Steering gear rebuild or replace?
doug bugg
doug bugg is offline
PostPosted: Sat Sep 17, 2022 10:20 am    Post subject: Steering gear rebuild or replace? Reply with quote
I have a few other things to check on my ‘68 but if my gearbox is the issue should I replace or rebuild? It looks to be original and the roller shaft adjustment screw is stripped at the top. I’ve used threadlock to help keep the nut in place.
If I outright replace the gear unit, is there a brand that I should go with or “steer” clear of?
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sat Sep 17, 2022 11:44 am    Post subject: Re: Steering gear rebuild or replace? Reply with quote
Rebuild what you have. All of the boxes are worn out, so you would need to rebuild anything you buy used. Some of the rebuilt ones need rebuilding once you get them. Might as well start off with the one you know. Start with a cover from a used steering box!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
OTTO 1303
OTTO 1303 is offline
PostPosted: Sat Sep 17, 2022 1:34 pm    Post subject: Re: Steering gear rebuild or replace? Reply with quote
If it is the OG, rebuild first.
If it is so bad that it can’t be rebuilt, buy another used OG and rebuild that one, or a used OG that is already rebuilt.
Good Luck
74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG
16 R-Line
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Sat Sep 17, 2022 2:19 pm    Post subject: Re: Steering gear rebuild or replace? Reply with quote
Everything is an option now.
Thread on rebuilding your box: https://www.thesamba.com/vw/forum/viewtopic.php?t=660446
You can buy TRW tooling ones here:
https://www.thesamba.com/vw/classifieds/detail.php?id=2554601
Rebuild kits are also available:
https://www.thesamba.com/vw/classifieds/detail.php?id=2554386
Starbucket
Starbucket is offline
PostPosted: Sat Sep 17, 2022 3:02 pm    Post subject: Re: Steering gear rebuild or replace? Reply with quote
There are two adjustment points on the steering box, the obvious one and the Big nut on the front, so make sure you have adjusted them all before rebuilding.
viiking
viiking is offline
PostPosted: Sat Sep 17, 2022 4:29 pm    Post subject: Re: Steering gear rebuild or replace? Reply with quote
I rebuilt my original 68 steering box. 54 years old and still in good shape. It's not nuclear science. Check the worm and roller for damage, bearings and replace the seals. It is really great to look at these old parts that have been over engineered and when clean look like new. The damage is usually caused by people incorrectly tinkering with the adjustment screw, not the parts themselves.
Seals are available from bearing supply houses. Your cover plate if damaged should be replaced. Use John Deere Corn Head grease to repack the steering box. Not EP oil, not wheel bearing grease. You need a grease that thins under shear (movement) and returns back to a semi-solid when not under shear.
Or buy from the advertisement posted.
From what I have heard, all the after-market units are problematic and out of the box are usually more defective than the original part that you are trying to repair.
VWNOS.com
heimlich is offline
PostPosted: Sat Sep 17, 2022 4:59 pm    Post subject: Re: Steering gear rebuild or replace? Reply with quote
That's not the case anymore.
baldessariclan
baldessariclan is offline
PostPosted: Mon Sep 19, 2022 7:17 am    Post subject: Re: Steering gear rebuild or replace? Reply with quote
Hey, so what is the story on the "TRW tooling" steering boxes currently offered? Are these new steering boxes originally suppled from TRW, and then rebuilt by somebody else with correct quality components and adjustments? Just curious...
VWNOS.com
heimlich is offline
PostPosted: Mon Sep 19, 2022 7:49 am    Post subject: Re: Steering gear rebuild or replace? Reply with quote
TRW stopped making boxes. I was looking for a replacement box and was looking at tooling up to make the parts. A manufacturer dropped in my lap. I sent the box to a steering rebuilder to look over. Long story short - the boxes are as good, if not better, than TRW. These are new boxes.
viiking
viiking is offline
PostPosted: Mon Sep 19, 2022 4:39 pm    Post subject: Re: Steering gear rebuild or replace? Reply with quote
From your ad
This steering gearbox is the best on the market. It is made from TRW template. It is better than TRW as it has items in it that TRW removed in the past. The old TRW boxes also needed to be rebuilt when new. These do not. There is quality assurance on my end to make this box ready to bolt onto your car.
Not to be a pain, but your explanation is inconsistent. In your ad you say "the boxes are as good if not better than the TRW". and here you say "the old TRW boxes also needed to be rebuilt when new".
In short you need to remove "as good if not better" to just better in your ad.
Cusser
Cusser is offline
PostPosted: Mon Sep 19, 2022 5:48 pm    Post subject: Re: Steering gear rebuild or replace? Reply with quote
Myself - I would buy from Heimlich, he knows his stuff.
VWNOS.com
heimlich is offline
PostPosted: Mon Sep 19, 2022 6:06 pm    Post subject: Re: Steering gear rebuild or replace? Reply with quote
The TRW boxes were good for parts. You could take them apart and rebuild them with the same parts and make them really good. They just needed to be rebuilt. My box would still be just a little bit better as they put back some parts that TRW had removed. It does not have the TRW name on it. It's also good out of the box and doesn't need to be rebuilt. TRW had a really good name behind them. So are the two equal, is one better than the other, etc is hard to say. A lot of people would buy TRW just for the name. People now just want a good box without having to filter through all of the crap that is out there. From your comments it looks like you've seen a bit of this.
How to quantify the above is not so straight forward so I stand by my choice of words. I appreciate your comments.
chris914x181
chris914x181 is offline
PostPosted: Tue Apr 04, 2023 1:50 pm    Post subject: Re: Steering gear rebuild or replace? Reply with quote
I'm interested in replacing my +25 year old TRW gearbox. It feels fine but has leaking seals that are covering everything in grease.
What are the parts you put back in yours that TRW took out?
1972 2.0L Porsche 914 Autocrosser
1973 2017 VW Thing
1974 2.0L Porsche 914
1986 Skateboard
2004 7.4L Roadtrek Versatile
http://www.cassidy-online.com
VWNOS.com
heimlich is offline
PostPosted: Tue Apr 04, 2023 2:00 pm    Post subject: Re: Steering gear rebuild or replace? Reply with quote
The top bushing was put back in. Here's a writeup on it: https://www.thesamba.com/vw/forum/viewtopic.php?p=10000050
chris914x181
PostPosted: Tue Apr 04, 2023 3:31 pm    Post subject: Re: Steering gear rebuild or replace? Reply with quote
For clarification are any of these things done to ones that you're selling?
OKType3Tim wrote:
Using those items, along with original FAG bearings, new gasket, double lip seals, and corn head grease; I assembled the unit in the far right of the picture.
1973 2017 VW Thing
1986 Skateboard
