Rosiecece Samba Member
Joined: August 19, 2021 Posts: 14 Location: CA Bay Area
Posted: Fri Dec 02, 2022 11:13 am Post subject: Cracks in 2L FI engine crankcase - can it be reused? |
I’m rebuilding my 1978 2L bus engine and was planning on reusing the crankcase. Upon splitting the case I noticed spider cracks around the #1 cylinder bore. None of them go through the case nor enter critical areas such as bearings or lifter bores. Has anyone seen these before? Are they superficial or critical? The engine is being rebuilt because of a recessed exhaust valve at #3. Can this crankcase be reused? Appreciate the help.
Posted: Fri Dec 02, 2022 11:15 am Post subject: Re: Cracks in 2L FI engine crankcase - can it be reused? |
| What you are looking at are probably just casting marks. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53173 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Dec 02, 2022 11:43 am Post subject: Re: Cracks in 2L FI engine crankcase - can it be reused? |
Looks like the typical casting marks on type 4 cases from here, someone explained the process VW used to make the aluminum case and why those marks were left, but I can't remember it right now.
If you wash it off really spiffy like and then warm the area with a propane torch do any sweat out oil? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42917 Location: at the beach in Northern Wokistan
Posted: Fri Dec 02, 2022 1:16 pm Post subject: Re: Cracks in 2L FI engine crankcase - can it be reused? |
if you are referring to the lines on the left, as others said, they are casting marks. Even a new case has them. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
timvw7476 Samba Member
Posted: Fri Dec 02, 2022 5:16 pm Post subject: Re: Cracks in 2L FI engine crankcase - can it be reused? |
| Looks great. Just peen or thread your larger welch plugs, especially the bellhousing area. 1978 was a lOOng time ago. Those plugs eventually work loose, dump a little oil, trash a clutch disc. Not fun. Deal with it as preventive maintenance while it's scattered. |
SGKent  Samba Member
Posted: Fri Dec 02, 2022 5:44 pm Post subject: Re: Cracks in 2L FI engine crankcase - can it be reused? |
Just be aware that sometimes a new threaded gallery plug can leak too. As me how I know. _________________
George Carlin:
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5572 Location: Holland, MI
Posted: Sat Dec 03, 2022 10:22 pm Post subject: Re: Cracks in 2L FI engine crankcase - can it be reused? |
Typical appearance for die cast aluminum. Most high production die cast aluminum castings look like that. Nothing to worry about. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
