Daddio Samba Member
Joined: June 23, 2007 Posts: 71 Location: Funkey Town Tx.
Posted: Sun Nov 14, 2021 11:18 am Post subject: Wrapping Vintage Speed Exhaust ? |
I'm experiencing the dreaded VS exhaust drone. Just got back from a 200 mile plus trip, at a fairly sustained speed of 60mph or 3700 rpm in my 71 Westie, the noise is just too much.
I'm running a new build 1776, CB stock heads and valves with heavy springs.
It's got the CB cheater cam and stock 34/30 Solex carb and stock air cleaner, stock heater box's and the Vintage Speed Bay Window Sport Exhaust. Great power and torque but highway travel is annoying. Has anyone tried wrapping the VS muffler to help eliminate this problem, or any other ideas? |
richparker Samba Member
Joined: November 24, 2011 Posts: 7540 Location: Durango, CO
Posted: Sun Nov 14, 2021 11:39 am Post subject: Re: Wrapping Vintage Speed Exhaust ? |
Wow, I think my VS sport sounds great in my ‘71 westy at those rpms and I have a CB speced 2275cc. I got a db app for my phone and I’m at 87 db at those rpms and I think it sounds great. Even my wife thinks it’s nice, way better then a merged to quite pack.
Maybe a stock exhaust is in your future, because you’re never gonna find a performance exhaust quieter then the VS sport. I’ve been down that road before. If you do find one please post what it is and the db levels it produces. Because at 60 mph my work truck w/ stock exhaust, my personal truck w/stock and bus w/VS sport exhaust all produce 87 db in the cab.
By heavy springs do you mean dual springs?
As a side note what was your MPG with that 1776 with cheater cam and pict34? _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3340 Location: Hamble, Hampshire, UK
Posted: Sun Nov 14, 2021 12:28 pm Post subject: Re: Wrapping Vintage Speed Exhaust ? |
I use a single quiet pack and managed to get quite a lot of sound deadening by using modern 30mm neoprene foam insulation above the engine bay, and inside the tailgate and under the rear seat. It took the inside of the bus from loud to being able to hear conversations and the stereo. _________________ Ancient vehicles and vessels
Posted: Sun Nov 14, 2021 12:38 pm Post subject: Re: Wrapping Vintage Speed Exhaust ? |
mikedjames wrote: |
I use a single quiet pack and managed to get quite a lot of sound deadening by using modern 30mm neoprene foam insulation above the engine bay, and inside the tailgate and under the rear seat. It took the inside of the bus from loud to being able to hear conversations and the stereo. |
What’s the db? What QP and what header?
I also run deadening in my engine bay. As well as all side panels inside the bus. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Daddio Samba Member
Posted: Sun Nov 14, 2021 2:08 pm Post subject: Re: Wrapping Vintage Speed Exhaust ? |
Rich,
I checked my build sheet and it only specified HD valve springs I'm pretty sure there not the doubles.
I hear very little exhaust note just a constant low pitch resonance.
I've put all new sound deadening material in the engine compartment and inside the bus.
On my old engine I was running a BugPack dual quite pack, nothing quite about it but it had the VW exhaust sound, now it sound like an old tank style gas water heater heating up.
Outside the bus the muffler is very quite at idle and city driving is not bad its just the highway speeds the sound is annoying.
I got around 20 mpg and the bus ran great.
Thanks for your help. |
Posted: Mon Nov 15, 2021 10:39 am Post subject: Re: Wrapping Vintage Speed Exhaust ? |
Daddio wrote: |
I got around 20 mpg and the bus ran great. |
Nice! I float in the 20 range as well. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17660 Location: San Diego, California
Posted: Tue Nov 16, 2021 8:21 pm Post subject: Re: Wrapping Vintage Speed Exhaust ? |
Take a look at the direction your exhaust outlet is pointed. It should point aft roughly parallel with the ground. I had one from A1 Muffler that pointed down and created the sound you’re having. Solution was to cut and weld into the aft direction _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Tue Nov 16, 2021 8:49 pm Post subject: Re: Wrapping Vintage Speed Exhaust ? |
It does not face down.
It produces 87db. What db does you’re exhaust produce at 60 mph, Aeromech? _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Posted: Tue Nov 16, 2021 8:51 pm Post subject: Re: Wrapping Vintage Speed Exhaust ? |
This caused excessive reverberation
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Tue Nov 16, 2021 9:01 pm Post subject: Re: Wrapping Vintage Speed Exhaust ? |
It's a customers bus from years ago. The point is that once installed, this $1000 exhaust created a lot of the same noise that the OP here is reporting. Just trying to help solve his problem. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Tue Nov 16, 2021 9:17 pm Post subject: Re: Wrapping Vintage Speed Exhaust ? |
I was asking about the beetle exhaust on your bus. You say it’s the best and the quietest. I think it’s nice, but it’s definitely not a performance exhaust. Please tell us some details. What’s the db at 3500 rpm, whats the Dyno numbers. Please tell us something other then “it just sounds nice.” Because in my opinion mine sounds nice too. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Posted: Tue Nov 16, 2021 9:38 pm Post subject: Re: Wrapping Vintage Speed Exhaust ? |
I like my exhaust but it has nothing to do with this thread _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3081 Location: The Bull City
Posted: Wed Nov 17, 2021 5:44 am Post subject: Re: Wrapping Vintage Speed Exhaust ? |
aeromech wrote: |
I like my exhaust but it has nothing to do with this thread |
Neither does the one you’ve made multiple posts about in this thread. _________________
aeromech wrote: |
in my opinion you don't know shit |
Posted: Wed Nov 17, 2021 9:33 am Post subject: Re: Wrapping Vintage Speed Exhaust ? |
VWsArent4Hippies wrote: |
aeromech wrote: |
Neither does the one you’ve made multiple posts about in this thread. |
Of course that one has significance. The angle of the outlet was pointd downward causing the same distinct reverb that the OP was getting in his vintage speed. Pay attention _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Wed Nov 17, 2021 9:37 am Post subject: Re: Wrapping Vintage Speed Exhaust ? |
aeromech wrote: |
aeromech wrote: |
Of course that one has significance. The angle of the outlet was pointd downward causing the same distinct reverb that the OP was getting in his vintage speed. Pay attention |
The angle of the outlet on the OP’s exhaust does not match what you have shown. Actually none of it is similar. Pay attention. _________________
aeromech wrote: |
Daddio Samba Member
Posted: Wed Nov 17, 2021 10:50 am Post subject: Re: Wrapping Vintage Speed Exhaust ? |
Mine points straight back, I thought it might be too close to the bumper and it does not stick out past the bumper.
I'm going to do a db test tomorrow afternoon I'll post the results tomorrow evening.
Thanks |
Daddio Samba Member
Posted: Wed Nov 17, 2021 11:02 am Post subject: Re: Wrapping Vintage Speed Exhaust ? |
Posted: Wed Nov 17, 2021 2:20 pm Post subject: Re: Wrapping Vintage Speed Exhaust ? |
aeromech wrote: |
thread |
I think it kinda does. I posted a link to you thread about it. The OP has a similar sized engine build as you and he’s complaining about exhaust noise. Since you run a stock beetle exhaust, which is said to have more flow b/c of the two exit ports and still remains quite. In this day and age we are able to download free apps to measure the noise level. As I stated above my work truck, personal truck and bus all measure at 87 db at 60 mph. What’s the db of your bus at 60 mph? Maybe it’ll be the same or maybe it’ll be a few db quieter and something the OP might want to look into. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Posted: Wed Nov 17, 2021 2:41 pm Post subject: Re: Wrapping Vintage Speed Exhaust ? |
Thanks for the picture OP. Hippie, kiss my ass. I was trying to help from my personal experience. You should try it sometime _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
