VolksVelo Samba Member
Joined: April 21, 2020 Posts: 138 Location: Portland, OR
Posted: Thu Apr 22, 2021 9:49 pm Post subject: EVC / rear spray hose |
It is about two feet long and a bit hard to pull out. Is the length about right? Thanks |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22677 Location: NYC/Upstate/ROW
Posted: Fri Apr 23, 2021 3:43 am Post subject: Re: EVC / rear spray hose |
Xevin is forbidden from posting to this thread... _________________ .ssS! |
Posted: Fri Apr 23, 2021 2:13 pm Post subject: Re: EVC / rear spray hose |
Abscate wrote: |
Xevin is forbidden from posting to this thread... |
Hmm... I don't understand. |
MrPulldown Samba Member
Joined: September 08, 2020 Posts: 649 Location: Truckee
Posted: Fri Apr 23, 2021 2:49 pm Post subject: Re: EVC / rear spray hose |
VolksVelo wrote: |
Abscate wrote: |
Probably an inside joke with another member.
I recall mine being about 2 feet long, but now it too is very hard to pull out.
If you remove the electrical panel you can see the hose. There is probably a twist/kink there. _________________ 2002 EVC |
Posted: Fri Apr 23, 2021 3:34 pm Post subject: Re: EVC / rear spray hose |
Thanks Mr Pullout, I'm feeling so much better 😎
Yeah, after rereading my post it does sound weird...
Posted: Sat Apr 24, 2021 3:40 am Post subject: Re: EVC / rear spray hose |
A bit of silicone spray on the outside of the hose might ease the friction a bit? _________________ .ssS! |
TFB777 Samba Member
Joined: February 12, 2021 Posts: 35 Location: Camas, Washington
Posted: Tue Jun 15, 2021 8:29 am Post subject: Re: EVC / rear spray hose |
Oh boy, did you set yourself up for this one brother!!! LOL! In all seriousness though, the spray hose on my van was becoming really brittle and the spray head clogged as well - despite repeated cleaning. Because the brilliant Winnebago designers ran the hose and coupling right above the rear fuse panel, a leaking hose could cause a nasty short. I found an identical sprayer on amazon for like $25 but with a longer hose so I replaced mine for safety's sake. I use the sprayer a lot at the beach so it was a must do for me. Advice: while I managed to replace mine by just going through the fuse panel area, it was a big pain to do so. It would be much easier to remove the entire plastic molding. |
Posted: Tue Jun 15, 2021 9:41 am Post subject: Re: EVC / rear spray hose |
Thanks TFB777, I need to work on mine soon. We were in scorching Southern Utah recently and couldn't comfortably using it. It's so hard to pullout I was afraid it's gonna break...
Do you have the link to that hose on Amazon? Many thanks! |
TFB777 Samba Member
Posted: Tue Jun 15, 2021 3:16 pm Post subject: Re: EVC / rear spray hose |
Many thanks! |
sgirard Samba Member
Joined: September 18, 2014 Posts: 93 Location: Spokane, WA
Posted: Tue Jun 15, 2021 4:07 pm Post subject: Re: EVC / rear spray hose |
I recently replaced mine. Original sprayer (or at least the one installed when I got the van) was ~3 feet long. It always felt too short, but I think it was pretty much pulling out all the way; maybe a little loop. Most of the ones you see for sale, including the one I replaced with, which may be the same as the one linked above, are ~4 feet long. That extra foot or so makes a huge difference in my opinion.
I also replaced the MIP fitting that the sprayer hose attaches to, which was plastic and I think the cause of a small leak I discovered while back there - probably due to being overtightened or something. I'm fairly certain this is what I replaced it with: https://www.homedepot.com/p/Everbilt-1-2-in-Barb-x-3-8-in-MIP-Brass-Adapter-Fitting-800199/300096744
Much happier with the sprayer now, although I just left the existing "receptacle" and although the new sprayer sits in there fine I recently noticed it has just enough room to vibrate when the the pump runs, making the pump seem louder than it really is. I haven't come up with a good way to dampen that vibration yet. Maybe a rubber gasket or something. _________________ 95 EVC
Previous:
64/71/72/82
Intro |
