Karma - Part it forward
SWbySWesty
SWbySWesty is offline
PostPosted: Fri Aug 26, 2011 1:18 pm    Post subject: Karma - Part it forward Reply with quote
So the point of this thread is to get karma by giving things away that you don't need. Generally van related or connected.
(Moderator edit)
Here's how this thread works:
1) Post a list of parts you would like to give away for free (or for cost of shipping).
2) If you want any of the listed parts, send the "seller" a PM (private message).
3) Once you've parted-it-forward, please edit your post with GONE! at the top; if you have multiple items, place a GONE!=> in front of the part(s) you've karma'd. If it's too late to edit your post, please PM a moderator and s/he will do it for you.
Please keep pointless banter out of this thread, this includes "thanks!" replies. Any posts not listing parts up for grabs will be removed.
If you see something you want, but the seller won't ship, go to this topic to find someone who's willing to drive it to you:
https://www.thesamba.com/vw/forum/viewtopic.php?t=693686 .
Thread purged:
Nov. 3, 2012
June 2, 2013
April 3, 2015
March 6, 2018
October 16, 2022
July 30, 2023
(/moderator edit)
Karma idea:
*You may NOT receive an item and then sell it. Use it, give it back, or karma it again. Don't be that guy.
**You may NOT request any items. Either it comes up or it doesn't.
***Post your location; first come, first served.
GONE!
I have a 1986 stock chrome w/ black rubber rear bumper. Great condition. Includes end caps (one slightly busted). Sitting in the back yard with nothing to do. Who wants it?
I'm in Marina del Rey, CA. Come get it or parts train it somewhere.
1986 Westy - Billie Jean
A Westy with a Jeep heart (Pura Vida)
www.theadventurebrigade.blogspot.com - Latest update: Johnson Valley - Nov 22, 2011
buelteman
buelteman is offline
PostPosted: Sun Feb 20, 2022 11:41 am    Post subject: Re: Karma - Part it forward Reply with quote
I have parts in a milk crate in my driveway on the coast in Montara California ready for the first lucky Vanagon owner to pick up! To wit:
1 - Blue Sea Automatic Charging Relay for your non Li-Ion battery, which works great and has served me well. Just intalled solar panels and new relay so this is surplus
1 - One Odyssey Extreme Battery (CCA: 810, PHCA: 1550) from the above mentioned setup. Used, but has held a 12.42 volt charge over the 18 months since I removed it without recharging. Case was carved with Dremel to perfectly fit second battery box behind driver's seat so lid can close.
3 - 2-plastic vanagon seat slider bushings for front seats, disused due to addition of Town and Country front seats from Small Car
4 - Bug Screen for front free air inlet, disused when I installed flapper control
5 - For bottom Cabinet below sink: Original riser that lifts base of front cabinet above sink drain along with nice vertical paper towel dowel and base.
6 - One 750 Watt DC to AC Power Inverter by Vector. Wheezes a bit when turns on due to a cooling fam bearing, but silences after restart. 1500 watt peak output.
'91 Westfalia Camper - VW BNB
1.8 Turbo courtesy Stephan's
Custom Geared 5-speed tranny with
Peloquin Limited Slip Diff
H&R Progressive Rate Springs
300 Watt 13 speaker stereo
Audi Disc Brakes
LED driving and interior lights
View user's profile Send private message Send e-mail Visit poster's website AIM Address Facebook Instagram Gallery Classifieds Feedback
the_benjamin_effect
Location: Gateway to the North Cascades, Washington State
the_benjamin_effect is offline
PostPosted: Mon Feb 21, 2022 6:05 pm    Post subject: Re: Karma - Part it forward Reply with quote
Free for pickup. Clamshell and associated hardware. Its from my stock 1987 SYNCRO FWIW. Photo is from TS gallery, but you get the point. mine was working perfectly, normal wear as seen in photo. Just installed the GW skid plate and rear spare mount.
I'm in Sedro Woolley (Burlington) Washington.
Also, still trying to get rid of this (also free):
Let me know.
Benjamin
-1967 Sundial Camper 1914cc "Sunny"
-1978 Deluxe Westfalia Jake Raby built PowerStroke 2109cc "Westy"
-1987 SYNCRO Westfalia GoWesty 2400cc "Ruby"
-2000 Subaru Impreza Sport EJ22 ¼ million miles "Trusty"
International Association of Machinists and Aerospace Workers. I.A.M. 751
International Brotherhood of Naval Flight Engineers. I.B.N.F.E. LOCAL 8251
U.S. NAVY Retired; Senior Chief Flight Engineer, P-3 Orion and EP-3E Aries II
U.S.S. Carl Vinson, VFA-22, VQ-2, VQ-1, VP-30
DuncanS
DuncanS is offline
PostPosted: Thu Feb 24, 2022 9:00 am    Post subject: Re: Karma - Part it forward Reply with quote
Will ship if you pay postage. Will be recycled by March 10th.
PM me if interested.
Duncan
MootPoint
MootPoint is offline
PostPosted: Sun Mar 13, 2022 10:58 am    Post subject: 84 Vanagon Fuel Sensor Reply with quote
Fuel sensor, worked well when I removed it when cleaning and replumbing tank. Since the tank was out, I replaced it with a new sensor, but this one works. You will probably need a new o-ring. Whatever you feel would be fair postage to wherever you are.
1984 Westy with tencentlife power!
Californio
Californio is offline
PostPosted: Mon Mar 28, 2022 2:20 pm    Post subject: Re: Karma - Part it forward Reply with quote
I have front door interior and sliding door panels to give away, not perfect otherwise I wouldn't have replaced them, but useable as is or could be straightened. Grey, 1987 Syncro, electric windows. The original map pocket is there but cracked...could be repaired...
Pick up in Mendocino, CA, or possibly on one of my trips to East Bay area. PM if interested.
revolution337
revolution337 is offline
PostPosted: Tue Apr 05, 2022 6:20 pm    Post subject: Re: Karma - Part it forward Reply with quote
Free Spectra fuel tank VW3B, with the large filler neck opening and 7mm fuel outlet (for early vans)
https://ecat.spectrapremium.com/en/parts/VW3B
I purchased this a few months back and leak tested it prior to installation into my van. It was during this that I found out it was leaking from the seam along the rear of the tank. ( see this thread https://www.thesamba.com/vw/forum/viewtopic.php?t=764974 )
I reached out to Amazon and they refunded me for the tank, however they did not request to the have tank sent back to them. They simply told me to "dispose of it however I wish". I figured I would offer it up here for free before I take it to the scrap yard. Maybe someone who is more ambitious (see: cheap) than I can try and repair it and have a good new tank for free. Some of the poorly applied silver paint is also peeling off already
FYI this tank has NOT been filled with gasoline at all. I simply used an EVAP smoke machine to leak test it. In case you were thinking of trying to weld it, it should be safe to do so (insert legal disclaimer here)
Due to obvious large size, local pickup only (central PA)
Shot of where it is leaking from.
1982 Westfalia AEB 1.8t
2017 VW Golf Sportwagen
2001 Audi A4 4.2 V8 swapped
2000 BMW Z3 roadster
-Mark
nvaaron
nvaaron is offline
PostPosted: Mon Apr 11, 2022 7:10 pm    Post subject: Re: Karma - Part it forward Reply with quote
Free JVC CD Player from around 1998. Removable faceplate. Works fine. I upgraded to bluetooth. You pay shipping.
teej
teej is offline
PostPosted: Tue Apr 12, 2022 9:48 am    Post subject: Re: Karma - Part it forward Reply with quote
A bunch of stuff, free pickup in N Seattle area:
pair of VW heads, no obvious cracks between valves
GONE! Set of used Kolbenschmidt 94.5mm piston and cylinders, pulled from VW of Canada rebuild that ran for about 50k miles. Thought I would use to build up a WBX but never did.
GONE! Coolant bottle w/ Blau cap, spare cap, level sensor, spare sensor.
GONE! Brown dash vents from 86, not perfect but they work okay.
4 chrome hubcaps for 14" VW steel wheels, fair condition
used 21mm antisway bar, end links, and powerflex bushings for same
1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans
Jennybenny
Jennybenny is offline
PostPosted: Thu Jun 16, 2022 5:35 pm    Post subject: Re: Karma - Part it forward Reply with quote
Set of repro side mirrors from Bus Depot. Convex so you see more but objects are way closer than they appear. Used a couple of months but replaced with the land rover mirrors.
Stock tow hitch with hardware. Good used condition.
Stock replacement a/c receiver / dryer. Acm Germany 944 573 143 00
Pick-up in Brooklyn NY. Or for those in upstate NY, I’ll be in the Adirondack’s late July / early August so could meet up somewhere.
mugford
mugford is offline
PostPosted: Wed Jun 22, 2022 1:57 pm    Post subject: Desert camo curtain set Reply with quote
As pictured. You can mount them with an elastic string along the top & bottom or use hooks on a sliding rail.
Bainbridge Island WA
xoo00oox
xoo00oox is offline
PostPosted: Thu Jun 23, 2022 11:14 am    Post subject: Re: Karma - Part it forward Reply with quote
FREE!. Complete Dometic refrigerator except for the propane jet. It was in good working order when removed. I just put it on my dumpster. Come and get it quick! I will not ship it.
EDIT- It is now also missing the sparker
space
space is offline
PostPosted: Fri Jun 24, 2022 3:12 pm    Post subject: Re: Karma - Part it forward Reply with quote
I have some rear drum brake parts for an 82 (rears converted to discs)
springs, cylinders etc
Let me know what you need
T
82 westy
w:
2.5 JDM Subie
Rear discs
UngaWunga
UngaWunga is offline
PostPosted: Sat Sep 03, 2022 3:00 pm    Post subject: Re: Karma - Part it forward Reply with quote
Need a brake caliper for a big brake upgrade? No carrier, but you can order those cheap from RockAuto and modify to suit. Two piston Girling caliper from an early 90s Audi used in the big brake kits. Pick up only. I can point you to the other Audi parts you'll need. Please only pick this up if you'll use it. Located in southern NH.
Never used, still in box.
Like these: https://www.rockauto.com/en/catalog/audi,1992,v8,4.2l+v8,1009459,brake+&+wheel+hub,caliper,1704
revolution337
PostPosted: Tue Sep 06, 2022 4:58 pm    Post subject: Re: Karma - Part it forward Reply with quote
Free stock Dometic fridge. Worked well on 120v as well as 12v. Also worked well running on propane, once I got it started (which was finicky at times). Not sure why the photo uploaded sideways, but you know what it looks like. No shipping, pick up only in Central PA area.
-Mark
VicVan
VicVan is offline
PostPosted: Mon Sep 19, 2022 4:42 pm    Post subject: Re: Karma - Part it forward Reply with quote
Not the best gift, but an old starter from a 2.1 WBX auto. It stopped working, I believe it was a stuck solenoid, but not sure anymore...
Works as a core though...
Local pick up in Victoria, BC (Vic West area).
'90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
indianpeaksjoe Premium Member
indianpeaksjoe is offline
PostPosted: Tue Sep 20, 2022 7:34 pm    Post subject: Re: Karma - Part it forward Reply with quote
I’ve got this rear cushion with what I think are cutouts for a/c. Free to anyone who wants to pick it up in Moab.
Mateo83
Mateo83 is offline
PostPosted: Fri Sep 23, 2022 8:59 am    Post subject: Re: Karma - Part it forward Reply with quote
Going through my parts shelf, let me know if anyone wants these:
Headrests
armrests for door cards
front Lowering coils
stock coils & shocks
4" kicker speakers for doors
AC - TEMP control plates. Brown & Black
83 Air-cooled 2.0 Tin Top
uberaudi
uberaudi is offline
PostPosted: Sun Sep 25, 2022 9:25 pm    Post subject: Re: Karma - Part it forward Reply with quote
Anyone need a Terrawagen 2wd partial flare?
A Terrawagen kit comes with options for both 2wd and 4 (2wd having the cutout for the fuel filler), so this is left over.
'84 Adventurewagen 1Z TDI, '08 Audi Avant Quattro 6spd BHW TDI
Another_VW
Another_VW is offline
PostPosted: Sun Oct 16, 2022 4:39 pm    Post subject: Re: Karma - Part it forward Reply with quote
xoo00oox wrote:
FREE! 1 pair of very lightly used 7" LED headlights. I used these only for about a month, didn't like them. Will not ship, pick up only!
Have you changed your mind on the shipping, I’m interested
Page 1 of 7
