| How many amp hours of aux battery to charge a phone? |
| 8 amp hours |
0% |
[ 0 ] |
| 6 amp hours |
0% |
[ 0 ] |
| 4 amp hours |
0% |
[ 0 ] |
| 2 amp hours |
20% |
[ 1 ] |
| 1 amp hours |
80% |
[ 4 ] |
| Total Votes : 5 |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10438 Location: Orbiting San Diego
Posted: Sat Jun 05, 2021 2:59 pm Post subject: How many amp hours of aux battery to charge a phone? |
| If my iPhone 11 battery runs very low, how many amp hours of my aux battery capacity are needed to full charge it? |
kourt Samba Member
Joined: August 13, 2013 Posts: 2367 Location: Austin, TX
Posted: Sat Jun 05, 2021 4:07 pm Post subject: Re: How many amp hours of aux battery to charge a phone? |
Too many variables. What amperage is your USB charging port? Or the charger itself? Are you disabling wifi and cellular while charging?
This question is useless without details.
kourt |
SSWesty Samba Member
Joined: August 20, 2008 Posts: 735 Location: Bellevue
Posted: Sat Jun 05, 2021 4:21 pm Post subject: Re: How many amp hours of aux battery to charge a phone? |
| I think you're in the 2 amp hour range +/-1 |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5865 Location: Bemidji, MN
Posted: Sat Jun 05, 2021 4:31 pm Post subject: Re: How many amp hours of aux battery to charge a phone? |
iPhone 11 batteries are ~3100mAH. so... figure a charge conversion efficiency of a conservative 60% therefore:
XmAH x .60 = 3100mAH
XmAH = 5100mAH or 5.1AH
that's for a fully discharged phone batt, which few let get that low but this is all armageddon scenario figuring a dead batt and poor charge efficiency. _________________ -dan
www.thefixitworkshop.com |
Posted: Sat Jun 05, 2021 5:01 pm Post subject: Re: How many amp hours of aux battery to charge a phone? |
I didn't ask how long it would take, just how much energy would be needed from the aux battery. The phone battery only holds a certain amount of energy and that is roughly how much must come from the aux battery. I realize there losses and some small variables.
Mark
| kourt wrote: |
kourt |
Posted: Sat Jun 05, 2021 6:43 pm Post subject: Re: How many amp hours of aux battery to charge a phone? |
You missed a key aspect which is the relative voltages of the 2 batteries in question. That puts your 5.1ah number way off, too high.
I'd say your efficiency assumptions are off too, but don't know that for certain.
Mark
| DanHoug wrote: |
that's for a fully discharged phone batt, which few let get that low but this is all armageddon scenario figuring a dead batt and poor charge efficiency. |
kamzcab86 Samba Moderator
Posted: Sat Jun 05, 2021 6:49 pm Post subject: Re: How many amp hours of aux battery to charge a phone? |
I don't have an iPhone, but I do have a USB amp meter in my van. I think my Android is something like 1.3 amps... I'll double-check when I get home next week. _________________ ~Kamz
2016 Golf GTI S
Sodo Samba Member
Joined: July 06, 2007 Posts: 10741 Location: Western WA
Posted: Sat Jun 05, 2021 7:58 pm Post subject: Re: How many amp hours of aux battery to charge a phone? |
For $13 you can read how many mAh passed thru this device.
a "USB Meter" on Amazon
The USB outlet adds some losses but it's probably not much different than the power that departed your aux battery. _________________
....KTMs, GasGas, SPOT mtb |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 24217 Location: NYC/Upstate/ROW
Posted: Sun Jun 06, 2021 4:49 am Post subject: Re: How many amp hours of aux battery to charge a phone? |
It took more energy to makes these posts than the energy in a phone.
Just looking at my battery meter, it charged from 2100-2300 to full cap last night ona 1 amp brick at 5 volts, thatโs 10 watt hours
So fir your 12 volt battery, thatโs less than 1 amp hour
Itโs marginally on par with the self discharge rate of a flooded lead scid battery! _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
Posted: Sun Jun 06, 2021 6:51 am Post subject: Re: How many amp hours of aux battery to charge a phone? |
| crazyvwvanman wrote: |
Mark
| DanHoug wrote: |
ack!! you're right!! need to equivalent everything to watt-hours, which accounts for the voltage diff. oops! _________________ -dan
jimf909 Samba Member
Posted: Sun Jun 06, 2021 7:09 am Post subject: Re: How many amp hours of aux battery to charge a phone? |
Mark
| DanHoug wrote: |
As best as I can tell, iPhone 11 batteries are 3.7 volts and 3100 mAH so charging one from zero will consume 11.5 watt hours or .9 amps from your aux battery assuming it's @ 12.7 volts. _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
Posted: Sun Jun 06, 2021 3:03 pm Post subject: Re: How many amp hours of aux battery to charge a phone? |
I think you meant to say .9 amphours so I'll agree, plus a little more for efficiency losses.
What meager info I have found for car charger efficiency indicates a 5% to 10% loss, far less than many home wall chargers waste.
Mark
| jimf909 wrote: |
As best as I can tell, iPhone 11 batteries are 3.7 volts and 3100 mAH so charging one from zero will consume 11.5 watt hours or .9 amps from your aux battery assuming it's @ 12.7 volts. |
Posted: Sun Jun 06, 2021 4:30 pm Post subject: Re: How many amp hours of aux battery to charge a phone? |
so, Mark.... what's the application for determining the rilly small demand? curiousity? running an array on the edge? off grid budget balance? inquiring minds and all that. _________________ -dan
