Bugs older then 1972 no louvers on rear deck lid 73 and up do ?
nextgen
nextgen is offline
PostPosted: Thu Nov 03, 2022 3:36 pm    Post subject: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
I have been selling magnetic covers for bug louvers and have been warning customers NOT FOR A RUNNNG ENGINE. Covering my rear end in case some one forgets to take it off.
A few of the guys came up with a good question, bugs earlier then 72 did not have rear deck louvers and did not have any problems. Engines were 1600cc just like later engines. 73 was the year (may be wrong ) that had duel port heads, a bit more power.
Sure more air is better but why so many years later after the 1500 and 1600 came out. Heck of a lot of engines did not have louvers and lasted a long time.
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Thu Nov 03, 2022 3:43 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
Early convertibles had 2 openings for louvers.
1970 had 2 openings for louvers, because of the single port 1600 that was introduced.
1971 same thing.
1972 The doghouse oil cooler was introduced and thus required more air, hence 4 sets of louvers.
1973 and on - 4 sets!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
volksworld
volksworld is offline
PostPosted: Thu Nov 03, 2022 3:51 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
yes...larger fan in the doghouse setup needed more air...as well as increasing emissions controls with leaner mixtures and different advance curves causing the newer engines to run hotter...certain Cali cars even had another air inlet behind the license plate to deal with their specs....saying that earlier cars had no problems is pretty funny...countless pulled studs and dropped #3 exhaust valves proved otherwise and is the reason for first trying 2 extra louvers then finally the doghouse and 8mm studs being introduced
VW_Jimbo is offline
PostPosted: Thu Nov 03, 2022 3:53 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
I think that was in 76 or 77. Funny little device!
Jimbo
nextgen
nextgen is offline
PostPosted: Thu Nov 03, 2022 5:28 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
Wow so now it all sounds logical. Especially the doghouse needing more air. The bugs birthday was a week ago if I am no mistaken and it is 83 years old. Amazing that we are still trying to under how it works.
Thanks
67rustavenger
67rustavenger is offline
PostPosted: Thu Nov 03, 2022 6:36 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
Ok. This louver, more air, doghouse fan blah, blah, blah... question comes up from time to time.
I have a 67, I know wrong forum. But my point is, I have ran my DH cooled 1679, 2180 with the decklid closed and no extra decklid louvers.
Without overheating the engine.
I even drag raced the 2180 with the decklid closed and didn't have any ill affect.
That said, I'm building a 2276 turbo. So it may now need the extra cooling air.
I have a 67 vert decklid with the 4 louver vents.
Joe, do you have the magnet covers for 2, 4 vane louvers like a 70 would have had?
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
nextgen
nextgen is offline
PostPosted: Thu Nov 03, 2022 7:02 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
Hi 67
I sure do email me (See my email address below ) and I will we can talk and give the pricing with
Free Shipping
Beetle Magnetic Deflector Shield B.M.D.S
Part Numbers:
BMDS - 1 REAR DECK LID GRILLE 1970 - Till end of production $25
BMDS - 2 FRONT WINDOW GRILLE 1968 - Till end of production $18
BMDS -3 REAR WINDOW GRILLE 1958 - Till end of production $25
BMDS -4 SHIELD KIT - ALL 3 SHIELDS 1 - 2 & 3 $45
FREE --- PRIORITY SHIPPING - FOR EACH and the 3 SHIELD KIT
Please note: Free shipping only in the U.S.A
neil68
neil68 is offline
PostPosted: Fri Nov 11, 2022 4:33 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
1300 DP Beetles in Europe had the solid deck lid well into the 70’s.
Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
nextgen
nextgen is offline
PostPosted: Fri Nov 11, 2022 7:05 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
Wow! Neil, thanks,
I should have added to my Disclaimer, something like. ( In different
countries there may be exceptions to years of beetles that were made with rear deck louvers ).
Actually a 1300 cc bug dual port, should run even cooler seeing that the 1600 dual port bugs, most likely put out more heat..
I have run into a bug convertible with the same over all louver area that my deck shield fits over , except it was made with out 4 louvers in the middle. The shield just covered the area were the missing 4 would have been.
irvanm
irvanm is offline
PostPosted: Fri Nov 11, 2022 7:34 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
My 70 has louvers.
Cusser
Cusser is offline
PostPosted: Sat Nov 12, 2022 7:57 am    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
VW_Jimbo wrote:
Early convertibles had 2 openings for louvers through 1969.
1971 same thing.
As stated above; and 1970 and 1971 convertibles had 4 openings, but slightly different than on the new deck lids sold these days.
volksworld
PostPosted: Sun Nov 13, 2022 10:09 am    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
1300s had much thicker cylinder walls and as a result the sealing surface to the head was wider...so the setup could handle more heat without distortion issues than the 1600...1300 lived on in Europe without issue while the 1600 was basically the equivalent of putting in a slip in big bore kit to hotrod the engine to try to keep up with large cubic inch american engines on our highways...and under those conditions with our additional emission requirements they needed additional cooling to stay together
nextgen
nextgen is offline
PostPosted: Sun Nov 13, 2022 12:18 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
That is why I wrote THE TYPE IV UPRIGHT CONVERSION MANAUAL back in 1993
T-4's Are hardly working when pushing a light Bug. a 2.0 like mine rarely gets over 110f
BTW I just posted on my facebook site that i have over 100 Original copies of my manual and the master copy that survived an 80 story fall and fire at the Twin Towers WTC in a huge safe found after a month after the massive clean up. The safe was in then office of my printer. When he called me he said Joe you are not going to believe me. Not knowing I had printed 200 copies made with out the Spiral black binder and clear plastic Cover. Those parts were unavailable at that time. Still $29.95
bnam
bnam is offline
PostPosted: Sat Jan 13, 2024 9:28 am    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
1971 same thing.
Correcting for future reference
1970 and 71 Sedans 1600s (SP in ‘70 and DP in ‘71) had 2 sets of louvres.
1970 and 71 1600cc convertibles had 4 sets of louvres in 7,7,7,7 configuration. This 2 year vert deck lid had the largest opening of the German made beetles.
72-on 1600 sedans and verts switched to louvres in 7,6,6,7 configuration - 2 fewer than the previous year verts. Not sure why it was made smaller.
Unvented decklids continued till 78 for 1200 and 1300cc engine Beetles sold elsewhere.
Click to view image
1952 Citroen TA 11BL
VW_Jimbo is offline
PostPosted: Sat Jan 13, 2024 11:13 am    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
1971 same thing.
Sorry man. I should have included the convertibles! I just did not even think of them. But glad someone included it!
And….AMAZING! I had neve, ever counted the number of louvers. Never had crossed my mind. But in thinking back, I can recall the 2 outer openings being one slit more than the inside ones. Too cool and right under my nose. I typically ask questions when I see oddities, but in this scenario, I never had!
Thanks! Love learning something new!
Jimbo
Floating VW
Floating VW is offline
PostPosted: Tue Jan 16, 2024 4:53 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
I even drag raced the 2180 with the decklid closed and didn't have any ill affect . . .
As mentioned above, a properly built engine can run very cool, and may not "need" as much air to keep cool as a poorly designed engine needs.
That being said, the "ill effects" of an engine that is starved for air may not always be apparent under certain circumstances. It's usually only when high ambient temps are paired with high speed, long distance highway runs that you really notice a cooling problem.
Many drag racers disconnect the cooling fan completely when they make a quarter-mile run, with no problem. However, a high displacement, high RPM ACVW engine can lose a significant amount of power if it has to compete with the cooling fan in a poorly ventilated engine compartment.
Here was my solution to poor ventilation: https://www.thesamba.com/vw/forum/viewtopic.php?t=742109&highlight=
A sweet pair of ram-air cooling ducts, and say goodbye to those lame deck lid louvers!
"It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works."
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Jan 16, 2024 6:42 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
If you have a large displacement engine and IDAs, you need air to get in.
I've seen the decklids get sucked down at WOT.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
stagewex
stagewex is offline
PostPosted: Tue Jan 16, 2024 8:26 pm    Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? Reply with quote
My '73 Super:
