gonefishen Samba Member
Posted: Wed Dec 29, 2021 10:48 am Post subject: TenCent timing on a 1.9 |
I did time by Tencent method, but that's for 35 degrees. Did anyone come up with a measurement for 40 degrees. I'm sure he said 2" from pulley mark for 35 degrees.
Thanks |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4434 Location: ABQ NM USA.... Except when not
Posted: Wed Dec 29, 2021 11:23 am Post subject: Re: TenCent timing on a 1.9 |
gonefishen wrote: |
Thanks |
Did you ask Chris/tencent that question? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6930 Location: Fort Lauderdale, Fl.
Posted: Wed Dec 29, 2021 11:32 am Post subject: Re: TenCent timing on a 1.9 |
There's a magic button in the upper right that will get you to here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=409221 _________________ This free advice is worth exactly what you paid for it.
Posted: Wed Dec 29, 2021 12:23 pm Post subject: Re: TenCent timing on a 1.9 |
So I figured out about 1/4 inch more for 40 degrees.
Thanks |
Posted: Wed Dec 29, 2021 1:45 pm Post subject: Re: TenCent timing on a 1.9 |
With the 1.9L Digijet you want to set your timing at 28° BTDC @ 3800+ rpms, hoses off and plugged, just like you would with an old aircooled. This takes into account that your vacuum retard and advance are not working to factory specs any more. The Digital Idle Stabilizer needs to be bypassed as well when setting the timing.
From memory the mark should be something like 1 5/8" from the "u" mark on the pulley, but you might want to do your own calculations. |
