bnam Samba Member
Joined: July 02, 2006 Posts: 3544 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sun Dec 18, 2022 4:31 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
What happens if a later style throwout bearing - that is correct for the transmission -- is mated to a flywheel which has the old style pressure plate with the centering ring attached? The release bearing should still act against the centering ring and disengage the clutch. But, will this disengagement start earlier on or is the surface of the centering ring at the same position as contact would be on ring-less set up?
Since the centering ring had some thickness - was the later release bearing thicker to take up the extra room from not having the bearing or was the additional travel adjusted out at the cable? _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sun Dec 18, 2022 10:28 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
| The centering ring on the PP will foul on the throwout bearing sleeve that's bolted to the transmission. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16769 Location: North Florida, USA
Posted: Sun Dec 18, 2022 11:52 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
| Pruneman99 wrote: |
Correct. To illutrate this, go back to page 1 of this thread and see the post with this pic showing the damage to the TO bearing sleeve when the centering ring is left on the PP.
Note: most early style PP with the centering ring can be converted to a later style PP by simply removing the centering ring. So there is no excuse for installing the centering ring on later model cars other than oversight or lack of knowledge/experience by the mechanic doing the work. _________________ AshMan40
bnam Samba Member
Posted: Sun Dec 18, 2022 10:56 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
I’m not sure removing the centering ring will work on this kind of OE pressure plate. Seems like it would chew up the release bearing
Click to view image
Posted: Mon Dec 19, 2022 8:30 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
Sorry, I should have started that statement as follows:
“Note: most early style PP with the centering ring (that you can buy today) can be converted…”.
I have only seen recently the diaphragm type for sale. Even rebuilt PPs are all the diaphragm type. I suppose this could be different where you live.
And for the rebuilt spring-type PPs and the NOS PPs like pictured above… I did say “most”.
Though, I do believe you can remove that centering ring and use that spring-type PP with the newer TO Bearings. Can someone who has done this chime in?
Was there a spring-type PP that did not have a removeable centering ring? I did some searching and all spring type PPs I could find have removeable centering rings, but this may just be for ease of rebuilding them? _________________ AshMan40
Cusser Samba Member
Joined: October 02, 2006 Posts: 33450 Location: Hot Arizona
Posted: Mon Dec 19, 2022 9:04 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
| bnam wrote: |
Photo 1
Photo 2
Yes, removing the center ring from that type of pressure plate WILL WORK, and work well, with the 1971 and later transmission/throwout bearing types.
In fact, my 1971 VW Convertible (mine since 1976) came from factory with a pressure plate like shown in Photo 2.
And when I installed the 1835cc engine from my 1970 VW (which had a pressure plate as shown in Photo 1) into my 1971, I removed its center ring so it now looks like Photo 2, and that is how it's been ever since. And it runs and shifts fine. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80410 Location: Sneaking up behind you
Posted: Mon Dec 19, 2022 9:11 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
If you have a 71 and up transaxle with the later style throwout bearing, you'll never get the engine seated to the transaxle if you don't remove the centering ring. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Mon Dec 19, 2022 3:36 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
| Glenn wrote: |
| If you have a 71 and up transaxle with the later style throwout bearing, you'll never get the engine seated to the transaxle if you don't remove the centering ring. |
Don't underestimate the ability of some people to screw shit up.
I accidentally made this mistake once when I wasn't paying attention. Your right in the fact that the engine won't slide up to the transmission correctly. This is where I realized my bone head move, lowered the engine back down, and removed the ring.
But I wouldn't put it past someone to use the mounting bolts to sinch it together or something, and crush stuff up.
Like that other thread showing how people make stuff fit backwards somehow. |
bnam Samba Member
Posted: Mon Dec 19, 2022 6:35 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
| Cusser wrote: |
| bnam wrote: |
Photo 1
Photo 2
And when I installed the 1835cc engine from my 1970 VW (which had a pressure plate as shown in Photo 1) into my 1971, I removed its center ring so it now looks like Photo 2, and that is how it's been ever since. And it runs and shifts fine. |
Cusser, are you sure it is the same ? My 71 had / still has / the OE 3 arm pressure plate - there are subtle differences from this one. For one, the tips of those arms are subtly different. They don’t have this cut in the middle and the ends were more rounded. With the cut there, I feel pretty certain it till cut into the bearing surface of the release bearing. Let me see if I can find a photo. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Glenn  Mr. 010
Posted: Mon Dec 19, 2022 6:38 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
| Pruneman99 wrote: |
| But I wouldn't put it past someone to use the mounting bolts to sinch it together or something, and crush stuff up. |
A good way to damage the TO bearing, guide tube and/or pressure plate.
From the 1st post.
Member #1009
#BlueSquare
bnam Samba Member
Posted: Mon Dec 19, 2022 6:43 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
This is the 71 OE plate. Note the differences. Functionally, the tip of the arm is the important difference. There is no cut and the tip has better bearing surface - no sharp edges. I’m sure the earlier plate (the one I posted earlier) that’s on the friend’s car will not work well with a release bearing once the centering ring was removed. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Glenn  Mr. 010
Posted: Mon Dec 19, 2022 6:57 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
Different design, the other is a 9 spring. _________________ Glenn
Member #1009
#BlueSquare
Cusser Samba Member
Posted: Mon Dec 19, 2022 9:11 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
I honestly don't remember if the pressure plate originally in my 1971 was 9-spring or not, just remember that it had three arms and no center ring. I can't remember if that pressure plate is now in my box of parts either, I just know that when I rebuilt that 1971 engine to go into my 1970 sedan in 2016-2017, that I couldn't use its pressure plate because it had no center ring. I had to buy a new PP with a center ring
And apparently I didn't save the center ring from my other 3-arm pressure plate when I had to remove its center ring when I moved the 1835cc engine from my 1970 sedan into my 1971 convertible about 2005.
Got all that? The test is tomorrow !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
SoFlo1970BusTypeII Samba Member
Posted: Sat Apr 22, 2023 12:45 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
After installing the early to late model throwout bearing conversion kit the throwout bearing body turns sideways when the clutch is depressed without the engine installed. I have a video of it doing this but it was too big to upload. Is this happening because the pressure plate is not there to keep it in place or is there something else going on that I should address before dropping the engine in? |
Glenn  Mr. 010
Posted: Sat Apr 22, 2023 12:49 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
The TO besting is crooked, so is it on the arms correctly or are the arms bent?
Member #1009
#BlueSquare
Posted: Sat Apr 22, 2023 1:08 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
| It starts out perfectly square then when we depress the clutch it turns. |
Posted: Sat Apr 22, 2023 1:09 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
| I was able to shorten the video to where the Gallery let me upload it but now I can’t find it in the Gallery. |
mikeonthebike Samba Member
Joined: December 08, 2012 Posts: 1010 Location: Sacramento, CA
Posted: Sat Apr 22, 2023 1:12 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
| The throwout bearing is not on the arms straight. The left side is too high and/or the right side is too low. You need to get that straightened out. See Glenn's picture. |
Posted: Sat Apr 22, 2023 1:19 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
| mikeonthebike wrote: |
It is on the arm straight to begin with then it turns when the clutch is depressed. I really wish I could figure out how to upload the 3 second video that shows it turning. |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4145 Location: Seattle, WA
Posted: Sat Apr 22, 2023 1:36 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
| SoFlo1970BusTypeII wrote: |
| After installing the early to late model throwout bearing conversion kit the throwout bearing body turns sideways when the clutch is depressed without the engine installed. |
It doesn't look to me like you have the correct TO shaft for the late-style bearing. The arms on that are quite different from the earlier style. Look at where the cutouts in the shaft arms are in the photo Glenn posted. _________________ '67 bug: seized by the authorities
