Wish I'd Discovered This A few Engines Ago.
&Dan
&Dan is offline
PostPosted: Tue Mar 16, 2021 11:09 am    Post subject: Wish I'd Discovered This A few Engines Ago. Reply with quote
The annoying pushrod tube juggle gets a lot easier when you go find your drumsticks, stick one down the first pushrod tube you place, then the remainder go lickety-split. Thanks, Buddy Rich!
earthquake
earthquake is offline
PostPosted: Tue Mar 16, 2021 12:08 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
I wish we had a "LIKE" button great idea but now I have to buy some drum sticks.
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
jpaull
jpaull is offline
PostPosted: Tue Mar 16, 2021 12:21 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
Some here that will just look at the picture and not read your post, they will be assuming thats the new lightweight pushrod set, cause saving 2 ounces will gain 10 horsepower Rolling Eyes
[email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth.
Dan Ruddock
Dan Ruddock is offline
PostPosted: Tue Mar 16, 2021 12:44 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
I just use a deep socket that fits.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Mar 16, 2021 12:46 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
I never had a problem lining them up.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
FreeBug
FreeBug is offline
PostPosted: Tue Mar 16, 2021 1:13 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
Bu-dum tish...
mark tucker
mark tucker is offline
PostPosted: Tue Mar 16, 2021 1:14 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
your going to have some serious thick shims for those pushrods.now the only thing missing is the rimshot!!!
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Tue Mar 16, 2021 1:17 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
I’ve always just used to pushrods themselves especially when building an engine in the upright position. This holds everything in the correct position as you line up the seams and get ready to tighten. Not shown any manual it was shown to me 25 or 30 years ago by the old man building engines.
&Dan
&Dan is offline
PostPosted: Tue Mar 16, 2021 1:20 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
Was waiting for a rimshot, was not disappointed!
Actually, any excuse to make a reference to Buddy Rich, I'm gonna use it.
Also, I never seem to have the pushrods nearby when at the head-setting stage, typically I don't install them until I've spun the motor up for oil pressure.
PostPosted: Tue Mar 16, 2021 5:57 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
I was thinking about drummers and thought of Gene Krupa and then this popped up😀 https://www.youtube.com/results?search_query=gene+krupa+buddy+rich+drum+battle+
evanfrucht
evanfrucht is offline
PostPosted: Tue Mar 16, 2021 6:00 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
I don't get what the drum sticks are doing? What's the juggle? Don't they pretty much just fall into place, like you can simply feel when they are seated into the lifter cups?
What does this help with?
1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder )
modok
modok is offline
PostPosted: Tue Mar 16, 2021 6:17 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
neat trick. It can be a pain sometimes.
The windage pushrod tubes are easier because the case end does not want to fall out.
&Dan
&Dan is offline
PostPosted: Tue Mar 16, 2021 7:12 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
Right? Man were those guys good, and they knew it.
For me it's a pain all the time, tubes falling on the floor, exasperating. Never been good at it.
T4s and Corvairs excepted.
nsracing
nsracing is offline
PostPosted: Tue Mar 16, 2021 8:46 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
I just use the pushrods to hang them tubes all together while I introduce the heads on the cylinders. AFter the seals are in place in their holes you can remove the pushrods. SErve like 12th hands on there.
Those drumsticks look silly - Laughing
Anyone else have used a sledgehammer to build engines? I find no use for a larger hammer building engines. Very Happy
modok
modok is offline
PostPosted: Tue Mar 16, 2021 9:17 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
All the time.
Who has 10+ different kinds of hammers?
master craftsman.
The more hammers they have probably the higher the skill.
Or possibly a hammer collector, or an idiot, but probably not.
The first tool you learn to use, but you will never master it.
"Just need a bigger hammer"......is probably wrong, but it's also sometimes right:lol:
Rubber hammers, wood, brass, lead, long and skinny, big and fat, flat face, radius, dead blows, and all combinations of the above, in every size.
If your bigger hammer is not working, probably using it wrong, or it's not the right kind of hammer for the job. Or maybe the wrong operator.
evanfrucht
PostPosted: Tue Mar 16, 2021 9:50 pm    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
LOL! No wonder I didn't understand this as I'm building my engine with the windage tubes. They stand up straight by themselves. Now I get it...
Dougy Dee
Dougy Dee is offline
PostPosted: Wed Mar 17, 2021 5:09 am    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
I looked and the second thing I thought is "Must have big balls! He's building that in the kitchen!"
&Dan
&Dan is offline
PostPosted: Wed Mar 17, 2021 8:43 am    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
Only as a matter of course...
Thanks for weighing in.
PostPosted: Wed Mar 17, 2021 8:44 am    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
There is probably 1000 different ways to do this and other tasks when building engines. Standard procedures are in manuals but much of what needs to be done is not. From time to time someone will share an idea or technique and I really appreciate that.
As for building indoors I can’t think of anything better. I kept a clean engine case on a dresser in our bedroom, and wife didn’t care. Since the house is climate controlled it’s ideal for storing things you don’t want to rust or corrode. This engine has been on the shelf for over twenty years is all standard. All the parts are there too.
The transaxle is swing but uses a later IRS case, look at the TO bearing, has 3.88 RP I’ve just not had occasion to use it. Stored inside it’s holding up well
PostPosted: Wed Mar 17, 2021 8:46 am    Post subject: Re: Wish I'd Discovered This A few Engines Ago. Reply with quote
And yes I see the white stuff on tranny case. Needs a wipe down and hit it with Gibbs.
