Zwentibold Samba Member
Joined: December 30, 2009 Posts: 16 Location: Rothenburg, Germany
Posted: Sun Jun 19, 2011 4:14 am Post subject: |
Hello Mark,
nice to "see" you again.
I notice you still don't have any cover plates in the engine compartment to keep the heat off the fuel pump, carburator, ignition etc... Didn't you have any problems on a longer distance ride so far?
In the original engine compartment the exhaust pipes and cylinderheads are separated from the rest to be directly cooled by the air-flow of the fan. And to get the heat straight off the engine.
Sorry, I don't have pictures of the cover plates alone...
For some reason, those special cover plates are not mentioned in the spare parts list. Maybe they are supposed to belong to the body itself, like mudguards, bumper bar, gearbox cover below the rear seats and so on...
My special advice: try to find an adequate passenger  |
Mr Slug Samba Member
Joined: December 06, 2009 Posts: 143 Location: United Kingdom
Posted: Wed Jun 22, 2011 3:58 am Post subject: |
And great to 'see' you again my friend - so helpful in the past, and still continue with your experience and advice.
I have not as yet made or fitted those panels - I do notice that the engine gets hot and it is yet another job that has to be tackled.
Thank you for those pictures - they will help enormously.
Thanks again - regards, Mark. |
BNMike Samba Member
Joined: November 12, 2009 Posts: 334 Location: Hot Springs, SD
Posted: Sun Jun 26, 2011 2:10 am Post subject: |
Thanks Mike - I have it.
A really nice interesting little film - well worth buying one if you don't have it and like your classic VWs |
ESSGAR Samba Member
Joined: January 20, 2011 Posts: 99 Location: el paso, tx
Posted: Thu Jun 30, 2011 12:31 am Post subject: |
im gonna build a church to your job...demet that freaking awesome..nice job ... kongratulation _________________ <<VW FEVER>>
76 THING
6?? Ragtop BUG |
BNMike Samba Member
Posted: Fri Jul 08, 2011 5:45 pm Post subject: |
[quote="Mr Slug
A really nice interesting little film - well worth buying one if you don't have it and like your classic VWs[/quote]
I brought the disk along to my "away from home terminal" today. It is pretty slick. One of the "animations" shows all the sections of the schwimmer drive train, one at a time, being "built up" and turning.
Someone who was prepared to fabricate the cases would have most all the info needed to do the four-wheel drive
All-in-all, a worthwhile purchase
BNMike |
Posted: Thu Aug 04, 2011 9:23 am Post subject: |
| Thanks Mike, |
fergal69 Samba Member
Joined: September 14, 2012 Posts: 1 Location: Tipton, West Midlands
Posted: Fri Sep 14, 2012 12:26 pm Post subject: |
| Mr Slug wrote: |
Even if I were lucky enough to buy a real one, I think a replica has its place. The real ones are so expensive as to be out of reach of the regular
enthusiasts. I understand there is a company in the United States that make replica Kubels, and are going to start making Schwimmers. I'd like to do a similar thing here in the UK - make replica 166s available either complete, or in a sort of self build/self finish kit form.
I understand that the US built replica 166s, will also be 2 wheel drive.
Thanks again, Regards Mr Slug. |
Just come across this site whilst looking for a replica schwimmwagen.
Amazing build of the VW166 - wish I was that clever in fabricating the body.
However, if you are to manufacture a tub, then I for one, would be interested, as that is the part I would struggle with & I would prefer a steel tub to a fibreglass one. |
tstracy39 Samba Member
Joined: May 14, 2008 Posts: 3295 Location: Seattle, WA
54bugn Samba Member
Joined: April 28, 2005 Posts: 548 Location: Parksville BC, Canada
Posted: Sat Aug 07, 2021 4:21 pm Post subject: Re: Beetle - Schwimmer replica |
Hello Mr. Slug, very well done and an inspiration for sure. I just purchased one of the US made fiberglass Schwimmwagen bodies, and I am wondering which plastic model it was you used to take your measurements from? I see a picture of it near the start of this thread, but wonder if you know which size scale etc.
Appreciate the help.
CHeers,
Mike _________________ OFACK Founding member
"Schwing wrote:
You either have to be too cheap to hire a pro or determined to do it yourself, but it helps to be both!"
54 European Sedan deluxe
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=414940 |
