iamnotatwork Samba Member
Joined: August 21, 2018 Posts: 162 Location: Oak Harbor, WA
Posted: Thu Sep 23, 2021 8:28 am Post subject: Re: 69 Squareback Restomod |
Bob, I have the rings from the donor pad. I don't yet see the best way to integrate and make it look nice. Do you have a link for Rob's Roadster? I'm not familiar...
Thanks!
Bobnotch wrote: |
As for the gauge rings, you might want to find a dash pad that's basically junk, and get the rings out of it. That's what we did for Rob's Roadster when we went steel with the dash.
I hope this helps. |
_________________ 1967 Bug "Giblet"
1969 Squareback (undergoing restoration) "The Pickleback" |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22440 Location: Kimball, Mi
Posted: Thu Sep 23, 2021 1:31 pm Post subject: Re: 69 Squareback Restomod |
Here's a link to his build, but it's missing a lot of the early build of it. Some pics of the steel dash are in my gallery though.
https://www.thesamba.com/vw/forum/viewtopic.php?t=596485&pile of bleached bones
I included some of my gallery pics. The humps over the gauges are re-worked T-1 engine tin parts. The rings got trimmed on the outside a little to help them fit better.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Thu Sep 23, 2021 1:42 pm Post subject: Re: 69 Squareback Restomod |
Metal dash looks good, but the easiest is to have your padded dash upholstered with whatever you pick out.
Dieselgirl had her sweet squareback dash upholstered with imitation alligator skin! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4925 Location: Southern AB
Posted: Thu Sep 23, 2021 2:39 pm Post subject: Re: 69 Squareback Restomod |
another alternative on the dash would be laying up 3-4 layers of fiberglass cloth on the metal dash, pop it off, use that as a base, and then build it up with foam, shaping it, and wrapping it with a 4 way stretch vinyl.
That could be a cool solution _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Tue Sep 28, 2021 9:22 am Post subject: Re: 69 Squareback Restomod |
Thanks for all the suggestions and photos! I'm going to think on this... _________________ 1967 Bug "Giblet"
Posted: Thu Dec 09, 2021 4:41 pm Post subject: Re: 69 Squareback Restomod |
While I think on that, some other progress was made...
We made an engine test stand:
That is version 1 and actually worked correctly on the first try. Woohoo!
We ran in Brian's bug engine first... it's crooked as this photo was taken before we drilled a new pin in the stand...
Next, I needed a gauge holder and tried to make one out of the radio bracket. I roached the first one but got the second one ok!
Second voltmeter will actually be oil temp.
TheGrafs Samba Member
Joined: May 07, 2012 Posts: 239 Location: Utica, New York
Posted: Thu Dec 09, 2021 8:30 pm Post subject: Re: 69 Squareback Restomod |
Hey brother! This is some good stuff! I enjoyed going through all you have done so far! _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Youtube: GrafsGarage3
Instagram: GrafsGarage |
Posted: Thu Jan 06, 2022 9:49 am Post subject: Re: 69 Squareback Restomod |
Thanks TheGrafs!
While I wait for this to dry:
We're going to get version 2 of the test stand going. I made a box-thing:
Added gauges, switches, and lights:
Fuel pump and oil filter mounted to stand:
Ready to go!
