blinking coolant temperature LED
Page: Previous  1, 2, 3 ... 13, 14, 15
Nuthin2It
Nuthin2It is offline
PostPosted: Thu Apr 29, 2021 5:49 am    Post subject: Re: blinking coolant temperature LED Reply with quote
Hopefully my solution to this problem is not already in this thread. I read through it all, with special attention to David Beierl's posts, but, I confess, I may have glazed over a few times.
I've been confounded by the red blinking light for a couple of years. It first appeared when we were in eastern Washington state (we live in Atlanta). The light blinked for a full day, then, thankfully, cured itself for the rest of the trip.
The light finally came on and stayed on a few weeks ago. Time to figure this out. When I pulled the Engine Coolant Level Relay, the light went off. Yes! Ordering a new one, though, was a problem. The guy at EuroCampers said the manufacturer discontinued them. They certainly seem to have disappeared from the vendors' shelves.
While waiting for another “order canceled” email, I checked the relay again. The light stayed on! Back to troubleshooting. Without going through all the things I tested and tried (this thread is already way too long), I discovered that the nuts on the posts behind the temperature gauge were loose. Holding a deep socket with my fingers, I snugged them down. Problem solved.
1985 Westfalia 15 degree EA288 Boxeer
coastdog
coastdog is offline
PostPosted: Mon Nov 13, 2023 2:53 pm    Post subject: Re: blinking coolant temperature LED Reply with quote
Are crazyvwvanman or dbreiel still monitoring this thread?
I have read all of this and still need some help.
My temp gauge light blinks correctly at start up and then blinks continuously again about 30 seconds after starting the engine or having the key in the run position. If I pull out the coolant level warning control module the blinking stops. The van is 1988 and the module is a 42.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Mon Nov 13, 2023 3:53 pm    Post subject: Re: blinking coolant temperature LED Reply with quote
That indicates a possible failed 42 relay but more likely a problem in the engine compartment.
The signal wire to the 42 relay from the coolant tank level sensor has a connection in the engine compartment wiring box, in one of the round 7 pin connectors. From there it goes to the 2 pin wiring connector in the top of the level sensor in the top of the coolant tank. From there the other wiring pin is a ground wire from there over to the body near the ignition coil.
A break or bad connection anywhere along that wiring path will cause what you are seeing.
A common trouble spot is the 2 pins of the sensor connection.
These can get corroded badly at times and stop making a reliable connection.
I have had to replace the wiring connector in several vans to get a reliable connection.
Mark
coastdog
coastdog is offline
PostPosted: Mon Nov 13, 2023 4:20 pm    Post subject: Re: blinking coolant temperature LED Reply with quote
Wow thanks for the quick response and information Mark. Is the signal wire tbe blue/green and does the brown ground from the other sender pin go back through the 7 pin connector before grounding under the coil.
I will check the signal wire as you described along that routing for a break or bad connection. Also try a new relay if I can find one.
coastdog
coastdog is offline
PostPosted: Tue Nov 14, 2023 8:22 am    Post subject: Re: blinking coolant temperature LED Reply with quote
One more question as I dig into this problem today. I have read that the glycol to water ratio is critical for the coolant low level warning system to work properly and that 50/50 is the correct ratio for a number of reasons. The main reason being correct continuity//resistance between the sensor pins.
So can both a too concentrated and too dilute coolant ratio affect the function of the coolant low level warning system?
crazyvwvanman
PostPosted: Tue Nov 14, 2023 12:01 pm    Post subject: Re: blinking coolant temperature LED Reply with quote
VW says that both conditions can cause it but I have doubts about the weak coolant end of it.
After working on the cooling systems on dozens of vans I have not experienced this. Some of those for sure had weak or mostly water for short test periods and didn't experience the flashing led in around town driving.
Maybe none of them had way too concentrated of coolant so I can't say if that would at some point be a problem.
When there is mostly water and more load driving I have experienced localized over heating which blows out some coolant and then gives a genuine low coolant warning.
Mark
coastdog
coastdog is offline
PostPosted: Tue Nov 14, 2023 10:41 pm    Post subject: Re: blinking coolant temperature LED Reply with quote
Followed the wire continuity from control relay through the connectors and the low coolant sensor and back to ground. I found the BL/G wire slightly backed out of the round 7 pin connector. System works as designed now. No flashing red LED. When I disconnect the plug connector on the top of the level sensor, the red light flashes after about 25 seconds. I have the GoWesty audible alarm installed and it sounds as well😃
Thanks for your help Mark!
Bill
Fhak915
Fhak915 is offline
PostPosted: Tue Nov 19, 2024 5:05 pm    Post subject: Reply with quote
Hello vanagon experts,
Guess I am chasing this issue on my 86 vanagon with stock coolant tank a bit longer.
Some of the electrical lingo here is a bit over my head but I’m dangerous enough to try to follow along.
Had the constant blinking light and after changing the coolant to verify the mixture, grounding the sensors wires, pulling the relay at the fuse block, the led continues to flash or blink.
I thought this was my only hope but after opening the temp gauge, everything looks good.
I’ll swap out the capacitor but this one looks good.
Not sure I want to take it all apart again if this doesn’t work, so was considering cutting the led to keep it from flashing.
I wonder if anyone would have any advice.
I’ll try reading this tread again but I suspect I might not fully understand this system.
Love this forum, learned so much from a distance, figured I’d try to reach out.
Thanks,
Frank
Frank
86 AW EJ22
DanHoug
DanHoug is offline
PostPosted: Tue Nov 19, 2024 5:19 pm    Post subject: Reply with quote
swap it out. that cap is 40 years old, about 20 years beyond normal life expectancy for an electrolytic cap.
-dan
www.thefixitworkshop.com
Fhak915
Fhak915 is offline
PostPosted: Tue Nov 19, 2024 5:39 pm    Post subject: Re: blinking coolant temperature LED Reply with quote
10-4
Thank, I got the yellow ones, not the aluminum one, not an electrical engineer so how do you tell the polarity?
The caps are in the mail, so I can’t tell if there is designations or what not.
Thanks so much.
Frank
86 AW EJ22
DanHoug
DanHoug is offline
PostPosted: Tue Nov 19, 2024 6:26 pm    Post subject: Re: blinking coolant temperature LED Reply with quote
Fhak915 wrote:
10-4
Thanks so much.
mmmyeah... "yellow ones" don't tell me much but they are likely tantalum. they will be marked with polarity on the cap itself and usually have a plus + sign for the positive lead. the cap you remove has a white band with down pointing arrows that designates the negative lead. put the tantalum plus lead on the opposite hole that the negative lead was on.
you don't have to be an EE to fix this stuff.... just know that + goes to +, - goes to -. order the same value in the same voltage OR GREATER voltage.
-dan
Page 15 of 15
