Engine ID help
js99nielsen
js99nielsen is offline
PostPosted: Sat Aug 06, 2022 8:49 pm    Post subject: Engine ID help Reply with quote
Can anyone help me ID an engine. There is only "14" stamped on the generator stand below the firing order casting. The engine is in a 1950 vw powered tempo matador which originally came with a 25 hp. Thanks.
'50 Tempo Matador (VW powered)
'65 Type 34
'65 dove blue doublecab
'89 Porsche 911 Carrera Targa ROW
'67 #1 SO-42 pearl white poptop walkthru...sold, shoulda kept
'63 beige gray/swr 15 window deluxe...sold, shoulda kept
'67 #2 SO-42 pearl white poptop walkthru...sold, shoulda kept
'67 #3 SO-42 pearl white poptop walkthru...sold, shoulda kept
'64 turquoise kombi...100% original, O rust...sold, shoulda kept
js99nielsen
PostPosted: Sun Aug 07, 2022 8:21 am    Post subject: Re: Engine ID help Reply with quote
Could no number mean it is the original engine?
'65 Type 34
sgmalt46
sgmalt46 is offline
PostPosted: Sun Aug 07, 2022 3:54 pm    Post subject: Re: Engine ID help Reply with quote
looks like an aluminum case . believe they where used to early 50 ?
see if it has casting dates. that may be a clue. or replacement case .
is it complete? heads and tin are different 25hp vs. 36hp.
that will tell you more. or try a different forum. other vw vehicles / volksrods.
maybe better luck there. not to many of those around. cool ride.
Steve
55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG
busdaddy
busdaddy is offline
PostPosted: Sun Aug 07, 2022 4:57 pm    Post subject: Re: Engine ID help Reply with quote
That's a question for Tempo experts to answer, did they use bespoke non numbered engines?, or industrial models for their builds?, unless that's a replacement case it's safe to say it likely wasn't previously installed in a VW car.
Does #14 show up in any of the Tempo's numbers?
Слава Україні!
js99nielsen
PostPosted: Sun Aug 07, 2022 7:08 pm    Post subject: Re: Engine ID help Reply with quote
Thanks guys. This started in another forum but Everett moved it here saying I would probably get more traction.
I've checked with the Tempo crowd and the thought (only comment I received) is it may be original but there is only so many Tempo owners and likely many of their vehicles had the engine replaced at some point.
The engine is complete and still installed in the Tempo. Where would casting dates be and what tin differences should I look for?
'65 Type 34
js99nielsen
PostPosted: Sun Aug 07, 2022 7:30 pm    Post subject: Re: Engine ID help Reply with quote
Here are a couple photos...left and right side of the motor:
'65 Type 34
FarmerBill Premium Member
FarmerBill is offline
PostPosted: Sun Aug 07, 2022 8:16 pm    Post subject: Re: Engine ID help Reply with quote
Casting dates should be just under the fuel pump boss and on the left side of the generator pedestal.
56samba
56samba is offline
PostPosted: Sun Aug 07, 2022 11:29 pm    Post subject: Re: Engine ID help Reply with quote
Depending on the age of your engine case (up to early 1950 cases), you may find the casting dates behind the dizzy and generator stand, albeit covered by the fan shroud.
sgmalt46
sgmalt46 is offline
PostPosted: Mon Aug 08, 2022 7:28 am    Post subject: Re: Engine ID help Reply with quote
25hp for sure. very cool. looks to have all the correct stuff.
64 crew cab
55 rag top beetle
66 beetle
js99nielsen
PostPosted: Mon Aug 08, 2022 11:06 am    Post subject: Re: Engine ID help Reply with quote
Thanks everyone. I'll do more digging and let you know what I find. I many need to lift the cab off to get better access and clean things up. The engine still has oil in it and is not seized which is cool.
A pic when she was delivered to me (Germany to Uruguay to the Netherlands to me).
'65 Type 34
js99nielsen
PostPosted: Mon Aug 08, 2022 3:15 pm    Post subject: Re: Engine ID help Reply with quote
Found it! Tempo stamps the number between the fan housing and clutch.
If you can't read them...the casting on the generator stand is 4-8-20 and the engine number is 121-0220477
'65 Type 34
sgmalt46
sgmalt46 is offline
PostPosted: Mon Aug 08, 2022 3:35 pm    Post subject: Re: Engine ID help Reply with quote
looks like a winner casting date 4th day 8th month 2nd production shift 1950 Applause
congrats. 121- must be a matador thing. 122 is industrial. no other vw
stamped the number there except type-3's probably easier to see due to the design .
i think there is only 10 or so known in existence. only made a few hundred.
Steve Very Happy
64 crew cab
55 rag top beetle
66 beetle
js99nielsen
PostPosted: Mon Aug 08, 2022 3:47 pm    Post subject: Re: Engine ID help Reply with quote
I got a little more input from the Tempo crowd and found out where to look.
Because of the way the engine is mounted in the cab it was really difficult to see the numbers where they typically would be stamped for VW so Tempo had them stamped there on top of the clutch housing.
The Tempo guy I've been working with ran the numbers and confirmed it is the original engine & transmission! He also said he doesn't know of any (tempos) that have had the original engine. I'm pretty excited!
'65 Type 34
busdaddy
busdaddy is offline
PostPosted: Mon Aug 08, 2022 4:06 pm    Post subject: Re: Engine ID help Reply with quote
js99nielsen wrote:
I'm pretty excited!
I would be too!, congratulations! Cool
Слава Україні!
PostPosted: Mon Aug 08, 2022 4:08 pm    Post subject: Re: Engine ID help Reply with quote
Sweet!
js99nielsen
PostPosted: Mon Aug 08, 2022 8:11 pm    Post subject: Re: Engine ID help Reply with quote
Now my next question...recommendations for an engine re-builder? Obviously this engine just became important to me so I want someone reputable, reliable and experienced in these early motors. Someone in the PNW would be awesome so I can deliver it myself.
'65 Type 34
kalymnos Premium Member
kalymnos is offline
PostPosted: Sun Aug 21, 2022 4:43 am    Post subject: Re: Engine ID help Reply with quote
Very very cool find: a 1950 Tempo Matador with matching engine!
Today I found an ad for the original paperworks for a 1950 Tempo, engine no. 121-0207503
50 split
50 split is offline
PostPosted: Sun Aug 21, 2022 11:57 pm    Post subject: Re: Engine ID help Reply with quote
I'm sorry to say, but the 2 oldest known to public with pictures, is located in Sweden, and both have the original matching numbers for the car/chassiesnumbers.
There are some more 1950 tempo matador pickup's in sweden (at least 4 other than the 2 with og motor. But this other 4 cars does not (as far as I know) have og number matching engine.
#Sawmillcollection
Kübel: 43 w Pepco
type 1: 50, 51 (kab), 51, 52(zwitt), 56, 57, 58, 60, 60, 61, 63, 63, 64, 65, 72
type 2: 51, 54 Taxi (H-O -26), 54, 56, 58, 65 (Fridge), 67(bay) 68, 68, 70, 70 (Burnt westy), 70 westy,71 westy 72, 73, 73, 75, 96, 96 Carthago, 01 Syncro , 2017
type 3 N: 62, 63 V: 62, 66, 67, 67, 68, F: 66 (Teak), 67
Type 4 2 door 71
Tempo: Matador 50(oldest)
Porsche: 356 65, 924 78
Anhänger:
Eriba Puck 65
Alfredo 59
Trailer Fickers So22, 65
Trailer 60
js99nielsen
PostPosted: Thu Sep 29, 2022 4:38 pm    Post subject: Re: Engine ID help Reply with quote
Thanks for the info 50 split. Knowing there are 2 others with original engines does not dampen my excitement about mine. I'm actually glad there are others. These are awesome vehicles and the more that come to light for people to appreciate the better.
Now, do you have any spare parts? 😁
'65 Type 34
