liquidrush Samba Member
Posted: Sat Jun 19, 2021 11:39 am Post subject: Just did the walk of shame. |
You know, when you're adjusting valves and go to start the engine up forgetting that the ratchet is still on the alternator nut. Yea, that one. I can't be the only one who's checked that box. |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Sat Jun 19, 2021 11:44 am Post subject: Re: Just did the walk of shame. |
well I can honnestly say no I have never done that!!! it was a aluminum AN rench....  |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11093 Location: Oregon
Posted: Sat Jun 19, 2021 12:20 pm Post subject: Re: Just did the walk of shame. |
I left a 30mm wrench on the crank pulley bolt a few years ago. Started the engine and unthreaded the pulley bolt in 1 second.
It's not a shame to admit when you made an error that doesn't hurt anything or anyone.
The shame comes. If you don't learn from your error! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Sat Jun 19, 2021 12:32 pm Post subject: Re: Just did the walk of shame. |
Loud, isn't it?  _________________ 1960 Ragtop w/Semaphores "Inga" |
Shane Tuttle Samba Member
Joined: February 02, 2011 Posts: 173 Location: Arlee, Montana
Posted: Sat Jun 19, 2021 1:02 pm Post subject: Re: Just did the walk of shame. |
Admitting you have will likely help prevent someone else from doing it.
IMO, that's one reason why this board exists. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33091 Location: Hot Arizona
Posted: Sat Jun 19, 2021 1:12 pm Post subject: Re: Just did the walk of shame. |
liquidrush wrote: |
Just did the walk of shame |
Heck, even Mrs. Cusser got over that !!!!
liquidrush wrote: |
I've NEVER done that, ABSOLUTELY. Because my VWs have generators. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
MrWhoopee Samba Member
Joined: October 24, 2005 Posts: 178 Location: Shingletown, CA
Posted: Sat Jun 19, 2021 1:15 pm Post subject: Re: Just did the walk of shame. |
Yes, but have you ever attempted to break the axle nut loose by pulling the bus forward with the cheater wedged against the ground, only to realize, as the back end rises off the ground, that you should have backed up?
Never happened to me, but someone told me...... _________________ Craig ('51 WASP)
Rosie ('63 Double Cab) |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35900 Location: Conejo Valley, CA
Posted: Sat Jun 19, 2021 1:59 pm Post subject: Re: Just did the walk of shame. |
liquidrush wrote: |
Yep, it's been done before.
https://www.thesamba.com/vw/forum/viewtopic.php?t=740788 |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2888 Location: HdG, MD & NJ
Posted: Sat Jun 19, 2021 3:25 pm Post subject: Re: Just did the walk of shame. |
I turn at the crank and never just leave the wrench on between adjustments. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
earthquake Samba Member
Joined: January 10, 2008 Posts: 4001 Location: SANDY VALLEY, NEVADA
Posted: Sat Jun 19, 2021 3:28 pm Post subject: Re: Just did the walk of shame. |
I left the wrench on the draw bar of my mill once, never done it again.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Sat Jun 19, 2021 3:40 pm Post subject: Re: Just did the walk of shame. |
earthquake wrote: |
eQ |
For me that was lesson #1 on day 1 in the machine shop - NEVER under any circumstances leave the key in the chuck of the lathe. Your example is basically the same thing. That’ll wake you up really quick. _________________ 1965 Beetle sedan
Click to view image |
KTPhil  Samba Member
Posted: Sat Jun 19, 2021 3:52 pm Post subject: Re: Just did the walk of shame. |
Matthew wrote: |
earthquake wrote: |
eQ |
For me that was lesson #1 on day 1 in the machine shop - NEVER under any circumstances leave the key in the chuck of the lathe. Your example is basically the same thing. That’ll wake you up really quick. |
From the link I posted above... true story:
Quote: |
I had a jr. high metal shop teacher who terrorized students mercilessly. One of his diatribes was about poor Johnny who left the chuck key on the lathe and hit the power. He said it tore through his hand on its way to the far concrete wall. His last words were, "Please tell the students to never leave a chuck key in the chuck!" and then died from blood loss. Shop teacher had dark red paint on the floor for realism. I smugly thought the story was BS.
That is, until a few days later I noticed a real chuck key embedded into the top of the 20 ft high concrete wall in line with the radial direction of the chuck... for real! |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2186 Location: Laurel Canyon, CA
Posted: Sat Jun 19, 2021 4:35 pm Post subject: Re: Just did the walk of shame. |
The walk of shame is the actual act of walking and getting whatever just got flung across the shop...
That's how we got that expression _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
FarmerBill  Samba Member
Joined: July 25, 2017 Posts: 866 Location: New England
Posted: Sat Jun 19, 2021 5:29 pm Post subject: Re: Just did the walk of shame. |
I knew a Saab mechanic that told me the factory procedure for breaking the crank pully loose on the 900 was to put a breaker bar and socket on the bolt, brace it against the body, and crank the starter, with the coil disconnected. He then described why that last bit was so important. |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6137 Location: CONGERS, N.Y.
Posted: Sat Jun 19, 2021 5:47 pm Post subject: Re: Just did the walk of shame. |
I had 78 non-turbo diesel rabbit that needed a head gasket. At 22 to 1 compression I knew there was no combustion chamber, the thickness of the gasket changed the compression.
Put in the new gasket, turn the key and KLUNK!!! I was one tooth off on the timing belt.
Destroyed a lifter and egg shaped the lifter bore.
I learned after that - don't start the engine until you hand turn the engine and make sure you have full rotation.
Actually I fixed that head and with another 100k miles. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Posted: Sat Jun 19, 2021 6:00 pm Post subject: Re: Just did the walk of shame. |
Yep, full revolution by hand should also be done on any engine that has been upside-down for a period of time to avoid hydrolocking. Don't ask me how I know this. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4489 Location: viroqua wi.
Posted: Sun Jun 20, 2021 5:17 pm Post subject: Re: Just did the walk of shame. |
Adjusting valves on 1 and 3 then 2 and 4, fired up and oil is pouring on the floor mostly, some is landing in the 1-3 valve cover on the garage floor where I left it. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3842 Location: The Woodlands, TX
Posted: Sun Jun 20, 2021 7:26 pm Post subject: Re: Just did the walk of shame. |
I thought that was when you girl friend walked out of your dorm in the early morning to avoid being seen...lol |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4277 Location: deepest, darkest Switzerland
Posted: Mon Jun 21, 2021 5:07 am Post subject: Re: Just did the walk of shame. |
Bringing a '66 bus to the state inspection. The "expert" (that's what they call themselves) call me down into the pit... "It happens to all of us", he says, as he points out the 17mm wrench sitting on the steering box adjustment nut.
And you haven't really felt the full painful depth of complete automotive shame...until you drive off from the gas station, with the nozzle still in the filler neck. It's not as bad as you would imagine, But the shame, the horrible realization that this will forever be part of my life story, the unspeakable level of embarrassment, the blank look on my face it's all something I will never manage to forget...
Hmmm...there is catharsis in confession;...i feel much better after getting that off my chest.  |
