Electronic Points Conversion
Page: Previous  1, 2, 3
KTPhil Premium Member
KTPhil is offline
PostPosted: Fri Nov 12, 2021 10:53 am    Post subject: Re: Electronic Points Conversion Reply with quote
Maybe this is off-topic, but I remember reading that to install some pointless systems, some "file to fit" and "goops and glues" steps were needed. Play or interference fits, rotor alignment, and maybe other issues meant it's a one-way-street to convert to pointless. Changing back to points on the road may be impossible, hence the advice to have a complete distributor (ideally with clamp, already timed) is a good backup on long trips.
mukluk
mukluk is offline
PostPosted: Fri Nov 12, 2021 1:06 pm    Post subject: Re: Electronic Points Conversion Reply with quote
I don't know if it's the same for other modules, but the Pertronix I had in my '68 over two decades ago didn't require any alterations to the distributor, you just removed the points & condenser then installed the module and reluctor. Swapping back took less than ten minutes... after I walked a mile home and came back with my old points and condenser.
Xevin wrote:
I thought I read the answer to the original question in one of these post Think
You did, but where's the fun in folks answering a poster's question when there's a chance to reanimate a dead horse then beat it to death again? Eh?
modok
modok is offline
PostPosted: Sat Nov 13, 2021 2:39 am    Post subject: Re: Electronic Points Conversion Reply with quote
Cusser wrote:
Jimbug57 wrote:
I've always been curious about electronic ignition in my bug. Now I'll be able to try for myself.
Call me when you've been driving a VW for 49 years like I have.....
HA! the Classics are always in style
I just got this big smart phone and so far it's just a hindrance.
too fragile to carry with me while working so I just set it next to the computer...but it's like, so what's the point then. no point.
I drive a 1960 with points AND electronic ignition Laughing
maybe I should get a pager. do they still make pagers?
ashman40
ashman40 is offline
PostPosted: Sat Nov 13, 2021 7:19 am    Post subject: Re: Electronic Points Conversion Reply with quote
KTPhil wrote:
… I remember reading that to install some pointless systems, some "file to fit" and "goops and glues" steps were needed.
I don’t know about “goops and glues” but to properly fit the CompuFire electronic ignition which uses a black magnetic disc below the rotor… I had to file down the bottom of the rotor to allow enough space between the rotor and the cam. Without filing down the bottom of the rotor it sat too high and would actually lift the distributor cap as the rotor rotated.
While this is a mod needed to properly fit the magnetic disc it does not prevent reverting back to points. If/when the electronic points need to be removed and points reinstalled the same rotor can continue to be used, there will just be a larger gap between the cam and the bottom of the rotor. The top of the rotor sits at the same height as an unmodified rotor.
I have heard that some Pertronix style electronic modules need slight adjustments in the gap between the black magnetic cylinder and the face of the pickup that sits just outside the cylinder as it spins. This adjustment is the same as adjusting points. Just as where you adjusted your previous set of points doesn’t affect how you adjust your new points, these adjustments don’t prevent installing new points nor do they effect their adjustment.
AshMan40
Max Welton
Max Welton is offline
PostPosted: Sat Nov 13, 2021 8:57 am    Post subject: Re: Electronic Points Conversion Reply with quote
Here's a little story about carrying spare stuff.
In four Berg Cruises and countless other cross-country trips, I've been shouldered only once. I was running a Compufire at the time but the 40-year-old Bosch coil is what died in Indio, CA. Not a spare coil among our 3-car group. It was in the middle of the night so we all just got a motel room till morning and borrowed a coil which I returned when we passed through Denver and got a new one at Painters Grinding.
Some time later, I was asked if I had started carrying a spare coil. Well ... no. I now had a nice new coil. The trick is to carry what you're going to need next, not what you needed last time.
For me, the 2006 Berg Cruise was 7110 miles start to finish over three weeks.
And I haven't been through Indio since then. Laughing
Here's another one involving a partial failure mode. It's long so I'll just link to it.
https://www.thesamba.com/vw/forum/viewtopic.php?p=5983918&highlight=coil#5983918
Max
1967 Type-3 Fastback
doug bugg
doug bugg is offline
PostPosted: Tue Nov 23, 2021 12:15 pm    Post subject: Re: Electronic Points Conversion Reply with quote
I'll weigh in on this. I'm for the old point and condenser set-up, here's why. Twenty years ago I had a '69 with the old points and aside from the usual maintenance and occasional replacement I never had any issues. Then...
... fast forward to September of this year when a buddy gave me his '68 bug. He couldn't get it going after sitting a couple years and swore it wasn't the electrical system because his big buck Pertronix only had a few hundred miles on it. Turns out there wasn't anything else keeping it from starting other than a fuel leak: The electronic ignition was bad.
I threw a new set of plugs, wires and the old 009 distributor on it and it fired right up. Did the Pertronix go bad from sitting? I don't know, maybe. But to me that was enough to kill any previous attraction I had for electronic ignition. No issues since and, yes, I do carry a set of new quality points in the glovebox.
Just sharing my experience.
maggiolo72
maggiolo72 is offline
PostPosted: Tue Nov 23, 2021 12:52 pm    Post subject: Re: Electronic Points Conversion Reply with quote
Buy a 123 distributor and forget it....
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Nov 23, 2021 1:49 pm    Post subject: Re: Electronic Points Conversion Reply with quote
Do some research... there are plenty of problems posted on the interweb... you just have to look.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
maggiolo72
PostPosted: Tue Nov 23, 2021 5:06 pm    Post subject: Re: Electronic Points Conversion Reply with quote
Really ? I have a 1302, a 1302 both with them, a friend on my club have it in a 6 cylinder 1924 Wolseley and in another 1952 Wolseley all are running without any problem....
Mr. 010
Glenn is offline
PostPosted: Tue Nov 23, 2021 5:17 pm    Post subject: Re: Electronic Points Conversion Reply with quote
The MG and Triumlh forums have a number of issues including the Bluetooth versions.
Btw, I've never had a problem with points, but others have.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Frank Bassman
Frank Bassman is offline
PostPosted: Tue Nov 23, 2021 8:26 pm    Post subject: Re: Electronic Points Conversion Reply with quote
Funny thread.
If your mechanical ability allows, use points to trigger a TFI module. Use a real coil (e core) from an 80's ford/chevy if you find the canister coils don't last. (But can use stock.)
Does away with the condensor and if you so choose, you can run better plug wires and open up the spark plug gap up to 40 thou.
But again, can stick to stock coils plugs and wires with TFI. That's what Modok did and he turned me onto it. Never going back to just points and condensors, and never back to canister coils either.
-Frank
Jimbug57
Jimbug57 is offline
PostPosted: Sat Dec 18, 2021 9:45 am    Post subject: Re: Electronic Points Conversion Reply with quote
Follow up:
The Compu-Fire # 21101 doesn't fit my 205 M, as in, no way no how. It went back together nicely though. I had to re-use the shim under the breaker plate because I forgot to order one. Re-used a couple other shims too because they were fine. I still need to get points and condenser from VWNOS though. The Compu-Fire is being returned. I'll just stick with points. It's what I know anyway.
Repeat after me "I am smarter than metal!"
Page 3 of 3
