EverettB  Administrator
Joined: April 11, 2000 Posts: 71609 Location: Phoenix 602
Posted: Sun Mar 21, 2021 9:04 am Post subject: Re: Porcelain Enamel Sign Fest |
RalphMH wrote: |
I have made one number unrecognizable in each case, because I want to see in case my scans are used somewhere else. Sorry  |
I'm not sure what this means, one of the numbers above is incorrect?
Maybe post the correct information here in your text - That way you can still see if the images show up elsewhere but the actual dimensions are here for people to reference. _________________ How to Post Photos
srfndoc Samba Member
Posted: Sun Mar 21, 2021 5:54 pm Post subject: Re: Porcelain Enamel Sign Fest |
RalphMH wrote: |
No signs, but original dimension sheets from the 1950s. These were available from the VW advertising department for those who wanted to make their own signs or facade decorations.
These were also available in a VW dealer issued brochure called "VW Standards for External Marketing".
_________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
RaMilHa Samba Member
Posted: Fri Apr 02, 2021 2:09 am Post subject: Re: Porcelain Enamel Sign Fest |
A = 35
B = 14
C = 2,5 %
Jos.Hall Samba Member
Joined: January 29, 2011 Posts: 348 Location: Sunny So Cal.
Posted: Sun Aug 21, 2022 9:42 pm Post subject: Re: Porcelain Enamel Sign Fest |
I picked up this beaut not too long ago My first and definitely a keeper.
_________________ PM ME TO ADD YOUR '67 TO THE '67 BUG REGISTRY!!!!
https://vintagejalopy.com/67bugregistry/vwbugregistry1967_view.php
'67 L41 Sedan 117333192
'67 L41 Vert 157343589
'67 L19K Vert 157452166
'67 L19K Vert ??????
'67 L282 Vert 157419653
'67 L620 Sedan 117534350 (Sold)
'67 L54 Vert 15745800 (Parted out)
'52 Split based Devin |
Posted: Mon Aug 22, 2022 8:14 am Post subject: Re: Porcelain Enamel Sign Fest |
Nice get. Not a lot of traffic on this thread lately but I know of many signs that have changed hands in the last year or so. Pricing seems to have gone up as well (like everything). _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
hoffvw Samba Member
Posted: Tue Sep 06, 2022 8:58 am Post subject: Re: Porcelain Enamel Sign Fest |
Jos.Hall wrote: |
Watched that on shopgoodwill.com, and should have set my high bid higher. Glad to see it went to someone who appreciates it. |
Posted: Fri Sep 09, 2022 9:48 am Post subject: Re: Porcelain Enamel Sign Fest |
Thanks Hoff, I was definitely willing to go way higher than it went but was pleasantly surprised. Unfortunately they didn't do a good job shipping it and some of the porcelain on the corners was chipped in shipping I decided not to complain too much as it's perfect for me and my needs. _________________ PM ME TO ADD YOUR '67 TO THE '67 BUG REGISTRY!!!!
hoffvw Samba Member
Posted: Fri Sep 09, 2022 10:29 am Post subject: Re: Porcelain Enamel Sign Fest |
Agreed. There are some good deals on there, if you watch. I was stunned when the sign showed up. Sorry to hear about the shipping, it's hit or miss. |
otherbeach Samba Member
Joined: September 15, 2016 Posts: 282 Location: Wisconsin !
Posted: Thu Nov 03, 2022 1:39 pm Post subject: Re: Porcelain Enamel Sign Fest |
I don't like to see reddish rust on signs. It makes me suspicious of the aging. Thank you for pointing out that they are repos. I am considering using paint thickness meters to start documenting known old vs. something I am examining. China and India are getting good at faking signs.
srfndoc wrote: |
Wanted to post these for awareness. These were for sale recently (the guy had three of them) and were being sold as reproductions (and priced accordingly):
These use an original makers mark but were definitely made much later (probably in the 80's/90's). Either way, cool looking reproduction sign. |
_________________ Coming to you from God’s Own Time Zone: Central Time…up near the Illinois/Minnesota border. ** Note I am currently (mostly) INACTIVE in the bus community due to life changes. My price tracking from 2016 to 2021 is now over and data stored offline. Unfortunately I am unable to query this archived data now. **
"Cows at the border of the Dairy State and the Land of Lincoln are remarkably honest." |
Posted: Thu Nov 03, 2022 3:01 pm Post subject: Re: Porcelain Enamel Sign Fest |
Orange rust is definitely a clue. I know of at least two of the old sign makers that are back in business and will make any sign you want so you need to be careful. I really wish you could say the new ones use a new makers mark but as you can see in this sign, they used an original makers mark so that's not a guarantee any more. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Fri Nov 03, 2023 1:19 am Post subject: Re: Porcelain Enamel Sign Fest |
I've never seen another Boos & Hahn sign so I figured I'd post this one here.
Posted: Fri Nov 03, 2023 7:27 am Post subject: Re: Porcelain Enamel Sign Fest |
Jos.Hall wrote: |
Cool find! I've seen that makers mark on lots of non-vw signs but this is the first vw.
Here it is on a non-vw sign:
Here is an NOS VW sign made by Boos Hahn with the corresponding sticker on the back:
This VW sign has the same font style as yours and I think came out of Canada:
Posted: Sun Nov 12, 2023 6:46 pm Post subject: Re: Porcelain Enamel Sign Fest |
srfndoc wrote: |
Srfndoc, Thanks for the response. I knew that they did a lot of advertising signs back in the 50s and they go all the way back to the teens so I was confident that the sign was legit. It was just a matter of making sure it arrived here safely from Hungary.
Here is a photo of the sign after I took some Bar Keepers Friend to remove the stubborn grease stains.
Posted: Thu Nov 16, 2023 2:40 pm Post subject: Re: Porcelain Enamel Sign Fest |
Jos.Hall wrote: |
srfndoc wrote: |
That cleaned up well. I've had many signs shipped over and its always nerve wracking. Fedex seems to be the best for stuff coming from Europe with the local post delivery services a total crap shoot. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
drG60 Samba Member
Posted: Thu Nov 21, 2024 10:21 am Post subject: Re: Porcelain Enamel Sign Fest |
Hello, I bought an old enamel sign from an antique dealer. He claimed that it was from the States and from around 1960. Unfortunately, I can't find anything about this sign and am now a bit suspicious. Has anyone ever seen a sign like this with this type of font? The letter C looks very modern, doesn't it?!? Or?!
30cm x 40cm
Posted: Thu Nov 21, 2024 11:34 am Post subject: Re: Porcelain Enamel Sign Fest |
Based on the condition and the shape/size of the sign I would say its a reproduction. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2550 Location: Australia
Posted: Thu Nov 21, 2024 2:28 pm Post subject: Re: Porcelain Enamel Sign Fest |
drG60 wrote: |
30cm x 40cm
Due to the size and the incorrect font used, I would say it is a reproduction. _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
Posted: Thu Dec 19, 2024 11:04 am Post subject: Re: Porcelain Enamel Sign Fest |
More fake VW dealer signs popping up on eBay. Pretty easy to identify if you know what to look for but buyer beware.
This ad was from a seller with 100's of other "vintage" signs so I'm guessing he's pushing a lot of fake signs (not just VW). _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
vwraymund Samba Member
Joined: October 31, 2006 Posts: 163 Location: Tilburg, The Netherlands
Posted: Sun Mar 16, 2025 11:19 am Post subject: Re: Porcelain Enamel Sign Fest |
Your thoughts?
_________________ Check out www.oldvw.nl
For parts and more. |
Posted: Sun Mar 16, 2025 12:12 pm Post subject: Re: Porcelain Enamel Sign Fest |
vwraymund wrote: |
Your thoughts?
Reproduction. The guy selling these has stated that in the past as well. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
