Do larger wheels affect speedometer/odometer?
markf1
markf1 is offline
PostPosted: Thu May 27, 2021 5:40 am    Post subject: Do larger wheels affect speedometer/odometer? Reply with quote
We put 215 R15 BFG Ko2 on our syncro. Previously had the stock 14” wheels.
Now I’m wondering if that had an effect on the speedometer and odometer? If yes, is there something that can be done to adjust for that?
1986 Westfalia Syncro
2.1 L Waterboxer
dobryan
dobryan is offline
PostPosted: Thu May 27, 2021 5:47 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
It is the final tire diameter that affects the speedo/odo, the rim size matters not. When you change tire diameter it changes how many revolutions per mile and that affects the speedo/odo.
You can have the speedo/odo head calibrated by a specialist shop.
Dave O
The Western Syncro build
mikemtnbike
mikemtnbike is offline
PostPosted: Thu May 27, 2021 5:48 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
In short, yes.
My "adjustment" was mental. I used a speedo app on my phone to determine that my speedo is reading about 7% slow. I make the mental adjustment to the speedo and odometer readings in my head accordingly.
2020 GTI SE manual
danfromsyr
danfromsyr is offline
PostPosted: Thu May 27, 2021 5:50 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
a larger tire rolls slower at a given speed than a smaller tire.
it's only the outer diameter that matters.
pure and simple math.
215/75R15 tires have a diameter of 27.7", a section width of 8.5",
The circumference is 87.0" and they have 729 revolutions per mile
185R14 is a Metric tire with a section or tread width of 7.3 inches,
overall diameter of 25.7 inches. 185R14 tire has a circumference of 80.7 inches, making 785 revolutions per mile
while they may be only 2inches taller.
they have a 7inch greater circumference when rolled out on the road.
it WILL also effect your overall gearing.. and you will spend more time in 3rd gear in the Mtns than before.
as well as putting more strain on the transmission internals. though that largely depends on your driving habits.. DO NOT LUG THE TRANSMISSION.
down shift and keep the RPMs up when loaded up and it's slowing down.
soo next question is what is to lug?
https://www.motorauthority.com/news/1105621_heres-why-you-should-never-lug-your-engine
To start, let's talk about what it means to lug your engine. This is the term used to describe when you're puttering along in a higher gear than you need to be in and the engine is turning low RPMs. When you're cruising along in 6th but you should've downshifted into 4th about a half mile back, you are lugging your engine. Why is this bad? Engineering Explained is here to lay it out for you.
When you lug your engine, you are forcing it to work far harder than it should. Low RPMs are fine if you're just cruising or slowing down, but when you accelerate, low revs leave your engine with a gearing disadvantage.
To get your car up to speed, the engine has to work a lot harder. Engine temperature will rise, and cylinder temperature will rise. This is where things can start to go screwy.
Picture yourself on your old 10-speed road bike. You're cruising along, having shifted up into the higher gears. Suddenly you need to accelerate and when you try to turn those pedals, you find it takes a lot more effort than it would if you were in a lower gear. You are working far harder than necessary just to get that bike moving again.
In this example, you've lugged your body because you're the engine of the bike. It's not fun to do that, so why do it to your car?
those bike pedals are your transmission gears. and that extra power is pushing too hard forcing the oil out of the gears and applying too much side load to the gears forcing unnecessary wear into the bearings and bushings that hold the gears in place. this is more of a problem with the big tire and big motor crowd. they end up learning the hard and $$$$$ expensive way..
I only mention these because I know you have had recent (last year?) transmission issues that cost a fair amount already.
say after me. it's OK to downshift on hills.. Wink
Abscate wrote:
dobryan
dobryan is offline
PostPosted: Thu May 27, 2021 5:54 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
I need me a piece of pi.
Dave O
MarkWard
MarkWard is offline
PostPosted: Thu May 27, 2021 6:12 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
The Speedo face has the value for number of revolutions per mile that it should have been calibrated for.
Even calibrated for the correct rotation, larger tires can impact mpg.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Thu May 27, 2021 6:23 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
I don't know about Syncro front ends, but changing the geometry of 2WD front ends by changing tire diameter and width puts stresses on the suspension that wasn't engineered into the system. How do you feel about your balls? Do you like them? In the 2WD world, they're the first thing to suffer from taller/wider tire mania.
I also don't know about the 4WD world in general. I know that in snow or slush, you want to cut through and bite on the hard surface under that to get your gription. Wider tires float up on top. It might be the same with muck and mud for the 4WD folks who do that stuff, I don't know.
As for the speedo, again, in my 2WD world, I know the speedo's were reporting incorrectly right off the factory floor. So, will yours be closer or even further from the actual speed? I can't decide. But, I went from 195R14 at 25.5" to a 16" rim with the lowest profile I could find at he time, and got to 26.1" and my speedo is now spot on between 40 and 84 mph. Lower is off a bit, and I have not taken the trouble to see if higher is 'on or off' as I'd be in for a serious ticket... (South Dakota Interstate has an 80MPH limit)
-bobby
markf1
markf1 is offline
PostPosted: Thu May 27, 2021 6:45 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
danfromsyr wrote:
I only mention these because I know you have had recent (last year?) transmission issues that cost a fair amount already. say after me. it's OK to downshift on hills.. Wink
Thanks to you all. that's what I thought but now I understand even better.
Dan- You are right about that! However - I think our transaxle blow up was due to 300K + miles versus lugging the engine. GF is the van owner and she does almost all the driving (while I mange the navigation, music and refreshments). She's pretty good at keeping it above 3K RPM when going up hills (which we do a fair bit of due to living in the mountains).
Mainly I'm thinking about the mileage interval for maintenance like tire rotation, oil change, tune up. We are getting ready to d o al that for the first time since putting on the new 15" wheels/tires.
729 revolutions per mile with the 15" wheels versus 785 revolutions per mile with the 14" is a difference of about 7.5%. So - I'm thinking if the odometer is showing 3K since last oil change/tire rotate that really = 2,775. Not that big of a diff but good to know. Also going to skew the gas mpg numbers I've been keeping track of as part of my co-pilot gig.
Thanks for all the helpful info, It would be nice to have the speedo and odo calibrated at a specialty shop but I doubt we will be able to find such a shop anywhere near us and I think we can get along OK doing the mental conversion.
2.1 L Waterboxer
markf1
markf1 is offline
PostPosted: Thu May 27, 2021 6:48 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
bobbyblack wrote:
How do you feel about your balls? Do you like them?-bobby
Very Happy
2.1 L Waterboxer
MarkWard
MarkWard is offline
PostPosted: Thu May 27, 2021 7:36 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
There is a company in Ft Lauderdale called Lauderdale Speedometer, that you could send the head to have it recalibrated. Probably not convenient. But I think you can specify the correction you'd like.
syncrodoka
syncrodoka is offline
PostPosted: Thu May 27, 2021 7:59 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
Get a speedometer app for your smartphone and see if the speed is in fact off. The factory tire size on my son's syncro reads high on the speedo.
You can buy a geared adapter to fix the speedo error but you need to know what % it is off. Getting the speedo tweaked by a pro is also an option.
markf1
markf1 is offline
PostPosted: Thu May 27, 2021 8:02 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
Thanks Mark. I just called that shop. Spoke with a super nice and knowledgeable person named Bob.
Cost $180- $230 = shipping. He says the odometer could be made somewhat more accurate but cannot really be calibrated. He could move/tweak the needle position on the speedometer and that would be more accurate but I believe he said +/- 3mph.
So... I think we just keep doing the mental math as occasionally needed. + we now know that 60 mph on the speedo is probably more like 55. I will set a gps on the dash and check speed next time we are driving the van to see how that matches up with the speedometer.
2.1 L Waterboxer
brickster
brickster is offline
PostPosted: Thu May 27, 2021 8:14 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
I often use this site to check tire specs. Looks like your tire is 751 revs/mile.
https://tiresize.com/tires/BFGoodrich/All-Terrain-TA-KO2-215-75R15.htm
markf1
markf1 is offline
PostPosted: Thu May 27, 2021 8:45 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
very cool brickster!
We are assuming the stock 14" that the speedo/odo are set for = 785 revs/mile (not sure how to verify that).
so 751 is @ 5% difference from 785.
Will still compare speedometer to phone app and/or gps on next drive.
2.1 L Waterboxer
brickster
PostPosted: Thu May 27, 2021 9:10 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
According to this handy dandy pdf (probably also here somewhere?), your original revs/mile was 820 or 798 depending on how it was equipped.
http://oldbluesblog.com/files/VanagonTireSpecs.pdf
4Gears4Tires
4Gears4Tires is offline
PostPosted: Thu May 27, 2021 9:13 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
With 27/8.5/14 tires my speedo reads about 2mph high at highway speeds. That's about perfect imo.
DuncanS
DuncanS is offline
PostPosted: Thu May 27, 2021 9:39 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
Photoshop a pic of your speedo dial and make it read correctly. Odo won't read correctly, but the speedo will.
Steve M.
Steve M. is offline
PostPosted: Thu May 27, 2021 9:43 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
Syncro correction gearing for speedometer are available.
https://www.brickwerks.co.uk/catalogsearch/result/?q=speedometer&x=0&y=0
The speedo cable comes from the front dif so it is gear driven and gears are changeable.
Steve M.
Steve M. is offline
PostPosted: Thu May 27, 2021 9:47 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
There's an Excel spreadsheet for tires sizes and gear ratios showing rpm outputs.
http://www.syncro.org/Files/syncrotireandgearratiosdd.xls
syncrodoka
PostPosted: Thu May 27, 2021 10:19 am    Post subject: Re: Do larger wheels affect speedometer/odometer? Reply with quote
Those plastic speedometer drive gears shouldn't just be swapped, they are matched to their drive gear.
