPosted: Thu Jan 28, 2021 5:30 pm    Post subject: Re: How much room behind glovebox Reply with quote
That might work. Attached to the metal dash cover?
SGKent is offline
PostPosted: Thu Jan 28, 2021 6:00 pm    Post subject: Re: How much room behind glovebox Reply with quote
The center air box has a tube on each side that runs out to the doors. That is a perfect place to mount something and where I mounted an amp, and an extra fuse box. The fuse box, and a small VDO gauge light trimmer are on the left side and the speaker amp on the right under the glove box.
You can mount on the cabin side of this tube. The screws will stick into the tube and not bother anything like my fuse box and the light trimmer.
George Carlin:
1971 deluxe (sold)
1977 deluxe
mikedjames
mikedjames is offline
PostPosted: Fri Jan 29, 2021 2:17 am    Post subject: Re: How much room behind glovebox Reply with quote
There is a fair amount of space in a wedge shaped volume above the glove box and behind the plastic hoses going up to the dash. You might have to make a bracket to suspend it in mid-air, and the installation might get in the way of putting in the glovebox liner.
Ancient vehicles and vessels
Abscate
Abscate is offline
PostPosted: Fri Jan 29, 2021 4:01 am    Post subject: Re: How much room behind glovebox Reply with quote
There is tons of room behind the glove box. It’s in front of the glove box that is more difficult Very Happy
