Off-Road Header Heat Riser Routing
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Thu Dec 15, 2022 4:44 pm    Post subject: Off-Road Header Heat Riser Routing Reply with quote
Even with the stock intake 100% clear this should be better then having the #2 and #4 cyl blowing back and forth. I tried looking for header preheat setups using the search but must be doing it wrong. Figured this is kinda what you guys are doing?
oprn
oprn is offline
PostPosted: Fri Dec 16, 2022 6:11 am    Post subject: Re: Off-Road Header Heat Riser Routing Reply with quote
Or a variation thereof yes. The search functions are very fussy things. Get one word or the spelling wrong or out of sequence and you are out of luck. Try this thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=755518&highlight=
tpinthepack
tpinthepack is offline
PostPosted: Sat Dec 24, 2022 5:16 am    Post subject: Re: Off-Road Header Heat Riser Routing Reply with quote
I think only after market uses those two cylinders, but Stock has the draw side behind the Pee Shooter so that trust comes from all cylinders.
I think your design will be good.
73 VW Thing has a different design with the dual exhaust that I like also.
Tony
TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne
