Vanagon A/C 50 amp fuse substitute?
RobdogAles
RobdogAles is offline
PostPosted: Sat Sep 24, 2022 10:26 am    Post subject: Vanagon A/C 50 amp fuse substitute? Reply with quote
The 50 amp fuse for the a/c in my van has gotten to the point is has oxidized and become weak. Replacing a relay I touched it and it split nearly in half. Looking online I can find heaps of these for about 50 cents ea and $20 in shipping.
Is there any reason I can't simply replace this strip-type fuse with a modern 50 amp blade type fuse?
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat Sep 24, 2022 10:30 am    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
50A is 50A, whatever works. I've seen these boxed fuses being installed, I'm not sure the name.
skills@eurocarsplus
Samba Peckerhead
you could do a maxi fuse, but most parts stores (napa, etc) can get and stock some of the strip fuses. even the dealer still has them
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
kamzcab86
kamzcab86 is offline
PostPosted: Sat Sep 24, 2022 11:03 am    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
I installed a 50A maxi fuse.
2016 Golf GTI S
RobdogAles
PostPosted: Sat Sep 24, 2022 11:11 am    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
Tried the local autopart stores. None have them and some can't get them. Napa has some in Arizona but it will cost $15 to get it here. I'll give VW a shout on Monday.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Sat Sep 24, 2022 11:12 am    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
The ones you had... ya, those are not 50 amp fuses after 20-30 years. Wilted, oxidized, etc. They are more like resistors after that amount of time.
I got all new exact replacements, and saw my amperage draws and heat production in the D pillar location go down remarkably.
So, my advice is to just put new stock ones in, not a new style, etc. The biggest reductions I had were in replacing or tightening loose connections, crimp ends and the likes. Any wiggle, and you will have electrical resistance, resulting in more draw, and higher temps in the area. Not a good thing in a tight little spot like the D pillar.
Last, I'd suggest you look into Pulse Width Modulation (PWM) units to replace the big resistors for the fans.
https://www.youtube.com/watch?v=qKlepF96tCQ&t=383s
(example for front blower, same concept)
https://www.thesamba.com/vw/forum/viewtopic.php?t=738697
(several options for A/C blowers)
And they are quite inexpensive.
https://www.ebay.com/itm/234324540095?hash=item368...BM9sOYi-5g
Regarding how to find the fuses themselves, I don't remember just now where I found them online, but they were very inexpensive as well. I know I bought a small bag of them, I probably even have some just sitting around somewhere, but my location management skills are poor... I will see what I can find from my orders history and get back here with useful info when I can take a look.
RobdogAles
PostPosted: Sat Sep 24, 2022 11:21 am    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
I was thinking about doing the pwm fan control after finding that in an earlier post when searching for options for replacing my strip fuse. Reason for replacing the strip fuse with a newer style is it makes it easier to find parts if needed.
PostPosted: Sat Sep 24, 2022 12:40 pm    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
I got some of these, IIRC:
https://www.ebay.com/itm/282920988038?chn=ps&_...-hEALw_wcB
But these also woudl do, I guess
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/strip-fuse-50-amp/n0171251/
https://www.digikey.com/en/products/detail/littelf...GGEALw_wcB
Corwyn Premium Member
Corwyn is offline
PostPosted: Sat Sep 24, 2022 2:05 pm    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
. . . or this:
https://www.amazon.com/Gauge-Inline-Fuse-Holder-Wa...amp;sr=8-8
'90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
Sodo
Sodo is offline
PostPosted: Sat Sep 24, 2022 2:37 pm    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
I see that's a Westy.
Delete the plenum - then you'll never need more than speed#3.
So disconnect Speed#4 from the switch and that wilted fuse is probably sufficient for a 3-speed.
....KTMs, GasGas, SPOT mtb
RobdogAles
PostPosted: Sat Sep 24, 2022 2:59 pm    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
Delete the plenum? Intriguing. Very intriguing. Benefits? Negatives? Photos???
Red Ryder
Red Ryder is offline
PostPosted: Sat Sep 24, 2022 4:16 pm    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
Search Amazon for “50A MIDI fuse”. Just did this. Direct replacement — easy peesy!
“Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
Sodo
Sodo is offline
PostPosted: Sat Sep 24, 2022 5:00 pm    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
Westy AC plenum delete...
....speed 2, quietly blowing nice cool a/c up to the front seats of the van....
I deleted the plenum at a campground in 100°F heat because Syncro Jael told me I'd be amazed.
The 2nd half of our trip was "amazing".
See this thread: Westfalia A/C vents & removing plenum
Sodo
Sodo is offline
PostPosted: Sun Sep 25, 2022 2:20 pm    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
Sorry ^^this^^ is an error.
Unplugging speed#4 doesn't reduce amperage across that fuse, or thru the 35 year old wires etc.
This proves that fxr, DuncanS, etc don't read every post. Cool Cool
And crazyvwvanman didn't catch me either. Shocked
The VW uses a set of 'resistors' to reduce the fan speed.
The resistors waste amps to reduce the motor speeds on 1,2,3.
Amperage to the motor is reduced, but the balance amperage is wasted by the resistor.
Consequently "total amps across that sad old fuse" is ~the same~ regardless of the speed.
The modern way is to use a PWM speed controller, which will definitely reduce the amperage at lower speeds.
No amps are 'wasted' with Pulse Width Modulation.
I'm wondering if there are little PWM boards, with little screw-pots that you could just abandon the resistor and install 3 separate PWM boards, pre-setting each one for speeds 1,2,3.
It wouldn't need that knob, just needs a little screw-pot that you set.
But it has to accommodate the motor wattage.
OR......a feller could re-route the outputs of the switch thru 4 discrete resistors that "choose" 4 positions of that knob/pot to control the PWM board.
Then the OEM fan speed switch still has 4 speeds, and works OEMish, with top speed about 80% (lesser power).
I like that.
Corwyn is offline
PostPosted: Sun Sep 25, 2022 4:25 pm    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
Good on ya' for jumping on your sword Cool
FAS Gen V 2.0
~ Captain Ron ~
RobdogAles
PostPosted: Sun Sep 25, 2022 5:44 pm    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
Thanks to all for your replies. I gotta say I love this forum. It's seldom I post questions but I always take away some amazing knowledge that can be difficult to dig out of the Bentley.
Cheers to you all.
Abscate
Abscate is offline
PostPosted: Mon Sep 26, 2022 3:11 am    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
I worked on a D pillar T3 AC electrical this summer. No way I would replace with stock fuses, splice in some modern stuff In those high amp circuits.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Mon Sep 26, 2022 9:13 am    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
Edit: how about measuring the amps through the fuse for each speed?
Mark
Sodo
Sodo is offline
PostPosted: Mon Sep 26, 2022 10:07 am    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
!!! Uh-oh this is worse than the dang sword ...
Good to confirm that the easy method (unplugging speed #4) is valid.
jeremiah.sites
jeremiah.sites is offline
PostPosted: Wed Nov 06, 2024 12:58 pm    Post subject: Re: Vanagon A/C 50 amp fuse substitute? Reply with quote
Reviving an old thread. Heading out camping this weekend and need a new strip fuse. Dont have time for shipping. Do you recall the size? Wonder if I can pick up at autozone, or napa.
