Rust & rocker panel replacement
pushkick
pushkick is offline
PostPosted: Sun Aug 21, 2022 8:45 pm    Post subject: Rust & rocker panel replacement Reply with quote
I am replacing my rocker panel & am trying to use 3m panel bonding adhesive. Is the rocker panel considered a structural member. Is it ok to use panel adhesive?what about side panel? Or should I spot weld?
Any help is appreciated.
i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
1990 vw automatic camper
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Aug 21, 2022 9:00 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
panel bond is NOT for use in this application.
time to bust out the welder
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
dobryan
dobryan is offline
PostPosted: Mon Aug 22, 2022 6:03 am    Post subject: Re: Rust & rocker panel replacement Reply with quote
Got a pic of what you need to replace?
Dave O
The Western Syncro build
DuncanS
DuncanS is offline
PostPosted: Mon Aug 22, 2022 6:45 am    Post subject: Re: Rust & rocker panel replacement Reply with quote
No photos, no responses, no advice.
Duncan
pushkick
pushkick is offline
PostPosted: Mon Aug 22, 2022 8:19 am    Post subject: Re: Rust & rocker panel replacement Reply with quote
Will post pics as soon as I am able. I am replacing outer rocker panel not inner rocker panel, I assume the inner is structural but outer dosent seem to be.
I will take more pics of current work asap.
pushkick
pushkick is offline
PostPosted: Mon Aug 22, 2022 8:35 am    Post subject: Re: Rust & rocker panel replacement Reply with quote
Rocker panel view need to zoom pic to see
pushkick
pushkick is offline
PostPosted: Mon Aug 22, 2022 12:18 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
Latest pic
outcaststudios
outcaststudios is offline
PostPosted: Mon Aug 22, 2022 12:59 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
both are structural especially since the trailing arm also ties in at the same point. i just made a batch of rocker skins for a VW guy local who does a ton of repair work, my suggestion is to mig them in with lots of littel tack welds, not overheating is the most importnat thing. if you miss a weld just move on to the next one and allow the missed weld to fully cool before you try to hit it again. good luck.
'88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791
pushkick
pushkick is offline
PostPosted: Mon Aug 22, 2022 4:45 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
Would you be interested in making some panels out of ss?
pushkick
pushkick is offline
PostPosted: Mon Aug 22, 2022 5:01 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
Is side panel structural or can it be glued? Only replacing from waist down to rocker panel.
outcaststudios
PostPosted: Mon Aug 22, 2022 6:43 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
my buddy who runs a shop had me make just the skin about 4 inches up, as that is the most common area to go bad, i used really nice, high carbon steel sheet, stainless is total overkill, but if you want to pay to have them made id be down, its pricey. i made a run of about 25 skins last time. they fit perfectly and the lip that hangs down is the proper length , as opposed to some other more common panels i have purchased where you have to buy a larger section and cut out what you need for that area ,those usually have a lip that is a bit longer and then needs trimmed. these dont. we sell tehm to him for about 75$ each which is slightly more expensive than some others available, easier install and less cleanup afterwards.
'88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
outcaststudios
PostPosted: Mon Aug 22, 2022 6:50 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
when you say 'side panel' i assume you mean on the drivers side above the rocker skins? that is not structural,there are internal pieces, but its a large flat area ( larege flat areas dont like to be welded too hot or they buckle and twist) and the lower seam is an entry point for water/rot over time,so i use seam sealer on them, still doesnt hurt to tack everything in place , especially considering that they are tin cans on a good day. the stronger the better. also the internal rocker skin should be addressed while you have the outer skin off.
'88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
pushkick
pushkick is offline
PostPosted: Mon Aug 22, 2022 8:00 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
How much for a ss prototype skin?
Where you located?
Mateo83
Mateo83 is offline
PostPosted: Tue Aug 23, 2022 2:24 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
metallurgy of SS to carbon steel is different. Make sure you research welding the 2 together, 309 wire etc.
83 Air-cooled 2.0 Tin Top
outcaststudios
PostPosted: Tue Aug 23, 2022 4:01 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
we cant really make just one, i mean we can but you'd have to buy a full sheet,pay for the time setting up the break and shear etc, and would end up paying a lot more. im on the east coast,back and forth between Maine and Pa.
'88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
pushkick
pushkick is offline
PostPosted: Sat Aug 27, 2022 3:39 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
316 ss give me a price. By the time I remove old panel repair what has rusted then rust primer/ encapsulate paint. Your price can't be all that expensive. I am willing to pay more never to do this again.
pushkick
pushkick is offline
PostPosted: Fri Sep 16, 2022 5:39 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
Would you use 3m structural adhesive(07333) on outer rocker panel instead of spot welding?
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Sep 16, 2022 10:27 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
NO
that is used in conjunction with spot welding. from the TDS sheet:
14. Perform Squeeze Type Resistance Spot Welding in appropriate areas while
the adhesive is uncured. DO NOT attempt to MIG weld through the
adhesive. Set rivets or other fasteners while the adhesive is still uncured,
typically within 2 hours of adhesive application.
if you want to do a proper repair get it out of your head you are going to glue this thing back together. it's not a 1:24 model kit
Jake Raby wrote:
Brian wrote:
Sodo
Sodo is offline
PostPosted: Fri Sep 16, 2022 10:28 pm    Post subject: Re: Rust & rocker panel replacement Reply with quote
I don't think it makes sense to use SS skin.
It could be a can of worms that sacrifices other sections of the van (as the next cathode).
Better to just use steel, seal it well, and ensure the wetness problem is solved.
It's either water leakage or condensation that's unable to dry.
Condensation problems require better ventilation.
....KTMs, GasGas, SPOT mtb
pushkick
pushkick is offline
PostPosted: Sat Sep 17, 2022 6:16 am    Post subject: Re: Rust & rocker panel replacement Reply with quote
skills@eurocarsplus wrote:
NO
If I am going to spot weld the outer rocker panel to the inner rocker panel . The only place this is possible is the bottom flange/lip where the 2 panels meet. The side flanges where they join other panels & the top portion which joins to side panel could be glued? Are you saying use adhesive then spot weld before glue sets on the bottom flanges? This is my first attempt at this dont want to have to do all over again due to screwing things up. Any advice is appreciated.
