Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3999 Location: Antioch, California, a block from the hood
halbug Samba Member
modok Samba Member
Joined: October 30, 2009 Posts: 27757 Location: Colorado Springs
Posted: Sun Feb 07, 2021 12:32 pm Post subject: Re: Cool Transmission |
halbug Samba Member
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Sun Feb 07, 2021 2:44 pm Post subject: Re: Cool Transmission |
| I used to have( still do somewhere) a 12 volt oil transfer gearotor oil pump for outboard yamaha engines to transfer the oil from the big tank to the engine mounted small tank.I was going to use it for either a prelube pump befor start up instead of a accusump or for a trans oil pump like you are doing. I almost did my vw trans for it but couldn't find it among all my "stuff", I thought about making a scoop to catch the throw off from the ring gear to send forward but didnt do that either.... after it was all done and installed I did a good amount of driving and 3 gear lube changes after a hour of playfull driving the trans was warm...just warm. it was a lot cooler than I thought. witch made me rethink some of the clearances I put in it as far as case growth end to end and the pinion thrust bearing I put in it, I probably put it in too tight due to the dam little heat the case was witch means the case wasent growing half as much as I thought it would. oh well it worked fine for 3 years till I sold the car and havent heard anything from the tickled shittless buyer. |
halbug Samba Member
halbug Samba Member
halbug Samba Member
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23547 Location: Oklahoma City
Posted: Fri Jun 25, 2021 12:47 pm Post subject: Re: Cool Transmission |
Nice cooler! Who makes that one please!
Ray |
Bad bug Samba Member
Posted: Fri Jun 25, 2021 12:48 pm Post subject: Re: Cool Transmission |
| halbug wrote: |
Cooler is in place
Halbug is that a whiteline sway bar you have on the backend if not can you tell me which it is, i need a set of sway bars front and back. |
halbug Samba Member
halbug Samba Member
Posted: Sat Jun 26, 2021 6:38 am Post subject: Re: Cool Transmission |
| Ok thanks for the information. Do you plan on putting a scoop around the cooler the scoop could double as protection. |
halbug Samba Member
Posted: Sun Jun 27, 2021 11:26 am Post subject: Re: Cool Transmission |
| ok. |
Tvättbjörn Samba Member
Posted: Sun Jun 27, 2021 11:16 pm Post subject: Re: Cool Transmission |
| halbug wrote: |
| Bad bug wrote: |
| halbug wrote: |
Cooler is in place
This sway bar is part of the Mendeola rear axle kit. Not sure it will fit original trailing arms? |
It looks like the Sway-away bar just mounted with different weld-on mounting brackets. I have one listed for sale. Does your sway bar has a number stamped on it? I can look at mine to check for the number. |
halbug Samba Member
halbug Samba Member
Posted: Thu Aug 05, 2021 1:46 pm Post subject: Re: Cool Transmission |
[quote="halbug"]
| halbug wrote: |
Based on some Porsche racing transmissions I have seen, I like the idea to return the cooled oil through jets directly onto the gears - at least some of the oil...
To make sure I have constant pressure and therefore even supply to all those points, I designed a distributor block with build-in pressure regulator. Anything past 10-14psi (adjustable with washers) will return directly into the case, through the oil filler hole.
And yes, it is a fuel injection rail profile
quote]
Very nice!
Is that just a spring loaded ball check valve inside?
Ray
Altmost to plan  |
halbug Samba Member
