mg50 Samba Member
Joined: August 30, 2022 Posts: 750 Location: Southeast
Posted: Mon Nov 07, 2022 3:39 pm Post subject: Can I get by without an Engine Stand? |
I want to pull out my beetle engine next month to source a leak, maybe the oil cooler. Will I be able to remove tin to get at the oil cooler, maybe replace pushrod tubes without having a stand to rotate the engine as I work? I don't anticipate having to do this frequently and don't have a lot of room in my garage. I have a floor jack, motorcycle jack and stands. I could possible buy a hydraulic table cart from Harbor Freight to lift the thing up off the floor to a work table. Old guy working alone. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79497 Location: Sneaking up behind you
Posted: Mon Nov 07, 2022 3:44 pm Post subject: Re: Can I get by without an Engine Stand? |
It's easier with a stand, but i've done top end rebuilds on a upside down trash can. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Bonesberg55 Samba Member
Posted: Mon Nov 07, 2022 4:03 pm Post subject: Re: Can I get by without an Engine Stand? |
I've done complete ACVW rebuilds with no engine stand. My workbench is fine and the engine is light enough to flip. When you get to heavier cast iron engines, then an engine stand is a must. |
Zundfolge1432  Samba Member
Posted: Mon Nov 07, 2022 4:05 pm Post subject: Re: Can I get by without an Engine Stand? |
Very nice |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4934 Location: Stuck in Ohio
Busstom Samba Member
Joined: November 23, 2014 Posts: 4579 Location: San Jose, CA
Posted: Mon Nov 07, 2022 5:48 pm Post subject: Re: Can I get by without an Engine Stand? |
mg50 wrote: |
Will I be able to remove tin to get at the oil cooler, maybe replace pushrod tubes without having a stand to rotate the engine as I work? |
Yes. |
mg50 Samba Member
Posted: Mon Nov 07, 2022 5:57 pm Post subject: Re: Can I get by without an Engine Stand? |
Sorry I should have known this had been discussed. I should have done a search. Thanks for the thread. |
