Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79778 Location: Sneaking up behind you
Posted: Mon May 23, 2022 5:53 pm Post subject: Changing 40hp round boss to square boss |
Have an engine that had the rocker stud insert rip out of a 40hp short stud round boss.
It seems like the best option is to replace both heads with square boss heads.
But are the rocker assemblies the same? If not what needs to change?
Just want to know what i'm looking at before I go that route. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Glenn  Mr. 010
Posted: Mon May 23, 2022 6:05 pm Post subject: Re: Changing 40hp round boss to square boss |
Did a search and it looks like the following are issues:
Round boss heads to square boss heads
Rocker assemblies
Head studs
Pushrods
Intake manifold
Can someone confirm? _________________ Glenn
Member #1009
#BlueSquare
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Mon May 23, 2022 6:08 pm Post subject: Re: Changing 40hp round boss to square boss |
im not sure you have to change the rocker assemblies. they are both 1.0 ratio unless the shaft blocks are different.
why not just buy a 10 dollar repair kit? easy and permanent fix. be aware tho. there are two styles.
If you must have different heads, buy some 1300 heads. bigger valves. both are 1 year onlies. _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP |
Glenn  Mr. 010
Posted: Mon May 23, 2022 6:24 pm Post subject: Re: Changing 40hp round boss to square boss |
Chickensoup wrote: |
why not just buy a 10 dollar repair kit? easy and permanent fix. be aware tho. there are two styles. |
Links?
I work mostly on 1600 based engines which is why i'm asking before moving forward. _________________ Glenn
Member #1009
#BlueSquare
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11243 Location: Oregon
Posted: Mon May 23, 2022 6:54 pm Post subject: Re: Changing 40hp round boss to square boss |
Time-sert or heli-coil.
I like the time-sert. You can buy them online. Or rent the tool and buy the time-serts from ACN.
This is an example. Not the specific tool for the round boss heads you are working on.
http://vwparts.aircooled.net/Time-Sert-Tool-Rental-5-16-24-0562-p/time-sert-rental-0562.htm _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Glenn  Mr. 010
Posted: Mon May 23, 2022 6:55 pm Post subject: Re: Changing 40hp round boss to square boss |
It actually broke the boss, so no timesert. _________________ Glenn
Member #1009
#BlueSquare
Posted: Mon May 23, 2022 6:59 pm Post subject: Re: Changing 40hp round boss to square boss |
Glenn wrote: |
It actually broke the boss, so no timesert. |
Well that kinda changes things, doesn't it?
Like you, I only work on 1600 based packages. Good luck searching. _________________ I have learned over the years.
Buy Once, Cry Once!
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3668 Location: Sarasota, in my adopted state of Florida
Posted: Mon May 23, 2022 7:56 pm Post subject: Re: Changing 40hp round boss to square boss |
Glenn wrote: |
Rocker assemblies Drill the bottom hole on the cube shaped rocker blocks bigger
Head studs I should have the two that are different
PushrodsSame
Intake manifold will fit the square boss heads
Can someone confirm? |
Measure the length you need for the head studs. The manifold will fit if it's a square boss 40hp head.
Dan |
RWK Samba Member
Posted: Mon May 23, 2022 8:08 pm Post subject: Re: Changing 40hp round boss to square boss |
FWIW, I pulled 40 hp rockers off a 1776 with CB big valve heads, one of the smaller problems it had!
ratios are different from 40 hp to 1300-1600, some 40 hp rockers, some if not all 40 don't have the oil hole to adjusting screw, and as you can see some are not welded shut, 40 hp arms don't have the 2 ribs on the top center of arm
_________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
RWK Samba Member
Posted: Mon May 23, 2022 8:16 pm Post subject: Re: Changing 40hp round boss to square boss |
Notice also the arm main beam on screw end is thicker on late arm then 40 hp arm, this was done to have room to drill oil hole through. May also have to change head studs for later heads (13-1600), Isn't there 40 hp sq. boss heads? or is that what your talking about? _________________ 73 Type 181
63 Type 113
Glenn  Mr. 010
Posted: Tue May 24, 2022 2:54 am Post subject: Re: Changing 40hp round boss to square boss |
Dan Ruddock wrote: |
Glenn wrote: |
PushrodsSame
Dan |
Dan,
Which studs are the problem? Too long or too short? _________________ Glenn
Member #1009
#BlueSquare
Posted: Tue May 24, 2022 4:53 am Post subject: Re: Changing 40hp round boss to square boss |
Not sure but I believe it is the two top row studs near the exhaust ports. A pic of the square 40hp head would help.
Ahh found a pic. all of the uppers are longer.
www.thesamba.com/vw/classifieds/detail.php?id=1714853 |
Glenn  Mr. 010
Posted: Tue May 24, 2022 6:16 am Post subject: Re: Changing 40hp round boss to square boss |
Here's the head.
Member #1009
#BlueSquare
Posted: Tue May 24, 2022 7:18 am Post subject: Re: Changing 40hp round boss to square boss |
Are there threads in the bore missing the mount on the left? If no threads, tap to size and screw in a mount like the one on the right. The one on the right has been converted.
FYI, when this conversion is done the valve clearance changes from .008" to .004"
https://www.thesamba.com/vw/classifieds/detail.php?id=2479064
Dan |
Glenn  Mr. 010
Posted: Tue May 24, 2022 7:40 am Post subject: Re: Changing 40hp round boss to square boss |
The insert was ripped out so there's nothing left. _________________ Glenn
Member #1009
#BlueSquare
Posted: Tue May 24, 2022 8:06 am Post subject: Re: Changing 40hp round boss to square boss |
Wow, I find that hard to believe. the threads are very large coarse threads. Somebody must have hacked it up when they taped it. I do have a set of early 40hp heads with the conversion already done. The engine was running when I pulled them off, but I have not done a thorough inspection of them. I have never seen a 40hp pull out the inserts, and yes I have rebuilt a number of them back in the day.
Glenn  Mr. 010
Posted: Tue May 24, 2022 8:12 am Post subject: Re: Changing 40hp round boss to square boss |
After some searching it seem the round boss has 177mm top studs and the square has 193mm. Assume both are 10mm. _________________ Glenn
Member #1009
#BlueSquare
Posted: Tue May 24, 2022 8:14 am Post subject: Re: Changing 40hp round boss to square boss |
Glenn wrote: |
After some searching it seem the round boss has 177mm top studs and the square has 193mm. Assume both are 10mm. |
Your assumption is correct. |
Glenn  Mr. 010
Posted: Tue May 24, 2022 8:15 am Post subject: Re: Changing 40hp round boss to square boss |
So new heads, 8 top studs and drill the rocker pedestals for the larger rocker studs is all that needs to be done. _________________ Glenn
Member #1009
#BlueSquare
Posted: Tue May 24, 2022 8:24 am Post subject: Re: Changing 40hp round boss to square boss |
Yes, you could also just put some 1500 1.1 rocker assemblies on it or swap out the rocker block for late ones. |
