AceManInFL Samba Member
Joined: February 18, 2022 Posts: 7 Location: St. Petersburg, FL
Posted: Thu Feb 24, 2022 7:07 pm Post subject: Help Identify My Carbs |
Just purchased a '64 beetle, it's my first beetle and I'm learning tons. Recent receipt shows install of two Weber carbs. I'm trying to determine if these are actual Webers or a similar style and what the model is. I can not find a serial number visible. Please help.
Additionally, if anyone does knows what these are can you tell me what the recommended fuel pressure PSI is? I'm at 3.2.
House Minutia Militia
Posted: Thu Feb 24, 2022 8:38 pm Post subject: Re: Help Identify My Carbs |
Look around the base of the carbs right above the intake manifold gasket with a light and mirror.
They should be stamped with a size and model number hopefully. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11419 Location: Oregon
Posted: Thu Feb 24, 2022 8:51 pm Post subject: Re: Help Identify My Carbs |
3.2 Psi will be ok.
Look at the fuel pump diagram cover plates. If the carbs are Weber's, the cover plates will have the Weber name embossed in the castings.
Otherwise, suspect that the carbs are IDF clones from China. That's not really a bad thing, these day's. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
