Two types of manifold heat riser gaskets?
Page: Previous  1, 2, 3, 4
diablosandwich
diablosandwich is offline
PostPosted: Tue Jun 01, 2021 2:23 pm    Post subject: Re: Two types of manifold heat riser gaskets? Reply with quote
I’m pretty sure I have an extra if you need one.
Casey.
1966 Java Greens
kingkarmann
kingkarmann is offline
PostPosted: Wed Feb 23, 2022 10:06 am    Post subject: Re: WW do not have this gasket anymore Reply with quote
Ferrety66 wrote:
Ferrety66 wrote:
diablosandwich wrote:
I ordered an exhaust kit from Wolfsburg West that did not have the small hole gasket. I called and they sent me one for free.
Update: I purchased the Muffler Installation Kit from Wolfsburg West (May 2021). The kit does not come with the small hole gasket anymore yet, the continue to advertise it on their pictures.
Here is how the conversation went.
Ulfberht
Wed, May 26, 6:48 PM (6 days ago)
to wwired
Hey guys thank you for your always fast and professional service. I just noticed item 111298009A did not come with the "small hole" gasket. Can you please send me one asap. Thank you kindly, I have included a pic showing exactly what I am referring to.
ww to me:
Hello
Thank you for the email.
Unfortunately HJS does not supply this gasket with the kits any longer. They only provide 2 of the large hole version.
Thank you.
Sean
I asked for a discount on my next purchase and he said the don't do that but I can return the kit for a refund. Well I still need the kit Crying or Very sad
By the way the have not updated their pictures.
been buying for 10 years ....
Reviving this old thread since I just reinstalled my carbon blocked single port manifold.
This is my first "stock" engine. I wanted to make sure I had the correct gaskets. I stumbled across this thread not knowing there were two different gasket sizes for the heat riser.
Since they seem to be unavailable I decided to fashion a plug made from aluminum flashing.
We will see how it works.
Ferrety66
Ferrety66 is offline
PostPosted: Wed Feb 23, 2022 10:17 pm    Post subject: Re: Two types of manifold heat riser gaskets? Reply with quote
That looks cool. Let us know how it worked out. By the way I searched in Google for those "small hole gaskets" the are available from several vendors. Best of luck!
"Mit Geduld und Spucke fängt man eine Mucke."
Pruneman99
Pruneman99 is offline
PostPosted: Wed Feb 23, 2022 10:55 pm    Post subject: Re: Two types of manifold heat riser gaskets? Reply with quote
If the manifold is carbon blocked, it doesn't matter what size hole is in the gasket Shocked
kingkarmann
PostPosted: Wed Feb 23, 2022 10:59 pm    Post subject: Re: Two types of manifold heat riser gaskets? Reply with quote
Just to clarify, the blockage has been resolved.
kingkarmann
PostPosted: Wed Feb 23, 2022 11:01 pm    Post subject: Re: Two types of manifold heat riser gaskets? Reply with quote
Please feel free to share. I would be happy to support them😎
Pruneman99
PostPosted: Wed Feb 23, 2022 11:05 pm    Post subject: Re: Two types of manifold heat riser gaskets? Reply with quote
I figured. Just messing around.
I think that solution should work as long as the insert gets trapped in there.
Your engine looks really clean. I like it.
kingkarmann
PostPosted: Thu Feb 24, 2022 6:50 am    Post subject: Re: Two types of manifold heat riser gaskets? Reply with quote
Seems The heimlich at VWNOS has them.
https://www.vwnos.com/113-251-265
Good to know if one decides not to go the DYI route.
He has a good amount of my cash already Laughing
Page 4 of 4
