panel Samba Member
Joined: December 02, 2001 Posts: 1091 Location: Victoria B.C. Canada
Posted: Sat Dec 11, 2021 8:49 pm Post subject: Fresh Air Inlet Box Assembly 1955-67 |
I was wondering how many changes in the Fresh Air Inlet Box Assembly there were during production. The one has a solid bump line and the other one has a broken line in the same area bump. My 65 has the 2 bumps inline.
_________________ My '65-Subaru EJ20 Turbo conversion |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Sun Dec 12, 2021 5:16 am Post subject: Re: Fresh Air Inlet Box Assembly 1955-67 |
From 3/55 to approx end of wolfsburg production they were ribbed lengthwise with a 5 position adjustment on the flap. From end of Wolfsburg production til end of Feb 58 they were ribbed with 4 position adjustment. After Feb 58 they lost the ribs per your photos. Not sure when the 2 lines started. |
Stocknazi Samba Member
Posted: Sun Dec 12, 2021 9:24 am Post subject: Re: Fresh Air Inlet Box Assembly 1955-67 |
12/30/59 with the split line.
Cool topic, will be interesting to narrow down when the changes occurred.
I'm guessing this change is not listed in literature. I believe there were also a couple different variations of the center panel pressing post 2/58.
_________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Sun Dec 12, 2021 7:08 pm Post subject: Re: Fresh Air Inlet Box Assembly 1955-67 |
CaLiBus has a triple rib down the center (front to back), VIN 328050.
First pic (my bus) has single sideways rib (forward of directional handle), smooth larger flat area, VIN 328082 (2/15/5.
StockNazi's bus (split/double sideways rib) = 12/30/59 _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Dec 13, 2021 9:43 am Post subject: Re: Fresh Air Inlet Box Assembly 1955-67 |
It may come up sometime here- but there's one more box variation if you count the '66-up one with the rear sealed inlet flap.
My wild hunch though is that VW found they needed more rigidity in the flat bottom perhaps to mitigate air leaks at speed?
Interesting topic indeed- Lind should be here soon _________________
EverettB wrote: |
FU#5 |
panel Samba Member
