Basilbomb Samba Member
Posted: Thu Apr 14, 2022 9:52 pm Post subject: Advice getting out stripped Allen heads in flexplate (Solved!) |
Today I was trying to get out the flexplate allen bolts and whoever was in here before torqued the hell out of them. Ive got a huge milwaukee impact good for over 1000ft/lbs and couldn't budge them. The first try the engine jumped and the allen head bolt stripped. I used a big breaker bar to get the rest out but there's that buggered bolt still in there.
I first tried sacrificing my allen socket by welding it into the bolt, but of course the welding wrecked the temper and it sheared off.
I then tried welding a big nut onto the bolt, and that sheared off too when I leaned on the breaker bar
Now I'm stumped. Those bolts are hardened and I sure don't want to try drilling it out.
Any suggestions? |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10495 Location: Sunshine Coast B.C.
Posted: Thu Apr 14, 2022 10:29 pm Post subject: Re: A little advice getting out stripped-torqued to the nuts-bolt |
I don't have any real advice other than forcing in a star shaped head on those Allen head sockets.
Maybe change your subject title to include "flex plate" or some such? That might get more attention and help? What I"m seeing is a pretty specialized situation.
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
Posted: Fri Apr 15, 2022 3:29 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
The problem at this point would be finding the center of the bolt and getting it punched accurately. You only have to get the head off so you don't have to drill all that deep, originally it would only have been 1/8" or so of metal to drill through. |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23853 Location: NYC/Upstate/ROW
Posted: Fri Apr 15, 2022 4:46 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
Lop of the head with a Dremel , grind flat
Center punch by eye , to within 1mm
Drill with good bit. Not from Harbor Fright or Lowes _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3624 Location: Dartmouth, Mass.
Posted: Fri Apr 15, 2022 6:43 am Post subject: Re: A little advice getting out stripped-torqued to the nuts-bolt |
Vanagon Nut wrote: |
Same here. I’d try driving a Torx bit into that remaining recess with a hand held sledge. I’ve done it with amazing success. At this point, I don’t know if it will work, but I’d give that a go before drilling, etc. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10002 Location: Where?
Posted: Fri Apr 15, 2022 7:30 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
Pounding in a triple-square works 486 TIMES as well as pounding in a Torx. Just saying. That would have been my step 1 rather than welding. |
sanchius  Samba Member
Posted: Fri Apr 15, 2022 7:42 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
A trick I learned from 10ceentlife is to give stubborn bolts some hard whacks with a heavy mallet. That helped me loosen an unyielding high-torque main crank bolt once.
If pounding in a triple-square doesn't work and you do end up drilling it out, supporting your drill with a strap or jack stand (as shown below) helps you focus on keeping your drilling straight.
I had to do something similar with a non-recessed flexplate bolt on a different vehicle. Once I had ground off the exposed bolt head with an fiber disc and removed the flexplate, I could turn out the remaining unloaded bolt shaft with just my fingers. Hopefully the PO didn't use thread-lock on those.
_________________ The Syncro years (2005-16) - The 2WD years (2017-23) - In Hoosierland (2023-now)
Westy & WBX rebuild spreadsheet - Sanchius & Tuna: The Video
Your gold star membership keeps this awesome list going! |
Posted: Fri Apr 15, 2022 8:09 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
Thanks for all the suggestions. FYI, I thought about the triple square as I do have those, but no way was it going to budge that bolt with that kinda torque on it. It would have just rounded it more.
Right now the hole is pretty much filled with hard weld material, but I'll see what I can do to dremel it out so I don't have to drill through that crap as well as the bolt.
I was hoping someone had a trick I hadn't heard of yet, but it sounds like buying some expensive cobalt drills is my only option right now.
I wonder if heating the bolt before drilling it would make it softer or just bugger the drill bit? |
9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Fri Apr 15, 2022 8:12 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
My .02 Canadian would be to flatten your weld out with a Dremel as noted above and drill it.
The welding heat cool cycling will have reduced the hardness of the grade 8 cap screw. Only go far enough to pop the head off.
If you have access to a left hand drill bit, use that. “Sometimes” the drilling forces can jar it loose but I doubt that will help in this case as you’ve tried some pretty severe techniques so far without success.
Alternatively you could heat it again, if you weld another nuts let’s say, and hit it with some Lloyd’s spray (or equivalent - other sprays are available). The shock can loosen the bond with the counter bore and the head of the cap screw.
I don’t envy you. This is a grim situation if you end up needing to drill the fastener out of the back end of the crank. _________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
Posted: Fri Apr 15, 2022 8:14 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
Basilbomb wrote: |
If you mean drilling it while the cap screw is hot, don’t.
There’s is tremendous heat generated while drilling and you’ll cook your drill bit.
Heat it, let it cool to anneal it, then drill.
Use cutting oil too.
Again, just my .02 _________________ 9 1/2 - missing a few pieces.
2018 BMW R Nine T
2012 Golf tdi |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4241 Location: Redwood City, California
Posted: Fri Apr 15, 2022 8:32 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
Sacrifice the flex plate and grind the head off the bolt off and then I’d bet the newly created stud will spin out with your finger. A replacement flex plate is cheaper and quicker than buying a bunch of drill bits and risking further damage to the crank.
I agree with others though, a Torx or triple square might have done it from the outset.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10639 Location: Western WA
Posted: Fri Apr 15, 2022 8:55 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
Wow this is a knock-down, drag-out fight.
And you are fighting admirably, i have to say this does not liook like your first rodeo.
Basilbomb wrote: |
FYI, I thought about the triple square as I do have those, but no way was it going to budge that bolt with that kinda torque on it. It would have just rounded it more. |
^^ I think you're mostly right ^^
But they are generally referring to CV bolts, which are stretched in and the more you disturb the head, pounding driver-bits in, and the delay-time that gives penetrating oil more time "assist". Also on a CV you can knock the head north/south/east/west in its shank clearance, sliding it back & forth over penetrating oil can reduce the head-torque resistance. Not the case here with these short bolts.
Carbide drill bits will march right thru that hardened steel like butter, but you'd need ~1/2" bit which are bloody expensive. Try searching "1/2" Jobber Drill Carbide Tipped" they cost less ($40) but I have no idea if a welded tip holds. I bet need to keep the weld cool. I have never used a carbide tipped bit on steel.
Another option might be to get a 1/8" solid carbide drill ($12?) , and drill thru the bolt so you can get penetrating oil in the backside that may reduce the torque you need to overcome. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Fri Apr 15, 2022 9:12 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
Sodo wrote: |
And you are fighting admirably, i have to say this does not liook like your first rodeo. |
Definitely, and I've never not had a weld-on-a-new-head not work, but then, Ive never had to do it with a bolt torqued on so tightly.
In my past experience, drilling out bolt heads rarely goes as planned and is usually a major headache.
I think I'll first try welding on another, larger nut so there's more weld material to hold the bolt. barring that, it's grind and drill grind and drill I think |
Posted: Fri Apr 15, 2022 9:36 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
If an impact wrench isn't available this hammer type impact tool might work along with a triple square or other appropriate bit:
https://www.amazon.ca/Lisle-30200-Hand-Impact-Tool/dp/B000P0TZ9W
I wore out my Lisle which might speak to a lack of quality in that brand but it did work on at least a several projects.
I agree. Heating the bolt metal red then letting it air cool would likely make it softer than it was. In part I guess that would depend on bolt grade and metal type?
The other consideration is that a PO may've put blue lactate or similar on those bolts. Especially if bolts were re used (IIRC, they're "always replace" types). Heating the bolts might help loosen any thread locking compound.
Neil.
Basilbomb wrote: |
....but no way was it going to budge that bolt with that kinda torque on it.
(VW Gas I4)
VE7TBN |
jlrftype7 Samba Member
Posted: Fri Apr 15, 2022 11:30 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
sanchius wrote: |
Thread lockers are usually defeated by heat if need be, so all that heat that was applied to the bolt 'should' have taken care of the Thread Loc-tite if it's on there. Your picture by the way, is hilarious, although I'm sure at the time you took it, it wasn't ....  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
tjet Samba Member
Posted: Fri Apr 15, 2022 12:46 pm Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
Drill the head off as wildthings suggested. You need to use a bit just larger than the bolt shank. When drilling, you need to go as slow as possible, while applying firm pressure. The drill bit should not be singing ( high pitch squeal). If it does, its already toast. Light oil will help. This method works, it just takes patience. The harder the metal, the slower you go. |
Posted: Sat Apr 16, 2022 10:57 pm Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
I ground out the weld filling in the bolt with a dremel, and that took quite awhile. but after that, a single 1/4" cobalt bit had it done in 15 min!
There's always a way. |
Posted: Sun Apr 17, 2022 10:37 am Post subject: Re: A little advice getting out stripped Allen heads in flexplate |
Basilbomb wrote: |
Posted: Sun Apr 17, 2022 2:23 pm Post subject: Re: Advice getting out stripped Allen heads in flexplate (Solved!) |
If you are just starting from scratch, you could drill say a 3/16 or 7/32" hole down through the sockethead. This may be enough to lessen the tension on the bolt to where it will back out, or if not make it so the head will shear off. |
