crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9941 Location: Orbiting San Diego
Posted: Wed Oct 13, 2021 6:52 am Post subject: Re: Official lazy person's stupid question thread |
He said it was a 1.9 NA which is a diesel motor commonly used to upgrade a dead 1.6 NA in 82 and 83 diesel vans.
Mark |
Skippa Samba Member
Joined: June 13, 2020 Posts: 2 Location: Alexandria, VA
Posted: Wed Oct 13, 2021 10:25 am Post subject: Re: Official lazy person's stupid question thread |
djkeev wrote: |
The oil pump is driven by mating into a slot on the cam gear.
If you didn't ensure a proper engagement, you weren't pumping oil, or pumping it very inefficiently.
1.9 in an 82?
1.9 did not appear until 83.
Someone may have modified your unit at some point in the past?
Or you have an 83 with a PRODUCTION date of late 82 which is an 83 MODEL year.
Dave |
Dave, Thanks for the reply. You are correct, the 1.9l was a replacement engine for the original 1.6. That was done when I got the van which is why I’m trying to figure out what went wrong. I’m happy to put another 1.9 in but obviously want to keep it running longer between blowups. Can I ask a follow up “stupid question”? Is there a good way to check how well the oil pump is circulating oil in case I have to repair another one? It appeared engaged properly and was seated as far in the slot as originally (based on markings on the pump). The oil light was not on. Thanks again! |
Posted: Wed Oct 13, 2021 2:20 pm Post subject: Re: Official lazy person's stupid question thread |
If the oil was not circulating you would not have oil pressure. I doubt too that the engine would have died as quickly as it did if the failure was caused by just a lack of oil since start up. I have seen cold engines run a long time with no oil flow. |
Diy2k Samba Member
Posted: Wed Oct 13, 2021 3:04 pm Post subject: Re: Official lazy person's stupid question thread |
If the water pump is a rattlin do I really need to change it? _________________ 1987 VW Vanagon Wolfsburg Weekender
2012 Ford Transit Connect Xlt |
Posted: Wed Oct 13, 2021 3:12 pm Post subject: Re: Official lazy person's stupid question thread |
Diy2k wrote: |
If the water pump is a rattlin do I really need to change it? |
No reasons to change it if you don't mind experiencing an engine failure. |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Wed Oct 13, 2021 9:45 pm Post subject: Re: Official lazy person's stupid question thread |
Oil pressure light in the instrument cluster.
1- Ignition on, engine off: light blinks
2- Engine on: Light turns off
(All good so far. I leave the engine on for 10 seconds.)
3- I turn the engine off, and switch the ignition on: light does not blink
Should the light blink at step 3?
If I wait a minute or two and start over, light blinks as it should. Is my oil pressure switch tired? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Wed Oct 13, 2021 11:02 pm Post subject: Re: Official lazy person's stupid question thread |
VicVan wrote: |
If I wait a minute or two and start over, light blinks as it should. Is my oil pressure switch tired? |
It takes a while for the cold thick oil to drain from the oil pressure switch, so this is pretty normal and expected. |
VicVan Samba Member
Posted: Thu Oct 14, 2021 9:27 am Post subject: Re: Official lazy person's stupid question thread |
Perfect! Thanks.
Took me a while to fix it, I had a damaged PCB (the one hiding behind the tach), AND a bad wire between the oil pressure switch and the T2 connector in the engine bay. That's when the diagnosis charts in the Bentley come in real handy. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Mk3rattlebox Samba Member
Posted: Fri Oct 15, 2021 7:40 am Post subject: Re: Official lazy person's stupid question thread |
Long time lurker... have a few questions regarding an auto (090) 86 westy...
1. Pinion cover - took mine off to replace the two seals seperating the transaxle from the valve body. Is there any requirement for checking play or anything of the like if i just removed the differential pinion cover to replace the seals?
2. The two seals are back to back with the 'lip' facing out. How do you get the 2nd seal into position without damaging the lip?
Thanks |
Posted: Fri Oct 15, 2021 6:36 pm Post subject: Re: Official lazy person's stupid question thread |
Mk3rattlebox wrote: |
Thanks |
Not real sure what you are asking. To replace the seals, most people would drop the transaxle and separate the two boxes. A few might try and do it by only removing the automatic section, but I don't think there was be much in the way of time savings by doing so. Any way to go at it you have to be real careful not to damage the oil pump drive shaft and/or the oil pump.
If the back to back seals are old and worn enough to leak, the governor shaft seal and the inner pinion seal may also be due for replacement, and don't forget the torque converter seal. |
jb20thae Samba Member
Posted: Fri Oct 15, 2021 8:44 pm Post subject: Re: Official lazy person's stupid question thread |
delete
VicVan Samba Member
Posted: Sat Oct 16, 2021 1:17 pm Post subject: Re: Official lazy person's stupid question thread |
Can I store a Dometic fridge on its side?
Someone gave me a spare fridge, which I'm keeping for parts. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sat Oct 16, 2021 3:03 pm Post subject: Re: Official lazy person's stupid question thread |
VicVan wrote: |
Someone gave me a spare fridge, which I'm keeping for parts. |
You probably can, BUT do not sit it upright and turn it on right away. Better to let it sit upright overnight before trying to start it. The freon/oil has to drain back into the compressor before starting. _________________ This free advice is worth exactly what you paid for it.
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32646 Location: Reading Pennsylvania
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sun Oct 17, 2021 8:08 am Post subject: Re: Official lazy person's stupid question thread |
djkeev wrote: |
Steve M. wrote: |
VicVan wrote: |
You probably can, BUT do not sit it upright and turn it on right away. Better to let it sit upright overnight before trying to start it. The freon/oil has to drain back into the compressor before starting. |
Aren't these still ammonia based? |
Yup - no compressor, no freon. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Sat Oct 23, 2021 10:07 pm Post subject: Re: Official lazy person's stupid question thread |
Anyone know if vw and/or audi wheel covers will fit modern mercedes steel wheels? |
VicVan Samba Member
Posted: Sun Oct 24, 2021 7:25 pm Post subject: Re: Official lazy person's stupid question thread |
Jake de Villiers wrote: |
djkeev wrote: |
Steve M. wrote: |
VicVan wrote: |
Yup - no compressor, no freon. |
Does that change anything regarding the ability to stock it on its side? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Mon Oct 25, 2021 3:49 am Post subject: Re: Official lazy person's stupid question thread |
VicVan wrote: |
djkeev wrote: |
Steve M. wrote: |
VicVan wrote: |
Does that change anything regarding the ability to stock it on its side? |
Yes. I was thinking of later model fridges with a compressor. Compressor is a spinning motor so you want the oils to drain back down into the spinning motor section.
The ammonia based older version does not have the compressor so you can put it on it's side easy enough, but I would still wait a bit before starting it. _________________ This free advice is worth exactly what you paid for it.
VicVan Samba Member
Posted: Mon Oct 25, 2021 12:25 pm Post subject: Re: Official lazy person's stupid question thread |
Steve, I have a 1990 Westy, with the dometic RM-182b, which I believe is the last version they installed. I don't believe there's a compressor in there. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Mon Oct 25, 2021 12:32 pm Post subject: Re: Official lazy person's stupid question thread |
Steve M. wrote: |
VicVan wrote: |
djkeev wrote: |
Steve M. wrote: |
VicVan wrote: |
The ammonia based older version does not have the compressor so you can put it on it's side easy enough, but I would still wait a bit before starting it. |
IIRC from my childhood, ammonia refrigerators should never be laid on their sides. This would be in reference to pre 1960 refrigerators though. |
