Replacing injection hoses
Norma
Norma is offline
PostPosted: Sun Nov 14, 2021 5:26 pm    Post subject: Replacing injection hoses Reply with quote
I’m replacing all of my fuel lines now is it true I need to release the pressure in the injectors first.
True?
I disconnect the fuel regulator while engine is running?
Thank you.
Injected 2.0 Bay Window
3rd owner of 14 years now!
Fortunately, I was able to travel in Norma Jeanne for 1.5 years, from Eureka to Tijuana. I loved every minute❤️
aeromech
aeromech is offline
PostPosted: Sun Nov 14, 2021 6:22 pm    Post subject: Re: Replacing injection hoses Reply with quote
No no no. With the engine off just bleed off the captured fuel pressure any way you can. On the left side fuel rail there’s an 8mm bolt that can be removed for this. Place a rug under the rail and protect your eyes as you remove that plug.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Norma
Norma is offline
PostPosted: Sun Nov 14, 2021 6:59 pm    Post subject: Re: Replacing injection hoses Reply with quote
Excellent!
Thank you!
Norma
Norma is offline
PostPosted: Sun Nov 14, 2021 7:01 pm    Post subject: Re: Replacing injection hoses Reply with quote
When do I put it back in?
aeromech
aeromech is offline
PostPosted: Sun Nov 14, 2021 7:17 pm    Post subject: Re: Replacing injection hoses Reply with quote
If you mean that 8mm plug in the fuel injection manifold located between #3 and 4 you can install it immediately. Remove it to bleed off the fuel pressure and then reinstall it right away.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Norma
Norma is offline
PostPosted: Sun Nov 14, 2021 7:21 pm    Post subject: Re: Replacing injection hoses Reply with quote
Great thank you.
I purchased 11’ of Gates Barricade 4219BF.
Is that okay?
It’s 30R14.
For the 1/2” line from pump to filter, does it need to be braided?
busdaddy
busdaddy is offline
PostPosted: Sun Nov 14, 2021 7:29 pm    Post subject: Re: Replacing injection hoses Reply with quote
Avoid braided unless it's guaranteed to be Ethanol proof, the J30-R9 (or higher) stuff from your FLAPS is likely better.
Don't lose the little washer under that test port screw, things get complicated when it falls down into the abyss.
Слава Україні!
Norma
Norma is offline
PostPosted: Sun Nov 14, 2021 7:44 pm    Post subject: Re: Replacing injection hoses Reply with quote
Thank you.
I still haven’t found a diagram for that screw😌
busdaddy
busdaddy is offline
PostPosted: Sun Nov 14, 2021 7:57 pm    Post subject: Re: Replacing injection hoses Reply with quote
It's described well in your Bentley manual, pictures too.
Look or feel along the LH fuel rail (hard line that tees off into the injectors) for a ~1/2" high proturbance with an 8mm hex head on it.
Or try search, one of these threads may have a picture: https://www.thesamba.com/vw/forum/search.php?searc..._chars=200
Слава Україні!
Norma
Norma is offline
PostPosted: Sun Nov 14, 2021 7:58 pm    Post subject: Re: Replacing injection hoses Reply with quote
Found a pic on googly!
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Nov 14, 2021 8:05 pm    Post subject: Re: Replacing injection hoses Reply with quote
Be careful removing that screw. It's a fine thread going into aluminum, and has a thin aluminum washer underneath, that if lost, will cause major leaks.
Norma
Norma is offline
PostPosted: Sun Nov 14, 2021 8:22 pm    Post subject: Re: Replacing injection hoses Reply with quote
Thanks,
No worries I have some strong magnets!
Lol
Is there room for me to lay a cloth under it.
busdaddy
busdaddy is offline
PostPosted: Sun Nov 14, 2021 9:14 pm    Post subject: Re: Replacing injection hoses Reply with quote
KTPhil wrote:
......... and has a thin aluminum washer underneath,........
You might want to get some of that Google on regarding non ferrous metals and magnets. Wink
Слава Україні!
Abscate Premium Member
Abscate is offline
PostPosted: Mon Nov 15, 2021 4:24 am    Post subject: Re: Replacing injection hoses Reply with quote
Work with someone experienced on this project. You are asking questions showing you are working out if your scope on a project that can literally kill you.
We have all started there, no judgement.
Norma
Norma is offline
PostPosted: Mon Nov 15, 2021 2:34 pm    Post subject: Re: Replacing injection hoses Reply with quote
Busdaddy-
My magnet reference was a joke. Thus the lol.
I know aluminum doesn’t react to magnets.
