easy e Samba Member
Joined: May 28, 2008 Posts: 3939 Location: 1 hr north of Santa Barbara
Posted: Sun Mar 14, 2021 10:21 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
I bet it was the location for a spotlight.
bobrk wrote: |
Another mystery on my truck is this antenna mount. It looks like they had it mounted between the windshields. Seems like it had a very weird angle to clear the top. Maybe it was a CB radio with one of those swiveling mounts?
_________________ aka: Evan
bobrk Samba Member
Joined: March 07, 2002 Posts: 290 Location: Beautiful Downtown San Jose
Posted: Sun Mar 14, 2021 10:30 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
easy e wrote: |
I bet it was the location for a Unity spotlight.
https://www.unityusa.com/thumbnail.asp?file=assets...amp;maxy=0
bobrk wrote: |
Actually, that was always an option in my mind as well! Thanks for the pic, it looks exact. _________________ 1959 Single Cab “Otto”
1500 single port | 1963 small nut/big brake transaxle | CSP Disc Brakes | dual circuit m/c | Deutsch Polster seats |
bobrk Samba Member
Posted: Sun Mar 14, 2021 12:06 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
easy e wrote: |
I'm going to keep an eye out for one, that would look badass. _________________ 1959 Single Cab “Otto”
ach60  Samba Member
Joined: May 14, 2001 Posts: 4137 Location: Santa Maria
Posted: Mon Mar 15, 2021 11:31 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
bobrk wrote: |
easy e wrote: |
I'm going to keep an eye out for one, that would look badass. |
https://www.ebay.com/sch/i.html?_from=R40&_nkw...ondition=4 _________________ Good Luck
Al |
bobrk Samba Member
Posted: Wed Mar 24, 2021 6:51 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Some days, you want to work on your truck but you're not sure what you want to do, so you just poke around and do stupid things like uncover it so you can look at it and just wash the windows.
Here are some pics from my spelunking...
I think all the glass is OG, a combination of Delog windshields and Sekurit side and back windows. And I just looked up "ver bund" and it means composite, which makes sense for a laminated windshield.
Thought I'd go look at the engine and was gratified to see that not only did it still have oil in it, it even turned, so I'm optimistic that it will start after 20 years with some careful preparation.
Brazilian carb?
Voltage regulator? And some solenoid...
12 Volt generator...
Also, it's an "H" engine, will have to look that up.
Thanks to this site, I know it's a Sep 65 1500 block.
https://www.thesamba.com/vw/archives/info/chassisdating.php _________________ 1959 Single Cab “Otto”
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15204 Location: Casa de Oro, California
Posted: Thu Mar 25, 2021 6:12 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
There's a black widow in your brushes. Can't say I've ever seen a pulley broken like that before. It looks like it's cast iron. |
bobrk Samba Member
Posted: Thu Mar 25, 2021 7:29 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
BarryL wrote: |
Good eye. I didn’t even notice. _________________ 1959 Single Cab “Otto”
apexxn Samba Member
Joined: September 09, 2002 Posts: 39 Location: Southern California
Posted: Thu Mar 25, 2021 8:03 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
BarryL wrote: |
There's a black widow in your brushes. |
And we all know how painful that can be.  |
bobrk Samba Member
Posted: Fri Mar 26, 2021 8:41 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Long-roofs wrote: |
Looks like you are dealing with '63 one ton rear drums, they take the longer stub axle, you may have the 3/4 ton shorter axle on the one side. |
I’ve been mulling this statement for weeks now. Is there any documentation of this anywhere? I can’t find anything online or in my Bentleys. I’d just like to verify before cutting my drum up. _________________ 1959 Single Cab “Otto”
ach60  Samba Member
Posted: Mon Mar 29, 2021 6:17 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
bobrk wrote: |
That is a 38 amp gen from your Kazbus.
The 38 amp is more powerful than the 30 amp found on Bugs.
Also the backing plates are different because the 38 amp Gen is longer.
There is some damage to that pulley, but completely useable.
It's OG german cast, and BETTER than anything you can get now. _________________ Good Luck
Al |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25895 Location: Olympia Wash Rinse & Repeat
Posted: Mon Mar 29, 2021 6:30 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Always make sure when working on the gen or alt pulley, that the screwdriver used to lock the pulley from turning is kept pointed at the pulley nut you are loosening or tightening. Allowing the screwdriver to tilt at all will result in cracking out chunks from those cast pulleys or bending up the pressed pulleys.
It might be a 38 AMP gen, but have seen those from the FLAPS rewound into a 30 AMP gen instead. _________________ In Stereo, Where Available! |
bobrk Samba Member
Posted: Mon Mar 29, 2021 6:49 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Eric&Barb wrote: |
It might be a 38 AMP gen, but have seen those from the FLAPS rewound into a 30 AMP gen instead. |
Naw, that gen was out of an untouched one owner 1969 camper that I had for a while. I’m assuming the pulley was from the truck. I’m gonna change that belt, though and will inspect that pulley at the time.
So nobody’s got an answer on my stub axles? Was there a difference in length between the 3/4 and 1 ton rgbs stub axles to make up for bigger (wider) brakes and they interchange? _________________ 1959 Single Cab “Otto”
Posted: Mon Mar 29, 2021 8:08 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
bobrk wrote: |
So nobody’s got an answer on my stub axles? Was there a difference in length between the 3/4 and 1 ton rgbs stub axles to make up for bigger (wider) brakes and they interchange? |
The one year only 1 ton stub axles are longer. Ran a pair of the stub axles with the 3/4 ton drums and had to add a shim between drums and axle nut. Think it was about 1/4" (6mm) thick. _________________ In Stereo, Where Available! |
bobrk Samba Member
Posted: Mon Mar 29, 2021 8:39 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Eric&Barb wrote: |
bobrk wrote: |
The one year only 1 ton stub axles are longer. Ran a pair of the stub axles with the 3/4 ton drums and had to add a shim between drums and axle nut. Think it was about 1/4" (6mm) thick. |
Ok, mine must be the opposite. I have the thicker brake drums that fit fine on one side, but need to be cut down on the other. 6mmm might be right. I'll have to check that.
Thanks! _________________ 1959 Single Cab “Otto”
bobrk Samba Member
Posted: Tue Mar 30, 2021 10:57 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Another thing I realized: I guess when people say "big brake" they mean WIDER brake drums, not larger diameter ones. _________________ 1959 Single Cab “Otto”
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Tue Mar 30, 2021 11:17 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
bobrk wrote: |
Another thing I realized: I guess when people say "big brake" they mean WIDER brake drums, not larger diameter ones. |
Yes the surface area of the friction material is larger resulting in a widere shoe and drum. |
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1592 Location: Annapolis, MD/Bloomfield Hills, MI
bobrk Samba Member
Posted: Tue Mar 30, 2021 11:39 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
peecee69 wrote: |
bobrk wrote: |
When speaking of drums, yes. When referring to discs, it's a larger "contact surface" of the brake, which typically means a larger diameter rotor (along with bigger pistons). |
Specifically, I was referring to the designations for the various RGB/Transmission setups on buses. I've always referred to the "upgraded" setup on my bus as a "small nut/big brake" system, but I never saw any larger diameter brake drums, just wider ones. So this makes sense as far as my axle stub discrepancy although it is a bit weird that I would have a 1 ton axle on one side and a 3/4 ton axle on the other side. It's amazing that they interchange... I do need to do some homework on the gears, hopefully this bus has not been driving around with different ratios on each side! _________________ 1959 Single Cab “Otto”
bobrk Samba Member
Posted: Wed Mar 31, 2021 11:17 am Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
Another interesting mystery is this blue paint under my VW emblem...
It does look like that white paint is flaking off, and you can see the SWR on the outside of the emblem, under the same flaking white paint.
I will have to pull the emblem off to see, and since it's missing a couple of clips anyway, it's probably a good idea. _________________ 1959 Single Cab “Otto”
bobrk Samba Member
Posted: Wed Mar 31, 2021 3:33 pm Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" |
In my never-ending quest to find the keys to this stupid bus, I pulled out my long lost paper file from my truck. Besides a million receipts and a bunch of '92 Miata brochures and receipts, I found these interesting documents.
Original CA DMV registration cards from the late 70s...
Single Cab illustrations from an old S.O.T.O. 'zine...
The Miata reference is interesting. My original web page for this bus insinuated I bought it because I was working on an old house and couldn't really carry anything in the Miata.
http://www.bobrk.com/otto/ _________________ 1959 Single Cab “Otto”
