Distributor 113905205T rebuild *PIC Heavy*
Pruneman99
Pruneman99 is offline
PostPosted: Thu Dec 09, 2021 2:07 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
The felt patch is nestled inside the body of the distributor in the shaft portion. To get it, you need to remove the dog and pull the central shaft out of the body. Then use a dental pick from the bottom of the distributor to fish it out of the recess it sits in. I've been told some distributors don't have this, but every one OG one I've checked did. Including big cap cast iron models, SVA, and SVDA models.
This is a 111905205N which is very close to the SVA you're working on. It was kinda hard to get a picture, but if you look inside the shaft hole, you'll see a black band in the picture. That's actually a recessed area. You cut the felt to fit in there. Oil it and install the shaft.
Many people leave the old, cruddy, falling apart felt in there and it will be full of grit. Even worse, I've seen someone glass bead the body of a distributor, and not take out the old felt. It HAD to be absolutely full of glass.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Thu Dec 09, 2021 2:52 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
I refer to those felts inside the shaft as bearing killers. As you point out, they are just packed full or dirt, grit and debris. There was a reason Bosch stopped installing them in their distributors starting in 1974.
The Samba member since 2004.
Pruneman99
PostPosted: Thu Dec 09, 2021 6:26 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
Interesting. So when you rebuild these types, do you remove the old one, clean, and omit the shaft felt upon reassembly?
moundtop
moundtop is offline
PostPosted: Sun Dec 12, 2021 3:27 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
Thanks to the details in this thread and parts from VWNOS I was able to successfully rebuild my 205T. I did encounter two difficulties. It took me a while to install the shaft without getting it caught on the new felt pad between the bushings. But the BIG problem was removing and reinstalling the pin that secures the drive dog at the end of the shaft.
Does anyone know a source of replacements for this drive pin? Would it be ill advised to replace it with a "roll pin" of similar size?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Dec 12, 2021 3:46 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
5/16" punch and a BFH.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sun Dec 12, 2021 8:09 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
The early cast iron distributors had no bushings, thus no felt pad either. Not sure I would consider the felt pad critical but the Bosch engineers felt they were needed for 14 years for a reason. I'm more positive than Bill. Rather than "killing bearings" I believe the pads retain oil, (and some minute dirt particles suspended in the engine oil) that lubricates the bearings. In the same 20 years I've only encountered a handful of distributors with excessive lateral play= worn bearings. I can't think of a drive dog pin that I couldn't remove, after twenty years of restoring distributors. A big enough hammer and some patients has always succeeded. I have at least 100 spare pins, PM me and you can have a couple for the price of postage. Every Bosch distributor has the same size drive pin from at least 1938 until-?
Roads Scholar
Member# 2059
Mr. 010
Glenn is offline
PostPosted: Sun Dec 12, 2021 8:18 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
tasb wrote:
I can't think of a drive dog pin that I couldn't remove... A big enough hammer and some patients has always succeeded.
I had a very few that needed some time, penetrating oil and a torch.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Sun Dec 12, 2021 9:20 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
I regularly replace the bushings in the aluminum distributors. It seems the mid 70's distributors and later more so. 009 most always need them replaced. Cast irons ones sometimes need to be sleeved and re-bushed but less so than the rest.
You can't beat the pins from the Garbe distributors. The drives break easily on those. The others you can hit them very hard. I've seen the Mexico distributors with roll pins in them. As long as you put the spring ring around it you will be fine.
Jimbug57
Jimbug57 is offline
PostPosted: Mon Dec 13, 2021 4:55 am    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
I use this 1/8" punch with a BFH to remove the drive dog pin.
Repeat after me "I am smarter than metal!"
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Dec 13, 2021 7:18 am    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
If those fiber felts were needed and critical Bosch would not have discontinued using them in their distributors. Having restored well over 1000 1974 and later distributors that don't use the felts, it's extremely rare to find measurable wear on the bushings or on the shafts of the distributor. And, I measure the bushings and shafts with snap gauges and micrometers. I don't go by feel. I have changed maybe four worn shaft bushings in 1974 and later distributors due to measurable wear due to extreme high miles or a clogged oil inlet to the distributor. One was a rarer distributor that required me to machine the mainshaft on my lathe and then make custom bushings due to the shaft being undersized after the machining. I've also had to bore out a few cast distributor bodies on my lathe that did not originally come with bushings due to excess wear in the cast body bores. I then made custom bushings with tight tolerance bronze rod.
I recently restored a German Bosch 009 distributor that the owner said had at least 200k miles on it. The German 009's also did not come with those fiber pads either. The shaft mic'd out perfect as did both the upper and lower bushings. The shaft looked brand new. It only required a polish.
People should do what they are comfortable with. Myself? I'll continue to remove those filthy, quickly contaminated bearing killers. Wink
Jimbug57
Jimbug57 is offline
PostPosted: Mon Dec 13, 2021 11:13 am    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
I just disassembled my spare 113 905 205 M. The felt pad was hardened gunk - hard to remove. I made a new pin to hold the cap clamp on, but I can't get the ends of the broken one out. It still works though.
The hard part for me on these is getting a new ground strap made and installed. I'm going to try a torch on the breaker plate because my soldering iron doesn't get hot enough. I could use some help on the correct way to be doing this.
I can see Bill's point on the pad, however, I have a new felt from VWNOS. Not sure what to do there. I can't imagine Bill would steer you wrong. I don't need to decide right now. I will be installing a Compu-Fire module in this one. I'm running another 205 M with points and condenser in my single port currently.
Chickensoup
Chickensoup is offline
PostPosted: Mon Dec 13, 2021 11:38 am    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
question... I completely rebuilt my late 40hp dizzy about a year or so ago.
I replaced the main bushing with one sold from VWNOS. The bushing was way to tight, and didnt fit at all once in the bore of the distributor body. So i ended up polishing the shaft which helped some, however when i turn the rotor it still feels too tight.
I believe the material is a bronze of some sort. Should i run it and see how it feels after break in? Or take everything back apart, remove the bushing, and make my own?
'65 Tourist Delivery Build
'66 RIP
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Dec 13, 2021 3:14 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
The tightness could be the shaft binding some of the felt fibers in the lower bushing. The felt fibers can get caught between the shaft and the bushings as you push the shaft through the felt. If that's not causing the tightness, then ideally you'd measure the new bushing that you installed. Then measure the shaft. I like to have about 1 thousandths play between the shaft and the bushing.
Make sure you don't have any burrs protruding out on the bushing from where you hammered on the lip to install it in the distributor body. The bushings are soft. Unless you used the correct size bushing driver, you'll probably have some high spots where the drift/punch hit the bushing. That will cause your issue. Use a round file and knock off any burrs or highspots around the bushing where it was impacted by the punch. Then test fit the oiled shaft back through the bushing to see if the shaft spins easier.
VWNOS.com
heimlich is offline
PostPosted: Mon Dec 13, 2021 4:06 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
You will need to ream it to fit. You can run them a little tight but not so tight they generate a lot of heat. If you want to send it to me I will ream it for you.
sb001
sb001 is offline
PostPosted: Mon Dec 13, 2021 4:52 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
When those fiber washers disintegrate:
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
Mr. 010
Glenn is offline
PostPosted: Mon Dec 13, 2021 4:57 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
Yes, if they were meant to last forever, Bosch would not of made replacements.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Pruneman99
PostPosted: Mon Dec 13, 2021 5:02 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
Looks like I opened a can of worms with the felt discussion. There seems to be some disagreement if it should be replaced or left out. I can see pro/con of each method so I guess it's going to be up to the restorer to decide.
The more important thing I was trying to point out is to not leave the old one in there like I've seen people do because they were unaware of it. I think wether or not you replace it, everyone can agree the old one needs to be fished out and cleaned well.
Mr. 010
Glenn is offline
PostPosted: Mon Dec 13, 2021 5:06 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
Not needed.
I've re-rebuilt a few that i've removed it from for customers that were building new engines and wanted it to look "fresh" all have plenty of oil and not wear.
It's just a wick to keep the shaft, between the bushings, moist. Mercedes and Volvo had a oil port added to the boss on the cast iron models, but VW/Porsche/BMW/SAAB did not.
After 20+ year and thousands done, i've not had a single reported problem.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
sb001
sb001 is offline
PostPosted: Mon Dec 13, 2021 5:33 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
Would not HAVE.
1600 SP engine
Mr. 010
Glenn is offline
PostPosted: Mon Dec 13, 2021 5:35 pm    Post subject: Re: Distributor 113905205T rebuild *PIC Heavy* Reply with quote
sb001 wrote:
Would not HAVE.
3M TA3
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Page 8 of 9
