Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
Posted: Wed Nov 10, 2021 8:07 am Post subject: Electronic Points Conversion |
Wife said get my Christmas present ordered this weekend. I want to rebuild my back up 205 M distributor and convert it to Pertronix point/condenser replacement. Thanks to VW NOS I can still get washers/shims/felts.
Is this the correct Pertonix kit for my 205 M?
http://vwparts.aircooled.net/Pertronix-Points-Replacement-Kit-SVDA-and-Vac-Adv-p/1847v.htm
I will probably get a new 00-012 coil also, but I don't think I need it.
My currently installed 205 M works great. I rebuilt it a few years back. I'll use that one to replace a Bosch 009 I rebuilt that is my emergency box back up (had to use it once to get me home from out of state). I really want to try electronic points replacement, but I like the idea of traveling around with a spare points/condenser 205 M in case the Pertronix ever gives me trouble. _________________ Repeat after me "I am smarter than metal!" |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33397 Location: Hot Arizona
Posted: Wed Nov 10, 2021 1:40 pm Post subject: Re: Electronic Points Conversion |
| Jimbug57 wrote: |
| I want to rebuild my back up 205 M distributor and convert it to Pertronix point/condenser replacement. |
I wouldn't.
| Jimbug57 wrote: |
| I really want to try electronic points replacement, but I like the idea of traveling around with a spare points/condenser 205 M in case the Pertronix ever gives me trouble. |
1. Many folks with "electronic points" travel around with spare points/condenser distributor in case the "electronic distributor ever gives them trouble.
2. Many folks with points/condenser distributors DO NOT travel around with spare distributors. That includes me. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
lboos Samba Member
Joined: November 20, 2015 Posts: 456 Location: Marietta GA.
Posted: Wed Nov 10, 2021 2:48 pm Post subject: Re: Electronic Points Conversion |
Even bad points will always get you home, those with bad electronic conversion's will end up walking.
Stick with the points.  |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36271 Location: Conejo Valley, CA
Posted: Wed Nov 10, 2021 2:55 pm Post subject: Re: Electronic Points Conversion |
I'll be a contrarian, but it's based on my experiences.
I am rebuilding my engine because it overheated during the last Type 3 Invasion, due to the mechanical advance mechanism breaking internally, forcing advance to 45 degrees in 120 degree heat on the drive home.
So issue number one is that I will carry a spare distributor anywhere I go now.
Issue number two is that the constant fiddling with the points hold down screw wears out the skimpy threads on the advance plate, leading to the need for a replacement plate, which I have but it's getting harder to find.
So my plan, once the engine is broken in with a stock distributor, is to install the 123 unit (including the the FI trigger point function and a solid state vacuum advance), so I never have to work a hold down screw again, and the advance should be reliable.
But just in case, I'll carry the complete stock (points) distributor as an on-the-road spare.
Some recommend a hotter coil with a resistor in place of the stock coil when using the 123 unit, something I'll also consider when that time comes.
Airstream65 Samba Member
Joined: January 28, 2019 Posts: 172 Location: Tulsa,Ok
Posted: Wed Nov 10, 2021 2:57 pm Post subject: Re: Electronic Points Conversion |
| I recently installed the Pertronix module in my 67, So far, I am pleased. Much better starting, cold and hot. My biggest problem with new points is the lack of quality. The part that contacts the distributor seems to wear down quickly. With all that said, I will carry p& c in the frunk, just in case! |
vamram  Samba Member
Posted: Wed Nov 10, 2021 5:54 pm Post subject: Re: Electronic Points Conversion |
JimBug -
I've been using CompuFire w/my bosch DVDA for 15k miles since April 2020. ZERO ISSUES. I toyed w/points for a couple hundred miles maybe at one point, for sh*ts & grins, ditched them pretty quickly. I use one on my '74 - at least until I parked it last year to rebuild the motor and other stuff, and will again when it's on the road again.
Also, although Compufire is now owned by Pertronix, I've had nothing but heartache w/every pertronix product i've ever used - points replacment left me stranded on the side of the road, Flame Thrower coil - lasted 6 months, SVDA distributor - vac can died w/in the year, centrifugal advance mechanism by itself is pure crap. I would use a CompuFire knock-off module before buying a Pertronix.
Victor _________________ "Men are qualified for civil liberty in exact proportion to their disposition
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!! |
Cusser Samba Member
Posted: Wed Nov 10, 2021 6:31 pm Post subject: Re: Electronic Points Conversion |
"Going pointless is pointless" - The Cuss
If one does not know how to install and set points, and then check/adjust the timing - my advice is NOT to own an old Volkswagen !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80260 Location: Sneaking up behind you
Posted: Wed Nov 10, 2021 6:53 pm Post subject: Re: Electronic Points Conversion |
If you can't gap the points then who's going to adjust the valve lash? _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
johneliot Samba Member
Joined: August 29, 2005 Posts: 2195 Location: Chico, CA
Posted: Wed Nov 10, 2021 7:06 pm Post subject: Re: Electronic Points Conversion |
Here we go again. Ask 100 people and half will give you a different answer. Just do what you want. I’ve had a pertronix in my 69 for 10 years and never had a problem. All cars now have an electronic ignition. Just have AAA and who cares? _________________ John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost" |
Glenn  Mr. 010
Posted: Wed Nov 10, 2021 7:15 pm Post subject: Re: Electronic Points Conversion |
| johneliot wrote: |
| Here we go again. Ask 100 people and half will give you a different answer. Just do what you want. I’ve had a pertronix in my 69 for 10 years and never had a problem. All cars now have an electronic ignition. Just have AAA and who cares? |
My wife would care if we broke down and she had to wait an hour or so for a tow truck.
I've never heard anyone who uses points say they carry a spare distributor. But i hear many with a Pertronix say they carry one. _________________ Glenn
Member #1009
#BlueSquare
Cusser Samba Member
Posted: Wed Nov 10, 2021 8:27 pm Post subject: Re: Electronic Points Conversion |
| Glenn wrote: |
I've never heard anyone who uses points say they carry a spare distributor. But i hear many with a Pertronix say they carry one. |
THIS _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Wed Nov 10, 2021 8:48 pm Post subject: Re: Electronic Points Conversion |
Yes, that is the correct one for your distributor.
| Jimbug57 wrote: |
| My currently installed 205 M works great. I rebuilt it a few years back. I'll use that one to replace a Bosch 009 I rebuilt that is my emergency box back up (had to use it once to get me home from out of state). I really want to try electronic points replacement, but I like the idea of traveling around with a spare points/condenser 205 M in case the Pertronix ever gives me trouble. |
Instead of a complete spare distributor, you may just keep a stock set of points and condenser in the car. Removing the electronic module and reinstalling P/C doesn't take more than five to ten minutes if necessary. _________________ 1960 Ragtop w/Semaphores "Inga" |
Xevin  Samba Member
Posted: Wed Nov 10, 2021 9:16 pm Post subject: Re: Electronic Points Conversion |
What was the question?  _________________ Keep on Busin'
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
| Clatter wrote: |
Damn that Xevin...  |
| skills@eurocarsplus wrote: |
| SGKent wrote: |
goober Samba Member
Posted: Wed Nov 10, 2021 9:57 pm Post subject: Re: Electronic Points Conversion |
Go for it.
I've been running Petronix in my 205T's for over 20 years with no problems. From -20 deg F to over 100 deg F, no problem. Bumper to bumper to all day highway, no problem. I check my timing once a year, it goes nowhere, no problem.
It's not that I can't install or adjust points but who wants to? Three things in the electronic world (over the mechanical) I've yielded to:
Petronix for points
Bosch electronic voltage regulator for my generator
Electronic vibrator for my gas gauge
I still have sets of points, electro-mechanical regulators and old bi-metal strip vibrators laying around in boxes. I carry a spare distributor all timed and ready to drop in but I did the same with points.
Why fiddle around when you can be on your way in less than 5 easy minutes.
These electronic devices are not only better they make life easier. |
Posted: Wed Nov 10, 2021 10:43 pm Post subject: Re: Electronic Points Conversion |
Never had to wait an hour for a tow truck. 30 minutes at the most. _________________ John
Mark Twain
Glenn  Mr. 010
Posted: Thu Nov 11, 2021 1:31 am Post subject: Re: Electronic Points Conversion |
| mukluk wrote: |
| Jimbug57 wrote: |
Instead of a complete spare distributor, you may just keep a stock set of points and condenser in the car. Removing the electronic module and reinstalling P/C doesn't take more than five to ten minutes if necessary. |
Don't forget to bring a dwell meter and timing light since your timing will be off and you can quickly over heat the engine. _________________ Glenn
Member #1009
#BlueSquare
Meiang Samba Member
Joined: September 27, 2016 Posts: 660 Location: Perth, Western Australia
Posted: Thu Nov 11, 2021 1:45 am Post subject: Re: Electronic Points Conversion |
I installed a Magnetronic points replacement system 22 years ago. No issues. I haven't had to adjust the timing since. Just set and forget. _________________ Range Rover Sport TDV8
Honda Civic Vi Hatch |
Zundfolge1432  Samba Member
Posted: Thu Nov 11, 2021 8:50 am Post subject: Re: Electronic Points Conversion |
https://www.thesamba.com/vw/forum/viewtopic.php?t=281144&highlight=electronic+vs+points
Oh this is my favorite, just pull up a chair grab a snack and read this funny shit. All 35 pages and if you make it you’ll see nobody changed camps although the points replacement Cowboys all seem to carry spare points because on a subliminal level they know which way is less troublesome 😀
My friend Cuss has been running same points and condenser since the 70s. Although nobody will ever own up to it I suspect some of the older fellows get to the point where bending over to service a distributor becomes too much. They acquiesce to using the maintenance free way and trade off maintenance for convenience, it’s ok just own it don’t be ashamed. I’ve had points close up and make the car hard to start if fact this is one of the first things I’d check on a hard start complaint. We used to see this all the time and you could just file the points, set the gap, grease the rubbing block, oil the wick to go another couple of years. I bought a NOS SVDA about 10 years ago and just recently had to service it.
I’ve also had two outright failures of points replacement systems that gave no warning of trouble. Still for the cost you can buy multiple sets of points and condensors as opposed to one time purchase of electronic. I’m only talking about OEM distributors custom is a whole other ball game. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11132 Location: Black Forest, CO
Posted: Thu Nov 11, 2021 9:12 am Post subject: Re: Electronic Points Conversion |
| Max Welton wrote: |
| Zundfolge1432 wrote: |
| All 35 pages and if you make it you’ll see nobody changed camps |
People do tend to dig in. I'm surprised this thread hasn't been locked already.
Max |
I suspect you are right we gravitate to what is familiar and what works. Rather than lock redirect to the 35 page novel 😀 it covers the topic A to Z with style and a bit of humor. |
