Lightening any and everything …
Page: 1, 2, 3, 4, 5  Next
BFB
BFB is offline
PostPosted: Sat Jul 09, 2022 8:33 am    Post subject: Lightening any and everything … Reply with quote
There’s a lot of threads on lightened flywheels and a few on lightening reciprocating parts but those seem mostly to be about balance things out. So i thought a thread on what you’ve done or seen done to lighten parts n pieces might be interesting, whether it worked or didn’t or even good or bad ideas.
I’ll start with a couple pics i found, i know i have pics of other stuff but not on this device..
3297 grams is about 7.25lbs
Most experts aren't.
vwinnovator
vwinnovator is offline
PostPosted: Sat Jul 09, 2022 8:41 am    Post subject: Re: Lightening any and everything … Reply with quote
cool stuff, but when is too light TOO light??
FarmerBill Premium Member
FarmerBill is offline
PostPosted: Sat Jul 09, 2022 9:03 am    Post subject: Re: Lightening any and everything … Reply with quote
When it breaks before the race ends. Wink
vwracerdave
vwracerdave is offline
PostPosted: Sat Jul 09, 2022 9:17 am    Post subject: Re: Lightening any and everything … Reply with quote
richardcranium is back.
Is has been determined by many VW engine builders the last 40 years that a 12 1/2 Lb. flywheel works the best for a street driven VW engine. Anything less doesn't allow the engine to be driven smoothly on the streets. It also has an effect on shifting as the synchro's have a difficult time keeping up, and will cause them to wear out sooner. If you remove too much PP material, it will overheat and warp with aggressive clutch use.
Those lightened flywheels were an old school Formula Vee trick back when they raced stock 1200cc.
QRP
QRP is offline
PostPosted: Sat Jul 09, 2022 9:22 am    Post subject: Re: Lightening any and everything … Reply with quote
LMAO !!!
BFB
BFB is offline
PostPosted: Sat Jul 09, 2022 11:12 am    Post subject: Re: Lightening any and everything … Reply with quote
QRP wrote:
LMAO !!!
What the fuck makes you think he left?
Anymore , vwracerdave, i look forward to your negative - naysayer comments as i am in awe of your ability to rain on anyone’s parade on any subject.
Vanapplebomb
Vanapplebomb is offline
PostPosted: Sat Jul 09, 2022 11:41 am    Post subject: Re: Lightening any and everything … Reply with quote
Richard, don’t be surprised that a lot of people have a negative reaction to your posts.
Also, why did you change your forum name?
1800 Type 4 Berrien 295
vwracerdave
PostPosted: Sat Jul 09, 2022 11:50 am    Post subject: Re: Lightening any and everything … Reply with quote
BFB wrote:
QRP wrote:
LMAO !!!
I gave you a serious response to your inquiry about a lightened flywheel.
BFB
BFB is offline
PostPosted: Sat Jul 09, 2022 2:47 pm    Post subject: Re: Lightening any and everything … Reply with quote
Just a change in life. And 19 years ago i started my bodyshop as Ben’s Fabrication & Bodywork’s ( BFB ) i changed the name pretty soon on but BFB was brought up as a joke as Ben’s F#*@cking Buggy’s, so i decided recently to recreate BFB as such and have some fun with it.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Jul 09, 2022 4:17 pm    Post subject: Re: Lightening any and everything … Reply with quote
Moderators Note: "DON'T post personal attacks"
Remember it's easier for me to simply delete the entire topic than clean it up.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
BFB
BFB is offline
PostPosted: Sat Jul 09, 2022 6:11 pm    Post subject: Re: Lightening any and everything … Reply with quote
Here’s something cool. and some of you will probably remember seeing this in a thread a “few” years ago…
Mr. 010
Glenn is offline
PostPosted: Sat Jul 09, 2022 6:16 pm    Post subject: Re: Lightening any and everything … Reply with quote
Stupid questions:
Is any of this practical? Meaning does it last more than 1 rpm?
What are the application for this extreme machine work?
Porsche 917 key
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Chickensoup
Chickensoup is offline
PostPosted: Sat Jul 09, 2022 7:26 pm    Post subject: Re: Lightening any and everything … Reply with quote
Bad chemistries brah Shocked simple math.
Example 1: Dude 1 insults dude 2 for no real reason expecting himself to be crowd surfed and worshiped = bad outcome
Example 2: Dude 1 gives dude 2 helpful criticism from the heart based off words of knowelege hoping to better the life of a brother = good outcome.
Choose your master.
'65 Tourist Delivery Build
'66 RIP
Vanapplebomb
PostPosted: Sat Jul 09, 2022 8:15 pm    Post subject: Re: Lightening any and everything … Reply with quote
Lately, my focus has been on valve train. My next build I am looking at hollow stem 8mm valves, or solid 7mm valves. Also light pushrods (aluminum) and valve springs. Currently looking at a set of Comp Cams beehive springs. I would love to find a light conical spring, but those are harder to come by. Several out there, but haven’t quite found one that fits the bill. A bit harder to fit without cutting the guide boss…which I refer not to remove material from unless I absolutely have to. I am pretty confident I can run an 86B cam up to 7k rpm with a beehive spring that actually has the same or less seat load than the stock springs. With conical springs, I could probably go as low as 90Lbs on the seat and easy rev to 7k rpm with no issues.
Chickensoup
PostPosted: Sat Jul 09, 2022 8:33 pm    Post subject: Re: Lightening any and everything … Reply with quote
I once said what you said but then I got mobbed up on and recieved some pretty rude and harsh PM's Laughing
I'm sure you know this. I think. But in case you don't, Dan Ruddock sells beehive kits for t1 and t4. Idk where/hoe he makes them, but folks seem to love them.
'66 RIP
DerrickfromNC1
DerrickfromNC1 is offline
PostPosted: Sat Jul 09, 2022 9:14 pm    Post subject: Re: Lightening any and everything … Reply with quote
Here’s a recent thread discussing the use of single valve spring with a lightweight valve train.
https://www.thesamba.com/vw/forum/viewtopic.php?t=766305
vwracerdave
PostPosted: Sat Jul 09, 2022 10:02 pm    Post subject: Re: Lightening any and everything … Reply with quote
Glenn wrote:
Stupid questions:
Those swiss cheese rods and flywheel are probably from a 40 horse 1200cc Formula Vee engine that might have 57 HP.
Probably wouldn't make it around the block on a typical 2276cc 170 HP street engine.
Howard 111
Howard 111 is offline
PostPosted: Sun Jul 10, 2022 1:05 am    Post subject: Re: Lightening any and everything … Reply with quote
One modification that's overlooked most of the time is lightening the wrist pins. It's a cheap and easy modification that takes weight off of a place that really matters, yet doesn't take away from the durability. I've always run them in all drag, and hot street cars, and run them in my current turbo street Ghia.
There are venders, or any machine shop can do it.
1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270
raygreenwood
raygreenwood is offline
PostPosted: Sun Jul 10, 2022 5:00 am    Post subject: Re: Lightening any and everything … Reply with quote
Probably the most effective "lightening" I have seen......ditch the unused seats, the spare tire....and the make the driver dump 30 pounds. The effects are amazing!
Laughing
Ray
Dan Ruddock
Dan Ruddock is offline
PostPosted: Sun Jul 10, 2022 5:26 am    Post subject: Re: Lightening any and everything … Reply with quote
FYI, the only part I make or should I say have made for me is the retainers. They are made locally for me here in Florida by three different places. One shop machine's them out of 4140 chromoly, the other heat treats them and then the last coats the with black oxide. I mod the keepers myself. The other parts?? I searched high and low for the most suitable parts for our app. The retainer is the key part to make use in a Volkswagen so much more practical and easier to install and use standard length valves.
One more key point on weight reduction, with a progressively wound spring, the effective weight of the spring at max/close to max lift is reduced in about half because the majority of the coils are stacked on top of each other and are not moving at all until the lift is reduced. Some beehives on the market are not wound this way so be careful if you want to hobble together your own setup. This progressive wind is also fantastic in reducing harmonics. Stock VW springs are also progressively wound but are completely inadequate in a performance app.
Dan
Page 1 of 5
