Gnarlodious  Samba Member
Joined: September 28, 2013 Posts: 2411 Location: Adobe Jungle USA
Posted: Fri Apr 29, 2022 6:25 am Post subject: What are these plastic filler screws forward of the D pillar? |
Anyone ever see these dummy plastic low profile screws in the side panels above the engine cover?
What were these holes used for? Bolt in the Westy cabinets? There is one on both sides. But my van, tintop, had one hole filled with this plastic screw. Was that normal for tintops? Does anyone have an extra plastic screw? Because one side it is missing. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
nvaaron Samba Member
Joined: August 26, 2021 Posts: 26 Location: Northern Virginia
Posted: Fri Apr 29, 2022 6:58 am Post subject: Re: What are these plastic filler screws forward of the D pillar? |
| Possibly used for 3-point seat belts connections. |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10151 Location: Where?
Posted: Fri Apr 29, 2022 9:25 am Post subject: Re: What are these plastic filler screws forward of the D pillar? |
| It is hard to tell the location from the pic. They might be holes for the seatback pins. |
Posted: Fri Apr 29, 2022 10:17 am Post subject: Re: What are these plastic filler screws forward of the D pillar? |
This should give a wider picture of where it is. The holes are threaded for the usual 17mm hex bolts. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15412 Location: Syracuse, NY
Posted: Fri Apr 29, 2022 10:50 am Post subject: Re: What are these plastic filler screws forward of the D pillar? |
rear 3point seatbelts
you can get a kit from Gowesty if you want..
otherwise.. for whatever you'd like to mount securely up there  _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
