Solvent to remove old carpet adhesive
chrismsnt
chrismsnt is offline
PostPosted: Fri Dec 23, 2022 7:02 pm    Post subject: Solvent to remove old carpet adhesive Reply with quote
So, I'm pulling out all my old carpet as my journey continues on! Does anyone know what solvent to use to remove the old carpet glue? I would like to get things as clean as possible prior to sound deadening and then new carpet install. Thanks!
Chris
1989 T3 Vanagon 16" Syncro
1967 Squareback
https://vwvandiesel.com
Instagram @VW_VanDiesel
dobryan Premium Member
dobryan is offline
PostPosted: Fri Dec 23, 2022 7:10 pm    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
I used a wire wheel to knock off the big chunks and then sound deader over the panel. No need to remove all the glue in my book.
Dave O
The Western Syncro build
DanHoug
DanHoug is offline
PostPosted: Fri Dec 23, 2022 7:14 pm    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
i'm sure someone will chime in with the right solvent but i'll offer that the only place i'd spend the time on to remove the glue is over the seat lid. i like a floppy, unbonded piece of carpet over that personally. the rest is going to be bonded with the sound deadening adhesive anyway so what does it matter? it sure ain't coming off! now if it sticks up enough to affect the bonding of the sound mat, that's another matter. i'd start with laquer thinner, then Goo Gone, maybe acetone, then maybe WD40. just throw whatever is on your shelves at it!
-dan
www.thefixitworkshop.com
DuncanS
DuncanS is offline
PostPosted: Fri Dec 23, 2022 8:24 pm    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
Gasoline is the universal solvent for gooey adhesives. It will take a fair amount and need stiff wire brushes to work it to a removable consistency.
Duncan
csebern
csebern is offline
PostPosted: Fri Dec 23, 2022 8:37 pm    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
Duncan
Gotta second this. Gasoline works great at breaking down old set adhesives.
Use gloves, make sure you have really good ventilation and for Pete's sake make sure not to use any cordless or corded brushed power tools.
If you must use power tools, brushless only. No sparks.
Get a Volkswagen they said. It'll be fun they said.
Howesight
Howesight is offline
PostPosted: Fri Dec 23, 2022 11:57 pm    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
LePage's glue makes a solvent for removing or cleaning up after using their contact cement. It works great and is not as toxic-smelling as lacquer thinner, which is mostly made up of toluene and xylene, both of which get you high unless you use a VOC mask. Lacquer thinner does, however, do a great job of removing contact cement.
Although I am a petrol-head, I hate the smell of gasoline inside a vehicle.
'86 Syncro Westy SVX
tjet
tjet is offline
PostPosted: Sat Dec 24, 2022 6:35 am    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
MEK will take that right off
https://www.westmarine.com/sunnyside-corp.-methyl-...HzEALw_wcB
ZsZ
ZsZ is offline
PostPosted: Sat Dec 24, 2022 7:00 am    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
I would try acetone or white spirit, but these residues are usually really dry and solvents does not harm them.
A rubber eraser wheel on a corded drill or small polisher would be the fastest and safest way.
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
Bonesberg55
Bonesberg55 is offline
PostPosted: Sat Dec 24, 2022 7:36 am    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
Lacquer thinner but wear a respirator.
caseyl
caseyl is offline
PostPosted: Sat Dec 24, 2022 8:50 am    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
Have you tried dry ice? It sometimes works very well.
Ronzo_volvo_guy
Ronzo_volvo_guy is offline
PostPosted: Sat Dec 24, 2022 9:16 am    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
Forum;
Good solvent possibilities already mentioned ...here's another one: Paint stripper may also contain the volatiles necessary to reliquify or just loosen the glue remains enough to allow wiping them away without attacking the surface beneath...length of time in contact is an important factor...too long and it may start affecting coatings on the surface beneath. Effectiveness and Compatibility tests are always called for!
Cheers and Greetings of the Season to all!
tencentlife
tencentlife is offline
PostPosted: Sat Dec 24, 2022 10:06 am    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
Well, I would ask why would anyone would waste their time on something so useless, but I won't because I know from observing others that anal-retentiveness is a powerful drive no matter how ridiculous the things it makes its sufferers do.
That said, MEK or TCE. I mean, seriously, if you're gonna be fucking around, why fuck around?
74 Thing
74 Thing is offline
PostPosted: Sat Dec 24, 2022 10:16 am    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
3M Adhesive Remover
DuncanS
DuncanS is offline
PostPosted: Sat Dec 24, 2022 11:21 am    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
All this stuff you guys are taking about costs way north of $10/gallon. Gas here is $3.45. The smell of gas quickly evaporates and is nowhere near as toxic as the stuff recommended.
Duncan
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Sat Dec 24, 2022 1:00 pm    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
I just did this job in preparation of new carpet. Used a razor (with the edges rounded a bit) held in a flat holder and scrapped the old cement off easily.
Then used acetone to remove the little bits of residue. Also touched up any chips and scratches with some color matched marine enamel I have leftover from another project. Came out nice and spiffy.
Only went to this much trouble after reading some comments about the sound deadener I plan to use. Complaints about the stuff not sticking very well. Plus I've a touch of OCD Wink .
Currently:
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Dec 24, 2022 2:00 pm    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
74 Thing wrote:
3M Adhesive Remover
THIS
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
DuncanS
DuncanS is offline
PostPosted: Sat Dec 24, 2022 2:37 pm    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
https://www.google.com/search?q=3m+general+purpose...nt=gws-wiz
$30 per QUART. $120 a gallon vs, gas and 3% of that price.
Duncan
MsTaboo is offline
PostPosted: Sat Dec 24, 2022 2:57 pm    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
Duncan
Or a little labor and 30 cents of acetone.
Most people are working indoors in the winter and gasoline as a solvent is not a good idea. While you should still use caution working with acetone, gas is very explosive.
https://www.tdi.texas.gov/pubs/videoresource/t5gasolinesafety.pdf
https://classicmotorsports.com/articles/dont-use-fuel-degreaser/
Currently:
DanHoug
DanHoug is offline
PostPosted: Sat Dec 24, 2022 3:12 pm    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
MsTaboo is uh .... dead on. gasoline has a flash point of -45F and acetone 90F. think of flash point as the temp at which a match or spark over the liquid will ignite the vapor.
both vapors are heavier than air and will travel along the floor like a snake looking for your furnace flame.
-dan
DuncanS
DuncanS is offline
PostPosted: Sat Dec 24, 2022 11:48 pm    Post subject: Re: Solvent to remove old carpet adhesive Reply with quote
"Or a little labor and 30 cents of acetone." 30 cents of acetone is less than ½ oz. How many square feet can you clean with ½ oz of acetone? I'm guessing a a couple of square inches depending on how much adhesive there is. I use acetone to clean off the adhesive on glass or plastic bottles I want to save and it takes repeated applications to get rid of it.
Gas indoors. Why would you do that unless it's a small butter dish to clean a part? Back the car out.
Duncan
