gregburb Samba Member
Posted: Tue Jan 04, 2022 1:40 pm Post subject: thread chaser set? |
Can anyone recommend a thread chaser set. I want to clean up the threads before putting heads back on. |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4392 Location: ABQ NM USA.... Except when not
Posted: Tue Jan 04, 2022 2:57 pm Post subject: Re: thread chaser set? |
FWIW, I've heard that sometimes taps and chasers enlarge the existing holes too much and a good solution for just cleaning the threads is the old bolt (or one same size) with cut a vertical/top-to-bottom slot or two in it with a dremmel. That way you are nor removing any new material. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
4Gears4Tires Samba Member
Posted: Tue Jan 04, 2022 5:06 pm Post subject: Re: thread chaser set? |
Using an angle grinder to cut a sharp groove into an existing bolt is a great way to chase threads. I've done it before, it works well.
That said, I have a Craftsman thread cleanup kit and they don't enlarge the holes any. They can remove coatings though, and then that sometimes makes a looser fit.
I have a Harbor Freight thread tap kit and that definitely cuts things looser. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3624 Location: Dartmouth, Mass.
Posted: Tue Jan 04, 2022 7:48 pm Post subject: Re: thread chaser set? |
A thread-rolling tap, vs. the more common thread-cutting tap is, in my humble opinion, a better way to โchaseโ threads.
I tend to use high-quality thread-rolling screws to chase threads. because of my access to such. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Mateo83 Samba Member
Joined: September 14, 2021 Posts: 645 Location: Lodi, CA
Posted: Tue Jan 04, 2022 11:45 pm Post subject: Re: thread chaser set? |
I got an easy out set and tap with proper bits at my local fastenal. |
jimf909 Samba Member
Posted: Sat Sep 10, 2022 6:41 pm Post subject: Re: thread chaser set? |
The M12x1.25 nut on the anti-sway bar end link took a leave and the threads on the end link got buggered. I don't have an M12x1.25 die and filing w/ a triangle file isn't delivering an effective result.
Is this end link a candidate for repair or replacement? If repair, what is recommended: thread chaser, thread cutter, file?
Thanks. _________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23853 Location: NYC/Upstate/ROW
Posted: Sun Sep 11, 2022 7:09 am Post subject: Re: thread chaser set? |
jimf909 wrote: |
Thanks. |
I think Irwin makes this size , available single piece at my local hardware store for about $10. You will only get 5-10 uses out of these in my experience.
Looks saveable IMHO _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
Posted: Sun Sep 11, 2022 9:49 am Post subject: Re: thread chaser set? |
Thanks for the tips. I'll attempt a repair and report back. _________________ - Jim
Butcher wrote: |
Guilty as charged.
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10002 Location: Where?
Posted: Sun Sep 11, 2022 11:04 am Post subject: Re: thread chaser set? |
Rather than using a file or thread cutting die, I would recommend getting a thread forming die or a thread repairing die, either of which will work to push the displaced metal back where it belongs rather than just removing it. The result would be a stronger thread. |
lcolon Samba Member
Joined: July 26, 2006 Posts: 57 Location: SF Bay Area
Posted: Sun Sep 11, 2022 2:19 pm Post subject: Re: thread chaser set? |
It looks like it is currently out of stock, but this is a great thread chaser set that should cover most of your near term metric needs:
https://www.mcmaster.com/25325A14/
It is a USA made JAWCO 1853 chaser set. Maybe you can find it elsewhereโฆ. Worth a look _________________ 1984 Vanagon Westfalia - Vanna
1971 VW Beetle |
Crankey Samba Member
Posted: Sun Sep 11, 2022 5:22 pm Post subject: Re: thread chaser set? |
Since the threads are worn away, after chasing they won't be very deep in the shaft...ya know like drilling an oversized hole to make tapping easier, it also makes shallow threads that don't have the same grip or clamping/pulling force.
I mean after chasing those out, the nut will still be loose, and if you try and torque on it you might just scrub the nuts threads past the shaft threads, stripping the remaining thread off the shaft.
It might feel ok and tight-ish after chasing but stress of driving movement could have it fail when your someplace where all you can see is trees and the night sky for miles.
I'd replace it. |
Posted: Sun Sep 11, 2022 9:38 pm Post subject: Re: thread chaser set? |
Thanks, folks. I'll try salvaging it with a thread repair die and will be ready to replace it if that isn't adequate (I've pinged Christopher at T3 to see if he has a replacement but I believe he's using different parts for the HD end links nowadays). _________________ - Jim
Butcher wrote: |
Guilty as charged.
Posted: Sun Sep 18, 2022 7:58 am Post subject: Re: thread chaser set? |
Follow-up: repairing threads on the T3 Technique HD endlink
I bought this cheapo thread repair set on amazon that included both a file and a chaser die (one hardware store in 35 miles and it doesn't stock such tools)
https://www.amazon.com/dp/B07VYGK6GN?ref=ppx_yo2ov_dt_b_product_details&th=1
- First, it became clear that there was no way the die could have been used to start the repair because the threads were too damaged and the chaser couldn't be turned with reasonable force.
- The thread repair file (it is a life changer!) did great work returning the threads to some semblance of their former selves but they still needed work in order to function.
- I could then use the chaser to finish the work and reinstall the end link.
- It took about an hour to repair the thread.
Before (after attempting a fix for about 20 minutes with a triangular file, the first four threads looked as bad as the rest)
After
Not having a vice in this shop required some creativity to hold the threads while using a breaker bar to turn the chaser
Crankey wrote: |
I'd replace it. |
The end links are on backorder at T3 Technique so I'll see how long this repair lasts. I've had questionable fixes last 30 years, and others that I thought were solid fail in short order. Given this is an anti-swaybar part failure will only result in a wobbly van.
Thanks all for the advice. In the past I've either used a thread cutting tool or a file so this type of thread repair was new to me. _________________ - Jim
Butcher wrote: |
Guilty as charged.
