TheVintageVw Samba Member
Joined: July 19, 2004 Posts: 680 Location: Porter Ranch California
Posted: Mon May 17, 2021 3:37 pm Post subject: is this a sand seal and can I remove it |
Sorry for the horrible photo but is that orange piece a sand seal? If yes can I remove it and use an OEM pulley?
Thank you
donald.lemay Samba Member
Joined: March 01, 2009 Posts: 484 Location: Rhode Island
Posted: Mon May 17, 2021 3:54 pm Post subject: Re: is this a sand seal and can I remove it |
Yes it is
Some are machined in others are slip in. Pray for slip in. Only way to find out is remove the pulley and measure where the seal rides. Slip in will have a much smaller diameter. Machined in snout will be close to stock diameter.
Good luck
Don _________________ 66 13 window deluxe
2085cc
9to1compression
ported polished heads 40x36 valves
010 distributor
VS 42mm exhaust
40 IDF carbs |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52785 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon May 17, 2021 4:02 pm Post subject: Re: is this a sand seal and can I remove it |
The next big question is why is it there?, was the engine puking oil from the pulley?, or is it just the natural progression of adding shiny things?, like a useless bling breather that caused oil to come from the pulley? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon May 17, 2021 4:08 pm Post subject: Re: is this a sand seal and can I remove it |
No idea! It actually just started puking oil and it looks to be from the pully area.
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10249 Location: Petaluma, CA
Posted: Mon May 17, 2021 4:16 pm Post subject: Re: is this a sand seal and can I remove it |
It looks like that motor is set up with a sand seal of some type.
Typically you cut the case to install those, so if it’s leaking you’ll want to replace it with a seal of the same size.
You could probably have a stock pulley machined to work with that seal if you want to have it look more stock. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12546 Location: Over 2002 posts deleted!
Posted: Mon May 17, 2021 5:03 pm Post subject: Re: is this a sand seal and can I remove it |
That is indeed a “slip in” sand seal and you can remove it and install a stock pulley. However, if it is “puking oil” with the seal already in there, it will make a serious mess without it!
If it was me, I’d rebuild it AND machine it for the proper sand seal.  _________________ Some people are so busy being clever they don't have time enough to be wise. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4051 Location: San Diego
Posted: Mon May 17, 2021 5:13 pm Post subject: Re: is this a sand seal and can I remove it |
Could just be a bad seal. There are multiple sizes |
Posted: Mon May 17, 2021 5:29 pm Post subject: Re: is this a sand seal and can I remove it |
pyrOman wrote: |
If it was me, I’d rebuild it AND machine it for the proper sand seal.  |
I think I will do the stock pulley and also hookup the breather line from filler neck to one of my carbs and see if that helps.
I think the biggest challenge now is finding a stock pulley that isnt bent LOL |
MrWhoopee Samba Member
Joined: October 24, 2005 Posts: 178 Location: Shingletown, CA
Posted: Tue May 18, 2021 8:44 am Post subject: Re: is this a sand seal and can I remove it |
What size is the motor? If it's a large motor, the stock filler neck breather tube will not be enough, which is probably why the sand seal was installed. Removing the sand seal will most likely make a bigger mess than you have now. My 2110 is still pushing oil out past the sand seal, though it is much less than before I installed it. Working on the latest breather arrangement to see if I can stop it completely. _________________ Craig ('51 WASP)
Rosie ('63 Double Cab) |
Posted: Tue May 18, 2021 9:22 am Post subject: Re: is this a sand seal and can I remove it |
engine is an 1835 with Kadrons. The filler neck vent was just venting to the floor . I did rig up a "Catch can" just to see if I get anything out the tube but it was pretty clean. Now this could be because its coming out by the pulley. |
Posted: Tue May 18, 2021 9:54 am Post subject: Re: is this a sand seal and can I remove it |
TheVintageVw wrote: |
I wouldn't expect much oil making it out the stock breather. An 1835 isn't that much bigger than stock, but the sand seal was added for a reason. I would suggest upgrading the breathing and maybe get a replacement seal before I removed it completely. Venting to the air cleaners is a topic of disagreement due to the possibility of introducing a significant amount of oil to the fuel mix. I don't see that as a problem here, but keep in mind that there is very little vacuum inside the air cleaner unless the filter is clogged. I see a breather box in your future. _________________ Craig ('51 WASP)
Posted: Tue May 18, 2021 10:09 am Post subject: Re: is this a sand seal and can I remove it |
pulled off the pulley. This isnt machined in right? Just slip on seal?
Posted: Tue May 18, 2021 10:32 am Post subject: Re: is this a sand seal and can I remove it |
I don't have X-ray vision, it looks like one of those press in no machining ones, but until it's out nobody can be sure.
When it is out remove the spacer washer that goes on the crank before fitting the stock pulley. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue May 18, 2021 11:02 am Post subject: Re: is this a sand seal and can I remove it |
looks press in....
Posted: Tue May 18, 2021 11:32 am Post subject: Re: is this a sand seal and can I remove it |
That aluminum collar has to come out too, it's the "press in" part that holds the seal. Careful prying under the outside edge should do it, unless you can grab it with a 3 jaw puller, put the bolt back in the crank if you use a puller so you don't F up the threads. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue May 18, 2021 12:19 pm Post subject: Re: is this a sand seal and can I remove it |
Came out fairly easily.
74 Thing Samba Member
Posted: Tue May 18, 2021 12:38 pm Post subject: Re: is this a sand seal and can I remove it |
There is usually a spacer in there too when using a sand seal pulley so it does not hit the seal. You need to punch out the woodruff key then get out the spacer if going to a stock pulley with the grooves. |
Posted: Tue May 18, 2021 1:10 pm Post subject: Re: is this a sand seal and can I remove it |
yeah thats next. Cant wiggle it out with the key in place? |
Posted: Tue May 18, 2021 2:30 pm Post subject: Re: is this a sand seal and can I remove it |
Some have a slot, some don't, how's your luck at gambling in general?
Get under the outer tip of the key with a dull chisel or screwdriver, hopefully you can get it moving up before it goes in too far, that may get complicated.
Or if you have a large sharp pair of sidecutters grasp the sides of the key and pry up with the handles to lift it a bit, you may have to file off a bite mark later. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue May 18, 2021 2:46 pm Post subject: Re: is this a sand seal and can I remove it |
I have a slip in in my garage. I just threw a caliper on the end that goes into the case it’s1.980 and the pulley measures 1.845
Hope this helps _________________ 66 13 window deluxe
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs |
