Convertible Door and Rear 1/4 Glass
Cusser
Cusser is offline
PostPosted: Thu Mar 05, 2020 5:50 am    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
johnpernock wrote:
Sorry to resurrect an old thread but I’ve been stuck for a few days trying to get my glass out. Any tips for getting the regulator unhooked from the bottom of the glass? No matter what I try it seems to be 1/10” of an inch or less off from lining up with the holes. I’m not sure if I did something wrong? I’ve followed the steps to a T, since this is the only resource I’ve seen about the vert windows.
I’m just trying to put all new seals on the doors haha.
Years ago, I replaced the door and window on my 1971 Convertible without taking out the door windows (I did remove the quarter windows though).
See these threads
https://www.thesamba.com/vw/forum/viewtopic.php?t=548840&start=40
https://www.thesamba.com/vw/forum/viewtopic.php?p=8718305#8718305
johnpernock
johnpernock is offline
PostPosted: Thu Mar 05, 2020 11:27 am    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Thanks Cusser, Im still having issues though, I followed both of those threads thoroughly. I need to remove the glass because I am replacing all rubber and the felt and everything. I just didnt know if anyone had any recommendations of a way to force the plastic guides over a little further to the holes. Ive done my Passenger Door so far and this is where ive stopped. Im about to try my Drivers door tonight to see if it is any easier.
Also, I saw that the screw under the rubber under the vent windows is M6, just wanted to check to make sure thats the correct one. Im missing it on my passenger side and I am assuming it is missing on my drivers side as well.
See these threads
JoeyBagaDonutz
JoeyBagaDonutz is offline
PostPosted: Thu Mar 05, 2020 1:09 pm    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Are you talking about moving the sliders over far enough to go thru the holes
where the arrows are in this picture?
https://www.thesamba.com/vw/gallery/pix/1039688.jpg
1967 Beetle Sedan
1971 Super Beetle Vert
1971 Karmann Ghia Vert
johnpernock
PostPosted: Thu Mar 05, 2020 1:18 pm    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Yes exactly. I was trying to get the glass off and can not get those over far enough. Didn’t know if anyone had any tips for that. It’s like right there but it won’t budge any further over and cannot click it out.
JoeyBagaDonutz
PostPosted: Thu Mar 05, 2020 1:26 pm    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Ok, I've found that by moving the regulator up or down inside the door the slides will move left or right.....its just a matter of moving it around till they line up. sometimes I leave one screw in as a pivot point and crank the window up or down to see which way it moves, then push it some more. It will line up to pop the window off the track if you get it in the right position.
Joey
1967 Beetle Sedan
johnpernock
PostPosted: Thu Mar 05, 2020 1:57 pm    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Thanks Joey,
Ill try again, I did exactly what you are talking about. I guess I just have to try harder haha. Ill take a stab at it tonight.
John
Joey
Amermel
Amermel is offline
PostPosted: Mon Mar 09, 2020 3:29 pm    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
I ran into the same problem and could not get the method shown to work.
I ended up removing the clips on the slides, and pulling apart the slides. With the regulator loosened, just push the regulator back on the regulator and there was enough room to disconnect the regulator.
I did end up purchasing new slide kits (they seem unreasonably expensive at $22.00), as the old clips got chewed up during removal, and the new clips have holes that make it easy to install the clips if you have c-clip pliers. Probably could have just purchased new c-clips...
johnpernock
PostPosted: Tue Mar 10, 2020 7:36 am    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Joey
So I got the window out, Ironically the window glass was just sitting in the mechanism piece and when I drove it, I was able to wiggle it out. It seems fine now.
Ironically... I had to drive it like that because I needed a socket for my audi already on the lift getting new brakes... One problem solved another.
I had issues getting the vent window out as the nut just spun in the door so I had to dremel it out and I got a long pair of curved needle nose pliers to get a nut up in there and just secure it from the bottom this time. Otherwise it was a breeze to get the seals in. Just some WD-40 and some Vaseline on the seal but its perfect so far. Now to do the drivers side... I messed up my door cards removing them so Im also waiting for new ones to come in the mail at this point.
Thank you all for your help on this...
JoeyBagaDonutz
PostPosted: Tue Mar 10, 2020 10:28 am    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Ya, the cage around the captive nut rots out and the nut spins....its a PITA for sure to get another nut in there!....I knew you'd get the window out one way or the other haha
1967 Beetle Sedan
Mich3
Mich3 is offline
PostPosted: Wed May 13, 2020 9:21 am    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Awesome thread (as usual) and very helpful.
Has anyone struggled replacing the upright seals in the quarter windows of the vert? The rubber seems too large for the chrome channel and I tried lubricant spray as well as vaseline to only insert an inch or so over 1 hour fight.
Cusser
Cusser is offline
PostPosted: Wed May 13, 2020 1:53 pm    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
I wrote these instructions for myself when I did my 1971 convertible seals, maybe 20 years ago:
Remove small phillips screw and rectangular plate near bottom of seal. Slide down old seal. Lubricate frame channel and replacement rubber seal lip well with glycerine and push up into frame (note: this might require two people). Wash off excess glycerine with water. The screw is about 11.5mm up from the bottom of the frame; drill a hole thru the seal at that place, slide up small rectangular bracket, and re-install screw (it's head will pierce the outer part of the seal).
Mich3
Mich3 is offline
PostPosted: Thu May 14, 2020 3:45 pm    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Thanks Cusser,
I'm thinking that the seal lip that goes into the groove is too large (see pic): do you remember something like that?
Cusser
Cusser is offline
PostPosted: Fri May 15, 2020 7:22 am    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Mich3 wrote:
Thanks Cusser,
I did mine a long time ago, and do not remember them being too large. I doubt I ever looked at them as closely as you did. But since I had to get a helper (which is quite rare for me), must've taken some effort.
Warming the rubber insert slightly "may" make it more pliable. Since suppliers were zero help (same as when I inquired), and these inserts are not overly expensive, I won't tell anyone if you shave the insert a little narrower. Lube well with glycerin, dish detergent-water mix, KY, anything that can be washed off with water.
Curious: did you purchase West Coast Metric seals? Because if their inserts are trouble to install, they should be contacted.
Mich3
Mich3 is offline
PostPosted: Fri May 15, 2020 8:04 am    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Cusser wrote:
Mich3 wrote:
Thanks Cusser,
We got them from JBugs and I will let them know for sure. After trying everything you are also suggesting, including the dip in boiling water, I ended up shaving both sides of the lip and my son and I were able to slip one on. Still a workout! Over the weekend we'll complete the rest of the top seals.
bosco0633
bosco0633 is offline
PostPosted: Sat Jun 13, 2020 11:49 am    Post subject: Reply with quote
djkeev wrote:
Step 6
*On the rear edge of the door, pop off the plastic cap towards the top and remove the 10mm bolt that secures the rear window guide in the door. ( I suggest doing this before you remove the door glass.)
Step 10
*Remove the rubber bit at the rear edge of the door window opening. It is held on by a small #1 Phillips screw. Odds are high it may be missing! Replacements are easily obtained.
(White Arrow)
Dave
I would appreciate any input on parts for step 6 and 10.
I can't seem to find what cap to order for this 10mm bolt hole. I ordered two sets of door hole plugs and none of them seem big enough.
On step 10, the piece of rubber seal that is screwed in between the two scrapers, I am unable to find that as well. Can you please link me to what I am looking for.
I have ordered a few things without being able to narrow in what they actually are.
Thanks in advance
Ryan
JREDC
JREDC is offline
PostPosted: Sat Oct 23, 2021 12:06 pm    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Even though this is an old post, it is still very relevant for someone installing windows. I am restoring my father's 77 Super Beetle Convertible. These forums have helped however there needs to be an update for installing or uninstalling the passenger and driver side windows on a 77 Convertible.
I have spent HOURS probably 12 or more trying to figure this out. It has been totally frustrating and I'm glad none of my neighbors heard me or they would think I was a sailor.
Here are necessary updates to this forum.
1. As stated in another post, The vent window would not come out up as it needs to be moved backward to pull up and out. But can't be moved back until the glass is removed.
2. Due to the side impact door reinforcement of the 77, the regulator will NOT slide backwards enough to disconnect the regulator plastic guides from the window track channels.
Here's what I discovered:
You MUST first unbolt the rear plastic guide from the regulator. Then pull the rear of the regulator arm towards the outside of the door to disengage the bolt from the regulator arm. You will then be able to crank the regulator into a position where you can remove the rear plastic guide from the track channel at the bottom of the window. With the rear guide removed you can then crank the window to a position where you can now remove the front guide from the window track. You can then follow all the other steps posted.
Installation will be the same procedure.
I hope this helps alleviate the frustration that I went through
James R
Barney the Bug
Barney the Bug is offline
PostPosted: Thu Jun 16, 2022 12:43 pm    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Does anyone know if there are directions on how to adjust the rear windows. When one of the rear window is rolled fully up its not flush at the top where it meets the front window its slightly bowed out about 1/2 inch. This is a 78 SB Vert. Can it be adjusted ? if so How? Or do you think I need to buy a new regulator. The other rear window on the pass side is perfect.
BUGGED11111 wrote:
SteveK wrote:
I'm having trouble with the chrome trim piece across the top of my windows--it pulls in the scrapers as it lowers last 1/2" into the door. Result is that the scraper edge that usually points straight up is pulled down 180 degrees and pointing straight at the ground. Are these scrapers hopelessly soft and or deformed, so need to be replaced?
That looks normal to me. When completely lowered the window goes below the rubber and the rubber pops back out over the trim. If that's as low as you go, you will need to adjust the window so it lowers further. There's a adj on the regulator for setting how high the window rolls up or down. Putting some talc on the rubber will also help it slide
Personally I never lower the window all the way to save wear and tear on the scraper so if my arm is resting on the door it's sitting on the top of the window trim not the scraper
Barney the Bug
PostPosted: Thu Jun 16, 2022 12:54 pm    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
This is my same issue but I don't see any explanation on how to adjust the rear window. Anyone know of some previous threads on how to adjust?
BWingate wrote:
A little review and some guesswork and I figured it out: The rear bolt in the image below is used to adjust the for and aft position of the roll-up window.
I loosened it up, shoved the window forward and tightened up back up and got this:
Not the best picture - sorry. The problem was not all with the adjustment of the windows - the seal between the front and rear windows was out of the track some, so I reset that, and everything works better with both windows rolled up just a little less than all the way up.
There are still some issues with the windows "flopping" in and out and with the height adjustment of the roll-up windows - I would like them to go all the way down easily and to lower the upper limit just a bit - but for now this is a 100% better than before.
bruehoyt
bruehoyt is offline
PostPosted: Tue Dec 13, 2022 1:41 pm    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
Thanks for posting this info. I hate this window set up.
Marking this thread for reference.
Current VW's:
71 Westfalia https://www.thesamba.com/vw/forum/viewtopic.php?t=633955
74 Super Beetle Convertible Sun Bug https://www.thesamba.com/vw/forum/viewtopic.php?t=748008
Past VW's:
71 Karmann Ghia Autostick. 17-21. https://www.thesamba.com/vw/forum/viewtopic.php?t=727596
70 Karmann Ghia driven 00-03, 67 Karmann Ghia 91-97, 74 Karmann Ghia 92-94, 71 Karmann Ghia 87-92, 74 Super Beetle 86-87, 71 Karmann Ghia 85-86 (my avatar)
Barney the Bug
PostPosted: Tue Dec 13, 2022 2:51 pm    Post subject: Re: Convertible Door and Rear 1/4 Glass Reply with quote
I forgot about this post thanks for getting back to me
I'll try some more adjustments and see what that does
Using talc will help with the window sliding up/down on the rubber scrapers
Thanks again
Personally I never lower the window all the way to save wear and tear on the scraper so if my arm is resting on the door it's sitting on the top of the window trim not the scraper[/quote][/quote]
Page 4 of 5
