Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80319 Location: Sneaking up behind you
Posted: Mon Feb 07, 2022 1:01 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
| Frizbal wrote: |
Bringing/keeping this alive as there doesn’t seem to be a lot of users yet. Looks like it needs Hoover bit to me. Just got mine in the mail.
It does... just like the original. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Frizbal Samba Member
Posted: Mon Feb 07, 2022 7:09 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
Yep. I didn't order one after reading this thread, but evident that I'll need one.
Also for anyone that orders one note: mine didn't come with the gasket/seals for the exit tin pieces. |
Glenn  Mr. 010
Posted: Mon Feb 07, 2022 7:36 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
| Frizbal wrote: |
I use foil tape. You don't see it and it sure works better than the aftermarket rubber seals.
Member #1009
#BlueSquare
wheel607 Samba Member
Posted: Mon Feb 07, 2022 7:51 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
| Glenn wrote: |
| Frizbal wrote: |
I USE to use foil tape until my engines were lasting longer that the tape. It seems like the tape cant take the heat for LONG, I mean LONG .....50 K mile periods. Had it fail twice, got sucked into the fan. Fortunately, the motors were local and ran long enough to make a tremendous amount of noise. Checked the tape and it had lost ALL of its sticky. Yea, it works better until it doesnt. |
Glenn  Mr. 010
Posted: Mon Feb 07, 2022 7:55 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
| wheel607 wrote: |
| Glenn wrote: |
| Frizbal wrote: |
Using the wrong tape. Recently did a clutch on a engine i did years ago. The tape is still there and not coming off easily. _________________ Glenn
Member #1009
#BlueSquare
Posted: Mon Feb 07, 2022 8:54 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
| I plan on using tape as well, but want the rubber as a back up and to minimize any vibration. |
KROC Samba Member
Joined: February 20, 2006 Posts: 364 Location: Vancouver B.C.
Posted: Mon Feb 07, 2022 9:57 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
No AA is not making them now, AA gets theirs from Concept 1
You can see C1 in their part number.
Cheers |
texastomeh Samba Member
Joined: November 20, 2018 Posts: 305 Location: Dallas, TX
Posted: Mon Feb 07, 2022 10:16 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
Glenn wrote:
| Quote: |
| Using the wrong tape. |
I like the idea of using the rubber seals and then covering them with foil tape.
Glenn - Would you mind recommending the proper tape?
THANX,
Tom _________________ A new engine build won't solve ALL of life's problems - only those THAT REALLY MATTER!!!
GETTING old was GREAT - BEING old SUCKS!!
Too bad that the guys that know how to solve all of the WORLD's problems are too busy working on old Volkswagens!! |
Glenn  Mr. 010
Posted: Tue Feb 08, 2022 6:09 am Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
| texastomeh wrote: |
Glenn wrote:
| Quote: |
THANX,
Tom |
Nashua 324A
https://www.lowes.com/pd/Nashua-324A-2-5-in-x-60-1...lsrc=aw.ds
| Quote: |
| Nashua 324A Cold Weather Premium Foil Tape is a cold weather, premium grade, printed aluminum foil tape (with liner) used for HVAC applications. It is recommended for use on UL listed fiberglass duct board in accordance with manufacturer's installation instructions. Ideal for permanent flexible seals. Meets UL 181 A-P standard for use as a closure material on fiberglass duct systems and UL 181 B-FX standards for use on flexible air ducts and closures. Also can provide a durable seal for dryer ventilation and on rigid sheet metal ducts. |
Provides long-term anchorage and strong cohesive bond for long-term durability.
Superior adhesion even at extremely low or high temperatures. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3999 Location: Antioch, California, a block from the hood
Posted: Tue Feb 08, 2022 9:05 am Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
| Quote: |
| Nashua 324A Cold Weather Premium Foil Tape |
it shall be!
I Found it listed at several of the "big box" stores (Lowes, Home Depot, Walmart, etc.) as well as AMAZON online.
Should seal it up "as tight as gnat's @ss stretched over a #2 washtub" as my Grandfather used to say!!
THANX Glenn!!
vdubrookie Samba Member
Joined: May 12, 2017 Posts: 305 Location: Battle Creek,Mi
Posted: Sat Feb 12, 2022 1:35 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
| I have a 36hp style cooler on my sand rail with a swing axle trans & I am right in that 3300 @ 55mph bracket. Trans was built by Leduc Racing c9mponents. Would I benefit from a shroud like this or would I be better off sealing up & optimizing the setup I have? |
empi3 Samba Member
Joined: October 03, 2015 Posts: 383 Location: SW Wyoming
Posted: Thu Apr 07, 2022 11:34 am Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
| Busstom wrote: |
Well, if they weren't made in China then, they will be now. |
Just received mine from JBugs. Box has EMPI made in ROC Taiwan stickers on the original Concept 1 box.
Steven
PS Looks like the quality is still good though  _________________ The fact someone posts a thousand messages a month does not mean the messages contain anything worth reading.
Bob Hoover
1970 Beetle
1956 Ragtop Beetle
1968 Ghia |
walter kandetzki Samba Member
Joined: June 02, 2003 Posts: 947 Location: Dillwyn, VA
Posted: Thu Jan 18, 2024 5:46 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
| So I’m deleting the heater boxes from my 71 super running j tubes,industrial tins,all factory German tins,thermostat oil bath cleaner,34 pict on a 1641.not a huge fan of the 36hp style especially with quality.would this fan housing be ok with my bug?im using a 3.88 trans and will be doing more highway driving than in town.original thing fan housings are just as much |
Glenn  Mr. 010
Posted: Thu Jan 18, 2024 6:19 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
I installed one on a 2017 in a 66 Bus. Fit and finish is equal to OEM. Flaps, linkage and thermostat fit just like stock.
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Busstom Samba Member
Joined: November 23, 2014 Posts: 4583 Location: San Jose, CA
Posted: Thu Jan 18, 2024 7:22 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
| empi3 wrote: |
| Busstom wrote: |
Steven
PS Looks like the quality is still good though  |
Good to hear! Specifications and factory selection matter  _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom)
| cory464 wrote: |
| if you aren't perfectly centered in the hole you will have issues when you tap it. |
Posted: Thu Jan 18, 2024 8:04 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
I installed one, but unfortunately had to have it hacked to pieces and re-welded… sure wish they would make a version that fits type 1 manifolds. Had interference with both GB and CB manifolds. But she looks sexy now!
Thread Samba Member
Joined: June 25, 2017 Posts: 71 Location: Portland, Or
Posted: Sat Apr 27, 2024 12:57 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
EDIT: figured out the interference, it was the inner flaps hitting the cylinder fins. Which makes sense since the barrels are larger.
I’m mocking up my build using the cooled fan shroud with the type 4 cooler. I’m also running the stock thermostat flaps. What linkage rod are those of you running this setup using? I’m using a 75-79 linkage and so far it’s pretty tight with the base of the cooler. I’m worried it might interfere when everything is buttoned up.
Was there any modification of the linkage needed on your setups or is there another version of the linkage that works better?
Glenn  Mr. 010
Posted: Sat Apr 27, 2024 1:24 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
| Frizbal wrote: |
Not sure what your problem was. Here's their fan shroud, with fresh air, and CB manifolds.
The shroud is the same dimensions of the stock one and i've had both Dellorto and 48 IDAs with no problem. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sat Apr 27, 2024 5:42 pm Post subject: Re: COOLED brand Engine fanshrouds and engine tin. |
They were the type 1 shorter manifolds from CB. But the gene berg manifolds didn’t fit either. Manifold flanges and carb linkage would have hit the edge of the shroud.
