FJBLF Samba Member
Posted: Sun Oct 02, 2022 5:32 pm Post subject: Accelerator Cable Replacement (Step by Step) |
I hope you find it useful, please follow my YouTube channel.
_________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80547 Location: Sneaking up behind you
Posted: Sun Oct 02, 2022 5:41 pm Post subject: Re: Accelerator Cable Replacement (Step by Step) |
I would recommend bending the angled tip to more of a 90*. Many times, over the years, the tip has ovaled the hole and it can pull through when you step on the gas. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
FJBLF Samba Member
Posted: Sun Oct 02, 2022 7:08 pm Post subject: Re: Accelerator Cable Replacement (Step by Step) |
| Glenn wrote: |
| I would recommend bending the angled tip to more of a 90*. Many times, over the years, the tip has ovaled the hole and it can pull through when you step on the gas. |
Considering that these are 50 year old cars, if the hole is oval, maybe is time to replace the part. _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
Glenn  Mr. 010
Posted: Sun Oct 02, 2022 7:27 pm Post subject: Re: Accelerator Cable Replacement (Step by Step) |
| FJBLF wrote: |
| Glenn wrote: |
Considering that these are 50 year old cars, if the hole is oval, maybe is time to replace the part. |
A lot more complicated since you have to remove the cluster and disconnect the clutch cable. At that point you might as well rebuild it.
Old cars are like an onion, peel a layer and then there's another.
Member #1009
#BlueSquare
