gitchesum Samba Member
Joined: November 10, 2003 Posts: 515 Location: North Cali
Posted: Wed Feb 17, 2021 3:13 pm Post subject: Lowering |
I've read all the posts about this . So there's that.
I need to drop the front down about 6 inches. I don't think I'll be able to get that with the beam and spindles. Thinking I might be able to squeak out 4 in. with that combo.
How far can I increase the length of that slot in the beam, and what'll I get ?
I just need a good 6 in.  _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
ALB Samba Member
Joined: August 05, 2008 Posts: 3499 Location: beautiful suburban Wet Coast of Canada
Posted: Sat Feb 20, 2021 2:26 pm Post subject: Re: Lowering |
Have you included 1 1/2-2" for shorter front tires as well? 185/60-15's are only 23 3/4" tall and there's a bunch even shorter. I can't imagine a 25-25 1/2" tire clearing everything with a 356 dropped that much... Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Sat Feb 20, 2021 6:44 pm Post subject: Re: Lowering |
Currently have 185/55's mounted on these wheels. When the car is on the ground I have 27 1/4 " to the ground, from the top of the fenderwell. with an appx 6 inch space between the top of the tire to the bottom of the fender. Like to see that at zero.
57 SC
61 356B
GMC SLT 4x4 Dmax
William Crowell Samba Member
Joined: February 15, 2011 Posts: 91 Location: Placerville, CA
Posted: Tue Feb 23, 2021 5:52 am Post subject: Re: Lowering |
I'm sure it will be JUST FINE!
Posted: Tue Feb 23, 2021 10:15 am Post subject: Re: Lowering |
Gorgeous...for a replica. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
Posted: Tue Feb 23, 2021 10:18 am Post subject: Re: Lowering |
Took out the adjusters to grind up the slot. This is the look I'm after, and will require spindles. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
Posted: Fri Apr 02, 2021 8:44 pm Post subject: Re: Lowering |
So i took the beam adjusting block out, and ground the top down 1/4 inch and notched the beam slot 1/2 inch. Dropped the car 3 inches and still has plenty of travel in the front. Now onto the dropped spindles to give me almost 3 inches more. Plus running a 185/60 tire.
57 SC
61 356B
GMC SLT 4x4 Dmax
