armi Samba Member
Joined: November 23, 2006 Posts: 32 Location: monterey
Posted: Mon May 02, 2022 9:28 pm Post subject: 1975 911s engine |
Hi there peeps i have a 1975 911s motor that orginally had 165hp but i have removed the old exaust and plugged up the thermo reactors on the heads i have replaced the cis injection with carbs and i installed headers. Does anyone know with the mods i have done what kind of hp i should be getting now? |
Starbucket Samba Member
Posted: Sat May 07, 2022 1:38 pm Post subject: Re: 1975 911s engine |
You don't say what carbs, are they 3 barrel Webbers? |
armi Samba Member
Posted: Sat May 07, 2022 10:46 pm Post subject: Re: 1975 911s engine |
Yes tripple weber carbs |
Posted: Sun May 08, 2022 6:54 am Post subject: Re: 1975 911s engine |
The carb'ed motor was rated at 168HP so you will need performance exhaust to up your HP. |
armi Samba Member
Posted: Sun May 08, 2022 5:58 pm Post subject: Re: 1975 911s engine |
I have a set of heat exchangers on it. |
allaircooled Samba Member
Joined: March 09, 2006 Posts: 5 Location: Lakeland, FL
Posted: Sun May 08, 2022 6:06 pm Post subject: Re: 1975 911s engine |
armi wrote: |
Which heat exchangers? It makes a difference. 74 and earlier where each side exits to the muffler, or the later kind where you only have one input to the muffler. |
armi Samba Member
Posted: Sun May 08, 2022 7:19 pm Post subject: Re: 1975 911s engine |
I have the early style. |
Posted: Sun May 08, 2022 7:28 pm Post subject: Re: 1975 911s engine |
Get a Bursch Extractor Quiet Muffler to help those Webers breathe. |
armi Samba Member
Posted: Sun May 08, 2022 7:58 pm Post subject: Re: 1975 911s engine |
I do have the bursh muffler. So what kind of HP i should be putting out with this set up? |
Posted: Mon May 09, 2022 9:07 am Post subject: Re: 1975 911s engine |
You are right around 180HP. |
armi Samba Member
Posted: Mon May 09, 2022 10:14 am Post subject: Re: 1975 911s engine |
Good 180hp should do well on my 914. |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 1050 Location: San Juan Islands
Posted: Fri Apr 21, 2023 11:05 am Post subject: Re: 1975 911s engine |
Starbucket wrote: |
With CIS Cams? Even though he has early exhaust, that seems optimistic for a 2.7 with Non S Cams.
Either way, a 2.7 will be a fun engine in a 914. _________________ When I set my timing, why do I flush, then take a pee? |
Joined: December 28, 2016 Posts: 310 Location: atlanta ga
Posted: Sat Apr 22, 2023 10:33 am Post subject: Re: 1975 911s engine |
you will have to reset the cam timing for the cis 2.7 to run optimally with the carbs. |
