tanhis Samba Member
Joined: July 23, 2005 Posts: 662 Location: Rauma Finland
Posted: Mon May 30, 2022 12:15 am Post subject: 2.1 DJ digijet idle computer relation to mixture |
So to go trough the complete story.
I bought the van 3 years back and previous owner had some shop do work on the EFI before me as he had issues with rough running.
Van ran fine but cold start was bit rough (not runnig on all four until you give a bit rpm) but after start there were no issues. Car passed the local emission test on first year no problem. Last year I needed to adjust the idle mixture a bit to get it trough. But this year there were not enough adjustment to get it running good.
I took out the injectors and checked the spray patterns and they were nice and even, also replaced the seals. I did not check the amount sprayed while on a car.
Also replaced the temp sensor to new VW item even the old one was in correct range.
Checked the compression pressures, all between 12-13bar, replaced and adjusted plugs, new rotor new dissy cap.
Found out that idle stabilizer did not affect the running of the car when wire removed, replaced the transistor on the idle computer.
After these car ran better then ever on idle, but the idle spiked from 900 to 1400 after I got the idle stabilizer to work.
Adjusted the idle from the throttle body back to 900 and car idle better then ever and cold start do not need assistance from the pedal anymore to get the car to run for first 30sec or so. But still it seems like it is not firing on all four on cold start and needs some rpm to get it running.
At this point I needed to take the emission test to keep the car on the road.
CO2 was still too high and idle mixture adjustment was not enough to compensate. I removed the wire from the idle stabilizer and got it trough the emission test by adjusting the idle mixture.
And now to the real question in digijet with out lambda sensor. How ECU controls the mixture?
Temp sensor, AFM, fuel pressure and idle computer controlling extra air. Or is there something else.
As I have started to think that the previous shop that worked on the car might have adjusted the AFM to compensate for the non functioning idle stabilizer and now that it is working again mixture is too rich. I was planning to install wide band lambda meter before I start to adjust but now just asking for advice before I do something stupid. _________________ -58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
RawUmber Samba Member
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10487 Location: Orbiting San Diego
Posted: Mon May 30, 2022 5:45 am Post subject: Re: 2.1 DJ digijet idle computer relation to mixture |
He says 2.1 DJ and that code DJ engine by definition includes a Digijet version of injection.
That also includes the separate vacuum/centrifugal ignition distributor setup like earlier Vanagons here have.
While the EPA approved gasoline engine Vanagons made for the USA/CA market have Cats and O2 sensors this wasn't the case for most T3 models built for other markets.
Mark |
tanhis Samba Member
Posted: Mon May 30, 2022 6:05 am Post subject: Re: 2.1 DJ digijet idle computer relation to mixture |
Thanks, I will go trough these and come back here if I can solve the issue with these.
And yes, europe had all kind of weirdness compared to america...or is it another way around so it is digijet as mentioned.
And as a sidenote I am not a stranger to flat fours but this shit is just too modern with injectors, air flow meters and water as a cooling. _________________ -58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-69 typ 2, 9 seater
hdenter Samba Member
Joined: October 14, 2008 Posts: 2962 Location: San Luis Obispo, CA
Posted: Mon May 30, 2022 6:48 am Post subject: Re: 2.1 DJ digijet idle computer relation to mixture |
I would also suggest that you look at the wiring harness. Poor connections and/or corrosion could be effecting the signal from the coolant sensor. The ground wire lug on the engine has also been a source of trouble for some.
Good Luck!
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
tanhis Samba Member
Posted: Mon May 30, 2022 8:30 am Post subject: Re: 2.1 DJ digijet idle computer relation to mixture |
| hdenter wrote: |
Good Luck!
Hans |
Good point, I have extra ground stap on my engine and i measure sensors etc directly from ecu plug to eliminate possible bad connections out. _________________ -58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-69 typ 2, 9 seater
