Wrapping Vintage Speed Exhaust ?
Page: 1, 2, 3  Next
Daddio
Daddio is offline
PostPosted: Sun Nov 14, 2021 11:18 am    Post subject: Wrapping Vintage Speed Exhaust ? Reply with quote
I'm experiencing the dreaded VS exhaust drone. Just got back from a 200 mile plus trip, at a fairly sustained speed of 60mph or 3700 rpm in my 71 Westie, the noise is just too much.
I'm running a new build 1776, CB stock heads and valves with heavy springs.
It's got the CB cheater cam and stock 34/30 Solex carb and stock air cleaner, stock heater box's and the Vintage Speed Bay Window Sport Exhaust. Great power and torque but highway travel is annoying. Has anyone tried wrapping the VS muffler to help eliminate this problem, or any other ideas?
richparker
richparker is offline
PostPosted: Sun Nov 14, 2021 11:39 am    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
Wow, I think my VS sport sounds great in my ‘71 westy at those rpms and I have a CB speced 2275cc. I got a db app for my phone and I’m at 87 db at those rpms and I think it sounds great. Even my wife thinks it’s nice, way better then a merged to quite pack.
Maybe a stock exhaust is in your future, because you’re never gonna find a performance exhaust quieter then the VS sport. I’ve been down that road before. If you do find one please post what it is and the db levels it produces. Because at 60 mph my work truck w/ stock exhaust, my personal truck w/stock and bus w/VS sport exhaust all produce 87 db in the cab.
By heavy springs do you mean dual springs?
As a side note what was your MPG with that 1776 with cheater cam and pict34?
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
richparker
PostPosted: Sun Nov 14, 2021 12:22 pm    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
Since you have basically a stock engine, maybe this will better suit your sound needs. Although if it were me, I’d add a set of IDF40s and enjoy the power and gas mileage.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
mikedjames
mikedjames is offline
PostPosted: Sun Nov 14, 2021 12:28 pm    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
I use a single quiet pack and managed to get quite a lot of sound deadening by using modern 30mm neoprene foam insulation above the engine bay, and inside the tailgate and under the rear seat. It took the inside of the bus from loud to being able to hear conversations and the stereo.
Ancient vehicles and vessels
richparker
PostPosted: Sun Nov 14, 2021 12:38 pm    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
What’s the db? What QP and what header?
I also run deadening in my engine bay. As well as all side panels inside the bus.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
Daddio
Daddio is offline
PostPosted: Sun Nov 14, 2021 2:08 pm    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
Rich,
I checked my build sheet and it only specified HD valve springs I'm pretty sure there not the doubles.
I hear very little exhaust note just a constant low pitch resonance.
I've put all new sound deadening material in the engine compartment and inside the bus.
On my old engine I was running a BugPack dual quite pack, nothing quite about it but it had the VW exhaust sound, now it sound like an old tank style gas water heater heating up.
Outside the bus the muffler is very quite at idle and city driving is not bad its just the highway speeds the sound is annoying.
I got around 20 mpg and the bus ran great.
Thanks for your help.
richparker
PostPosted: Mon Nov 15, 2021 10:39 am    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
Nice! I float in the 20 range as well.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
aeromech
aeromech is offline
PostPosted: Tue Nov 16, 2021 8:21 pm    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
Take a look at the direction your exhaust outlet is pointed. It should point aft roughly parallel with the ground. I had one from A1 Muffler that pointed down and created the sound you’re having. Solution was to cut and weld into the aft direction
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
richparker
PostPosted: Tue Nov 16, 2021 8:49 pm    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
It does not face down.
It produces 87db. What db does you’re exhaust produce at 60 mph, Aeromech?
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
aeromech
aeromech is offline
PostPosted: Tue Nov 16, 2021 8:51 pm    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
This caused excessive reverberation
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
aeromech
aeromech is offline
PostPosted: Tue Nov 16, 2021 9:01 pm    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
It's a customers bus from years ago. The point is that once installed, this $1000 exhaust created a lot of the same noise that the OP here is reporting. Just trying to help solve his problem.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
richparker
PostPosted: Tue Nov 16, 2021 9:17 pm    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
I was asking about the beetle exhaust on your bus. You say it’s the best and the quietest. I think it’s nice, but it’s definitely not a performance exhaust. Please tell us some details. What’s the db at 3500 rpm, whats the Dyno numbers. Please tell us something other then “it just sounds nice.” Because in my opinion mine sounds nice too.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
aeromech
aeromech is offline
PostPosted: Tue Nov 16, 2021 9:38 pm    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
I like my exhaust but it has nothing to do with this thread
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Wed Nov 17, 2021 5:44 am    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
Neither does the one you’ve made multiple posts about in this thread.
aeromech wrote:
in my opinion you don't know shit
aeromech
aeromech is offline
PostPosted: Wed Nov 17, 2021 9:33 am    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
Of course that one has significance. The angle of the outlet was pointd downward causing the same distinct reverb that the OP was getting in his vintage speed. Pay attention
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
VWsArent4Hippies
PostPosted: Wed Nov 17, 2021 9:37 am    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
The angle of the outlet on the OP’s exhaust does not match what you have shown. Actually none of it is similar. Pay attention.
Daddio
Daddio is offline
PostPosted: Wed Nov 17, 2021 10:50 am    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
Mine points straight back, I thought it might be too close to the bumper and it does not stick out past the bumper.
I'm going to do a db test tomorrow afternoon I'll post the results tomorrow evening.
Thanks
Daddio
Daddio is offline
PostPosted: Wed Nov 17, 2021 11:02 am    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
richparker
PostPosted: Wed Nov 17, 2021 2:20 pm    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
thread
I think it kinda does. I posted a link to you thread about it. The OP has a similar sized engine build as you and he’s complaining about exhaust noise. Since you run a stock beetle exhaust, which is said to have more flow b/c of the two exit ports and still remains quite. In this day and age we are able to download free apps to measure the noise level. As I stated above my work truck, personal truck and bus all measure at 87 db at 60 mph. What’s the db of your bus at 60 mph? Maybe it’ll be the same or maybe it’ll be a few db quieter and something the OP might want to look into.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
aeromech
aeromech is offline
PostPosted: Wed Nov 17, 2021 2:41 pm    Post subject: Re: Wrapping Vintage Speed Exhaust ? Reply with quote
Thanks for the picture OP. Hippie, kiss my ass. I was trying to help from my personal experience. You should try it sometime
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Page: 1, 2, 3  Next
