Clutches - what pressure plate with what throwout bearing
Page: Previous  1, 2, 3 ... , 17, 18, 19  Next
bnam
bnam is offline
PostPosted: Sun Dec 18, 2022 4:31 am    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
What happens if a later style throwout bearing - that is correct for the transmission -- is mated to a flywheel which has the old style pressure plate with the centering ring attached? The release bearing should still act against the centering ring and disengage the clutch. But, will this disengagement start earlier on or is the surface of the centering ring at the same position as contact would be on ring-less set up?
Since the centering ring had some thickness - was the later release bearing thicker to take up the extra room from not having the bearing or was the additional travel adjusted out at the cable?
Click to view image
1952 Citroen TA 11BL
Pruneman99
Pruneman99 is offline
PostPosted: Sun Dec 18, 2022 10:28 am    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
The centering ring on the PP will foul on the throwout bearing sleeve that's bolted to the transmission.
ashman40
ashman40 is offline
PostPosted: Sun Dec 18, 2022 11:52 am    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
Correct. To illutrate this, go back to page 1 of this thread and see the post with this pic showing the damage to the TO bearing sleeve when the centering ring is left on the PP.
Note: most early style PP with the centering ring can be converted to a later style PP by simply removing the centering ring. So there is no excuse for installing the centering ring on later model cars other than oversight or lack of knowledge/experience by the mechanic doing the work.
AshMan40
bnam
bnam is offline
PostPosted: Sun Dec 18, 2022 10:56 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
I’m not sure removing the centering ring will work on this kind of OE pressure plate. Seems like it would chew up the release bearing
Click to view image
ashman40
ashman40 is offline
PostPosted: Mon Dec 19, 2022 8:30 am    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
Sorry, I should have started that statement as follows:
“Note: most early style PP with the centering ring (that you can buy today) can be converted…”. Very Happy
I have only seen recently the diaphragm type for sale. Even rebuilt PPs are all the diaphragm type. I suppose this could be different where you live.
And for the rebuilt spring-type PPs and the NOS PPs like pictured above… I did say “most”. Razz
Though, I do believe you can remove that centering ring and use that spring-type PP with the newer TO Bearings. Can someone who has done this chime in?
Was there a spring-type PP that did not have a removeable centering ring? I did some searching and all spring type PPs I could find have removeable centering rings, but this may just be for ease of rebuilding them?
AshMan40
Cusser
Cusser is offline
PostPosted: Mon Dec 19, 2022 9:04 am    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
Photo 1
Photo 2
Yes, removing the center ring from that type of pressure plate WILL WORK, and work well, with the 1971 and later transmission/throwout bearing types.
In fact, my 1971 VW Convertible (mine since 1976) came from factory with a pressure plate like shown in Photo 2.
And when I installed the 1835cc engine from my 1970 VW (which had a pressure plate as shown in Photo 1) into my 1971, I removed its center ring so it now looks like Photo 2, and that is how it's been ever since. And it runs and shifts fine.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Dec 19, 2022 9:11 am    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
If you have a 71 and up transaxle with the later style throwout bearing, you'll never get the engine seated to the transaxle if you don't remove the centering ring.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Pruneman99
PostPosted: Mon Dec 19, 2022 3:36 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
Don't underestimate the ability of some people to screw shit up.
I accidentally made this mistake once when I wasn't paying attention. Your right in the fact that the engine won't slide up to the transmission correctly. This is where I realized my bone head move, lowered the engine back down, and removed the ring.
But I wouldn't put it past someone to use the mounting bolts to sinch it together or something, and crush stuff up.
Like that other thread showing how people make stuff fit backwards somehow.
bnam
bnam is offline
PostPosted: Mon Dec 19, 2022 6:35 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
Cusser wrote:
Photo 1
Photo 2
Cusser, are you sure it is the same ? My 71 had / still has / the OE 3 arm pressure plate - there are subtle differences from this one. For one, the tips of those arms are subtly different. They don’t have this cut in the middle and the ends were more rounded. With the cut there, I feel pretty certain it till cut into the bearing surface of the release bearing. Let me see if I can find a photo.
Click to view image
Mr. 010
Glenn is offline
PostPosted: Mon Dec 19, 2022 6:38 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
A good way to damage the TO bearing, guide tube and/or pressure plate.
From the 1st post.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
bnam
bnam is offline
PostPosted: Mon Dec 19, 2022 6:43 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
This is the 71 OE plate. Note the differences. Functionally, the tip of the arm is the important difference. There is no cut and the tip has better bearing surface - no sharp edges. I’m sure the earlier plate (the one I posted earlier) that’s on the friend’s car will not work well with a release bearing once the centering ring was removed.
Click to view image
Mr. 010
Glenn is offline
PostPosted: Mon Dec 19, 2022 6:57 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
Different design, the other is a 9 spring.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Cusser
Cusser is offline
PostPosted: Mon Dec 19, 2022 9:11 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
I honestly don't remember if the pressure plate originally in my 1971 was 9-spring or not, just remember that it had three arms and no center ring. I can't remember if that pressure plate is now in my box of parts either, I just know that when I rebuilt that 1971 engine to go into my 1970 sedan in 2016-2017, that I couldn't use its pressure plate because it had no center ring. I had to buy a new PP with a center ring
And apparently I didn't save the center ring from my other 3-arm pressure plate when I had to remove its center ring when I moved the 1835cc engine from my 1970 sedan into my 1971 convertible about 2005.
Got all that? The test is tomorrow !!!
SoFlo1970BusTypeII
SoFlo1970BusTypeII is offline
PostPosted: Sat Apr 22, 2023 12:45 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
After installing the early to late model throwout bearing conversion kit the throwout bearing body turns sideways when the clutch is depressed without the engine installed. I have a video of it doing this but it was too big to upload. Is this happening because the pressure plate is not there to keep it in place or is there something else going on that I should address before dropping the engine in?
Mr. 010
Glenn is offline
PostPosted: Sat Apr 22, 2023 12:49 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
The TO besting is crooked, so is it on the arms correctly or are the arms bent?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
SoFlo1970BusTypeII
PostPosted: Sat Apr 22, 2023 1:08 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
It starts out perfectly square then when we depress the clutch it turns.
SoFlo1970BusTypeII
PostPosted: Sat Apr 22, 2023 1:09 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
I was able to shorten the video to where the Gallery let me upload it but now I can’t find it in the Gallery.
mikeonthebike
mikeonthebike is offline
PostPosted: Sat Apr 22, 2023 1:12 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
The throwout bearing is not on the arms straight. The left side is too high and/or the right side is too low. You need to get that straightened out. See Glenn's picture.
SoFlo1970BusTypeII
PostPosted: Sat Apr 22, 2023 1:19 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
It is on the arm straight to begin with then it turns when the clutch is depressed. I really wish I could figure out how to upload the 3 second video that shows it turning.
kreemoweet
kreemoweet is offline
PostPosted: Sat Apr 22, 2023 1:36 pm    Post subject: Re: Clutches - what pressure plate with what throwout bearing Reply with quote
It doesn't look to me like you have the correct TO shaft for the late-style bearing. The arms on that are quite different from the earlier style. Look at where the cutouts in the shaft arms are in the photo Glenn posted.
'67 bug: seized by the authorities
Page 18 of 19
