Swedish '59 bug from belgium - next step 12v conversion
Page: 1, 2, 3, 4  Next
Wily
Wily is offline
PostPosted: Fri Sep 23, 2022 1:45 am    Post subject: Swedish '59 bug from belgium - next step 12v conversion Reply with quote
Hi from Belgium
Since I have already learned a lot on this forum I would like to take a moment to share my beetle with you.
It is a 1959 beetle that was imported from sweden in 2015.
I did already have a 1960 beetle 7 years ago.
What have i learned from my 1960 beetle? That I will not mount an extremely narrowed front axle.
Now my 1959 patina beauty! Cool
From very far away this is a beautiful car but when you look closer you see the imperfections.
The paint is poorly done and has many drips....
The car already has some serious rust spots that I am going to address.
Mechanically a lot has been renewed though
The gearbox and brakes received a complete overhaul
The engine was replaced by one from 1969 with 1500cc
A lot was replaced
Engine: sheet metal partly renewed / repainted, gaskets inlet and exhaust renewed, seals oil cooler replaced, new v-belt, new spark plug wires, new spark plugs, new crankshaft pulley, new rotor + distributor cap, new contact points and condenser, new fuel hoses, new ignition coil, new fuel pump + fuel pump support, new valve covers + gaskets, new clutch/pressure group/pressure bearing, new crankshaft seal, new throttle cable, valves adjusted, carburetor and ignition tuned by Leo de Ryck
- Electrics: new 6V battery, rear lights wiring harness renewed, completely new battery cables + ground strip gearbox
- Suspension: four new shock absorbers, front axle stop rubbers renewed
- New window rubbers mounted on fixed side windows, windshield and rear window; new windshield (star was further cracked during disassembly), NOS snowflake lenses mounted in taillights, license plate light seal replaced, new trim clips and caps
Interior:
- All original interior, roof liner in very good condition (once replaced), driver's seat cracked (new fabric included for repair, this can still be done by agreement at time of sale)
- Rare triple MotoMeter instrument in dash
- Original Ra-Bambus rack
- Double sun visor
- Swedish front lap belts
Otherwise, there is some work on the body but this is a largely original 63-year-old car.
That there are some spots after all these years seems normal to me. technically OK I thought more important + some patina? I LOVE IT
I am fortunate to be able to do a lot myself at night school, we have all the tools and materials there.
The door is the first job I will do there.
At a further stage the body will come off.
[img]https://i.ibb.co/YD8Y4bs/
303611830-996110087848890-712723182093285194-n.jpg[/img]
This weekend I am going to install a battery key from Hella.
Lowered spindles are also ready to install.
At that time the link pins are also going to be renewed.
I did give the spindles a coat of paint to prolong their life, though
I am also working on the new wheels Cool Cool Cool
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Fri Sep 23, 2022 7:16 am    Post subject: Re: Presenting my black 1959: lot of text and pictures Reply with quote
Very beautiful car 😀
matthew henricks
matthew henricks is offline
PostPosted: Fri Sep 23, 2022 7:35 am    Post subject: Re: Presenting my black 1959: lot of text and pictures Reply with quote
Nice bug
1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat.
Wily
Wily is offline
PostPosted: Sat Sep 24, 2022 11:37 am    Post subject: Re: Presenting my black 1959: lot of text and pictures Reply with quote
Quickly fitted a battery key today.
It is a hella one.
The ground cable is self made from 25mm² and the battery cable is a 35mm²
For now it is just in the car but the bumper plate under the rear seat is currently made out of some kind of cardboard.
This I am going to make in aluminum or stainless steel and then build the key in it
Rome
Rome is offline
PostPosted: Sun Sep 25, 2022 7:30 am    Post subject: Re: Black patina 1959: fitted a batterijswitch Reply with quote
Very nice Beetle. Too bad the taillamps are mounted too high. Just last week a man at work brought his black mostly original '60 Beetle to the office. It also has a 1500 engine, though he converted his car to 12 volts. Has same wheels as yours- painted factory stock two-tone- though the tires have whitewalls.
Wily
Wily is offline
PostPosted: Sun Sep 25, 2022 11:08 am    Post subject: Re: Black patina 1959: fitted a batterijswitch Reply with quote
i have some fuch wheels but waiting for my tires Cool
Wily
Wily is offline
PostPosted: Thu Sep 29, 2022 10:05 am    Post subject: Re: Black patina 1959: fitted a batterijswitch Reply with quote
Photo with my other toy
Finally got my new wheels
Empi fuch rims in 4.5 and 5.5 wide
Rear 195/65 front 155/60 falken brand
They are still dirty from the tire grease but I will polish that up.
I didn't have any lead left to balance them but I'll do it on Tuesday.
I also want to paint the center caps to break up the whole thing a bit
Wily
Wily is offline
PostPosted: Wed Oct 05, 2022 10:47 am    Post subject: Re: Black patina 1959: bought wheels Reply with quote
extra pictures
TRS63
TRS63 is offline
PostPosted: Sun Oct 09, 2022 7:22 am    Post subject: Re: Black patina 1959: bought wheels Reply with quote
Let's see pictures with the wheels mounted Smile how will you make the change to 5x130?
Bests
Antoine
Antoine
My 62 ragtop daily driver:
My 52 Standard Zwitter :
Wily
Wily is offline
PostPosted: Mon Oct 10, 2022 11:40 am    Post subject: Re: Black patina 1959: bought wheels Reply with quote
Bests
Antoine
Hi
i dont need to change Wink mine are 5x205 Cool
First i need to mount my dropped spindels before i put the wheels on Antoine
Wily
Wily is offline
PostPosted: Fri Oct 14, 2022 11:53 am    Post subject: Re: Black patina 1959: bought wheels Reply with quote
time for a little update Cool
opted for swan neck mirrors after all.
maybe not the best to see anything but i just like them!
Some pictures how to mount them
Wily
Wily is offline
PostPosted: Sun Oct 16, 2022 12:25 pm    Post subject: Re: Black patina '59: swan neck update! 14 october Reply with quote
Here I am again
Keep posting , maybe I can help someone through the pictures. Laughing
Already started disassembling the original spindles today.
That goes very smoothly and easily I must say
The spindles are now off.
At work I will have to use a press to get the bushings out of the spindle holder.
So that will be for the next few days.
Then also paint some parts (brake plate, steering rods...).
sportin-wood
sportin-wood is offline
PostPosted: Mon Oct 17, 2022 6:52 am    Post subject: Re: Black patina '59: lowered spindels coming Reply with quote
Nice car! Are you going to use wheel studs for the Empi Fuchs? Also, I understand that when using the Porsche center caps, some have encountered clearance issues with those wheels.
Dave
1966 Bug project
1973 Thing project
hobthebob
hobthebob is offline
PostPosted: Mon Oct 17, 2022 8:48 am    Post subject: Re: Black patina '59: lowered spindels coming Reply with quote
Very honest and clean car brother. Keep up the good work.
Wily
Wily is offline
PostPosted: Tue Oct 18, 2022 4:34 am    Post subject: Re: Black patina '59: lowered spindels coming Reply with quote
True, the centercaps come against the wheel bearing protective cover at the front.
You can't remove these because your speed cable is in there.
However, you can put a spacer so your wheel will be more forward.
That way your center cap will fit.... There are also companies that make wider caps.
I am not going to put centercaps on the front for now and I am going to polish the caps of my bearings. In the future I can look for spacers but then you would already have to put a narrowed axle or your wheels will come out too far
Wily
Wily is offline
PostPosted: Tue Oct 18, 2022 4:36 am    Post subject: Re: Black patina '59: lowered spindels coming Reply with quote
thanks for the fine comment
Currently working on replacing the king and linkpins.
I am doing everything at leisure because the winter season is about to start in belgium.
That way I can also renew the wheel bearings and paint some things on the steering gear
sportin-wood
PostPosted: Tue Oct 18, 2022 7:23 am    Post subject: Re: Black patina '59: lowered spindels coming Reply with quote
I purchased these center caps recently for mine. They don't look as nice as the Porsche caps you have, but they will clear the speedometer cable, and I wanted to avoid the wheel spacers if possible.
Dave
1966 Bug project
1973 Thing project
Wily
Wily is offline
PostPosted: Tue Oct 18, 2022 8:38 am    Post subject: Re: Black patina '59: lowered spindels coming Reply with quote
You can find those with porsche logo below
Maybe something for you? will match the rear ones
https://www.johnbrownwheels.com/product/foosh-rais...POm_L3saK4
Wily
Wily is offline
PostPosted: Tue Oct 18, 2022 2:42 pm    Post subject: Re: Black patina '59: lowered spindels coming Reply with quote
Removed the linkpin bushings today.
I also removed the kingpin bushings because they were in poor condition.
The new kingpin bushings are in the caliper and next week I can visit someone to use a vw 224 tool. You need this one to ream the kingpin bushings a bit. Then the lowered spindles will come on and the wheels will get new bearings.
We are trying to do everything ourselves hence everything is taking a little longer
Wily
Wily is offline
PostPosted: Wed Oct 19, 2022 11:38 am    Post subject: Re: Black swedish patina '59: bit of paint front axle parts Reply with quote
When I feel like it I always do something small to the car
Today refreshed some parts with rustoleum paint.
This protects against rust and suddenly looks much fresher
Page 1 of 4
