Tac hook up ?
QRP
QRP is offline
PostPosted: Thu Jun 02, 2022 9:30 am    Post subject: Tac hook up ? Reply with quote
A quick question here.
This tac came in a bug I just got but I'm not sure about the wiring, I don't see any pos or neg markings on it.
I am assuming the flat prong is pos and the round post goes to the coil.
Thanks in advance.
RCP Phx
RCP Phx is offline
PostPosted: Thu Jun 02, 2022 9:49 am    Post subject: Re: Tac hook up ? Reply with quote
I wouldn't assume anything. Why not just call them and ask them?
bsairhead
bsairhead is offline
PostPosted: Thu Jun 02, 2022 1:38 pm    Post subject: Re: Tac hook up ? Reply with quote
That would be my guess. I would put a 9v battery - side on case + side on flat tap and see if it lights. If it does that would be your connection to 58b on your light switch or piggy back from dash lights.
bsairhead
PostPosted: Thu Jun 02, 2022 2:45 pm    Post subject: Re: Tac hook up ? Reply with quote
I might be wrong, Is there a separate lamp holder?
QRP
QRP is offline
PostPosted: Thu Jun 02, 2022 4:48 pm    Post subject: Re: Tac hook up ? Reply with quote
Yes there is.
bsairhead
PostPosted: Thu Jun 02, 2022 4:55 pm    Post subject: Re: Tac hook up ? Reply with quote
My MG buddy says keyed hot on tab coil negative on lug and dash lights on insulated lamp holder and there should be a housing ground or the mounting stud.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jun 02, 2022 5:08 pm    Post subject: Re: Tac hook up ? Reply with quote
bsairhead wrote:
My MG buddy
Positive Earth?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
bsairhead
PostPosted: Thu Jun 02, 2022 5:21 pm    Post subject: Re: Tac hook up ? Reply with quote
Glenn wrote:
bsairhead wrote:
My MG buddy
Positive Earth?
Nope not all are positive earth. The posters picture even says negative earth.
bsairhead
PostPosted: Thu Jun 02, 2022 5:26 pm    Post subject: Re: Tac hook up ? Reply with quote
67 on are negative earth
Dale M.
Dale M. is offline
PostPosted: Fri Jun 03, 2022 7:31 am    Post subject: Re: Tac hook up ? Reply with quote
Found on i-net search...
http://www.mgb-stuff.org.uk/tach.htm
RCP Phx
RCP Phx is offline
PostPosted: Fri Jun 03, 2022 9:49 am    Post subject: Re: Tac hook up ? Reply with quote
I think right now you need to decide on it's worth! You don't even know if it works and it's age is very questionable? Where did you intend to mount it? There are 100's of new ones out there that are cheap and have many more options/features!
https://www.summitracing.com/parts/bgs-fst-7906
bsairhead
PostPosted: Fri Jun 03, 2022 10:13 am    Post subject: Re: Tac hook up ? Reply with quote
Smith's makes very good gauges and no new one is as cool.
67rustavenger
67rustavenger is offline
PostPosted: Fri Jun 03, 2022 11:32 am    Post subject: Re: Tac hook up ? Reply with quote
The tach is already mounted in the OP's dash. I saw pic of it in the HBB offroad forum.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
QRP
QRP is offline
PostPosted: Fri Jun 03, 2022 3:31 pm    Post subject: Re: Tac hook up ? Reply with quote
The tac was mounted in the dash when I got the car but I removed everything the previous ( tweaker ) owner had done, I didn't trust any of it.
Anyway I just don't wanna mess this tac up by wiring it up wrong.
And it will be tested before or if it goes back in.
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Sat Jun 04, 2022 7:58 am    Post subject: Re: Tac hook up ? Reply with quote
Worth mounting just for the NEGATIVE EARTH logo!
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
